Question about Alpine SWS-1240 Car Speaker
I am trying to install speakers in my 95 chevy cheyenne 1500, but there are no holes to screw in the screws. do i just need to make new holes? if so, how?
    Guru:
  • 403 Answers
I would recommend just drilling new holes do not try to screw them in without first drilling pilot holes other than that you should be fine just make sure that the panel has no wiring or vital components behind it.
Posted on Jun 04, 2010
Chevy cheyenne starter
need more info does it have fuel try starting fuid to see if it tries to sart then its fuel related
Jan 10, 2014 | Cars & Trucks
I have a 95 chevy cheyenne. My ac pump doesn't
Have you checked to see if the system has enough freon ?
If the system is low or empty the low pressure switch will prevent power from going to the compressor clutch.
Aug 29, 2013 | Cars & Trucks
Can a 94 chevy cheyenne transmission interchange with a 97 chevy silverado tranmission
Will it physically fit? yes. Will it be a direct replacement any everything hook right up and plug right in? If we are talking about an automatic then no. 1994's wiring was completely different than the 1997. Can it be made to work? possible, but I believe it would be more trouble trying to make it work than if the correct transmission were located and installed. If it is a cost issue where he has a good trans out of a 1994 he might see if a salvage yard will do some partial trading for the correct trans.
Apr 24, 2013 | 1998 Chevrolet C1500
Cost of a wiper motor assembly for '93 chevy cheyenne 1500, 4.3 v6
A rebuilt motor should be around $50 depending on the store and where you live.
Oct 07, 2012 | 1997 Chevrolet K1500
Cant seem to axcess the rear speaker screws to replace them.
Are you looking from the trunk to the top of the rear deck? You are correct though in most factory installed audio systems, the size and quality of the speakers is unique and low quality. Generally any aftermarket speakers you buy will have to be bolted using holes that you drill in the deck. Also most car audio place will cut the deck with a saw in order to enlarge the holes for better sound. You may want to consider using POP rivets as fasteners for the new speakers because getting under the glass to use screws can be tough.
Oct 30, 2017 | 2004 Chevrolet Aveo
Replace brake switch on 1995 chevy cheyenne 1500
Brake switch wiring good, can manually make switch and brake lights work. But when installed and brake pedal mashed does not work. Slight pressure on rear of switch will allow to work. How do you keep switch stationary? Switch is clamped around booster rod and has clip installed. Switch is new. Is there a brake pedal adjustment? HELP PLEASE.......... 1995 CHEVY 1500, 5.0L ENGINE
Nov 22, 2009 | 1995 Chevrolet C1500
What is the torque specifications on a 1995 chevy cheyenne 1500. looking for the torque specs on the bolts going from the transmisison to the bell housing.
transmission to engine is 32ft lbs but is normaly tighten alot tighter you can't screw this up tighten really tight
May 08, 2009 | 1995 Chevrolet K1500
95 chev cheyenne 1500 5.7 club cab
Chevy trucks are known for wiring trouble most likely there is a wire shorted out under the carpet. Always test first though before ripping out interior lol
Apr 26, 2009 | 1995 Chevrolet C2500
Broken inside door handle-1996 Chevy Silverado Extended Cab
On almost all GM's there will be a screw in the recess that the handle sits in. After removing this screw, gently wiggle this cup out of it's hole and there should be a metal rod attached to the back of it with a small clip. Unclip this and it's out - installation is the reverse. Just don't lose the clip or let the linkage rod fall down inside or you will have to remove the door panel. It shouldn't take five minutes to replace and most parts stores now carry GM door handle assemblies. Good Luck!
Jan 11, 2009 | 1999 Chevrolet Silverado 1500
Alpine SWS-1240 Car Speaker Logo
79 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Jaime Hernandez
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
