Kenmore Washer - Who is actual maker
Model 110.4786291
TYPE 111
Who is the actual maker of this washer is it Whirlpool, Inglis, GE?
Also is it a Direct Drive or Belt drive.
Anyone got answers
Thanks
  • Jeff Rockwell
    Jeff Rockwell May 11, 2010
    Whirpool is the manufacturer and the washer was manufactured in 1997. Can you please verify the model number again? I cannot find a match for it.
  • 240 Answers
SOURCE: Clothes washer won't drain - digital display shows LD
looking at the tech sheet for this, it appears to be a standard whirlpool top load but with electronic controls, correct? normalling with this type a lid switch is the issue but the electronics would have a different code for this, LD is Long Drain for this model. suspect a transmission but this should help you troubleshoot. go to www.servicematters.com and click technical reference - tech library - tech sheets, enter model minus 110.prefix. this will show tech sheet with diagnostics. this book can also be found inside your console.
Posted on Mar 14, 2009
tomsat69
  • 214 Answers
SOURCE: inglis direct-drive washer spins slow even with no
First cheack if there is oil on the floor under washer if there is you need a transmission and a clutch clean.
or If you can feel around the top of your tub where the splash guard is there may be a piece of clothing stuck there it is between the inner and outertub if you can't feel anything you may need to get a repair man in there to remove tub to cheak If he ia a good repair man it should only take a few min
Posted on May 07, 2009
localwonder
  • 6784 Answers
SOURCE: Kenmore type 111, very weak spin
HI, you have an issue that concerns the internal structure of the drive motor. it could be that , the transmission is dry(Low oil state, causing friction) or, this could be a weak motor as well.
This will require a careful inspection of the transmission and, drive assembly and motor.
A service tech is recommend in this situation.
Posted on Jun 24, 2009
canbruce75
  • 1776 Answers
SOURCE: i need instructions on replaceing the motor coupler
Check the video at the following link and see if it is of assitance to you in changing the coupler. Sure hope so and best wishes.
http://www.youtube.com/watch?v=WLPGs2UMUJc
Posted on Oct 04, 2009
  • 401 Answers
SOURCE: I have a Kenmore washer model 110-24962300
There are plastic parts called "dogs" that need replaced. They are inexpensive and not hard to do.
Posted on Jan 02, 2010
I would like to know the year of my Kenmore special edition washer and dyer SM 97 10804-4
Hi C,
Looks like around 2001 according to Serial #.
110 prefix means Whirlpool manufactured this item for kenmore
Dec 29, 2014 | Kenmore Washing Machines
It is a Kenmore 90 series The model number is (small) 110 (bigger next to it) 22902100 serial number: 2219941 type: 111 This was given to me. they said all it needed was a fuel fill sensor... what is that,...
I have no clue what a Fuel Fill Sensor is on a washing machine. HOWEVER,
See the Sears Parts site for your washer with diagrams of all major parts and components.
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.22902100&pathTaken=partSearch
Also see the Whirlpool / Kenmore Service manual for this type of washer.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Also see the following for how to access the console and remove the cabinet if necessary.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=fdfb6e4cb03bc063c74b1096fca5a7cd
By determining what the washer WON'T DO, you should be able to determine (also using the Whirlpool manuals' troubleshooting section) what part you need.
Apr 19, 2010 | Kenmore 24032\24036 Top Load Washer
Whirlpool type 111 model LSQ9200LQ3 washer not
I have a whirpool model:lsq9200lq3, and recently it has stopped working. when ever you turn it on, its fine and the water fills up normally and right before it gets to the spinning cycle the machine makes a grinding noise like if something is stopping the motor from spinning, and it dosent spin inside the washer. if anybody has any suggestion It would be great thank you.
Jan 30, 2010 | Whirlpool Washing Machines
Loud noise coming from bottom of washer during spin cycle
If it is a ge kenmore it sounds like your tub bearing is dry and needs to be replaced.The reason i say ge kenmore is because they fall under differant companys depending on witch year you bought it
May 07, 2009 | Whirlpool Inglis IP4400 Washer
The tub on my kenmore model no.44052401 front loader won't turn
Always remember Electricity is dangerous and should be treated with respect.
Please pick a topic of your  problem by clicking ...hope you find this helpful :-)
  1. Automatic dispenser information
  2. How a washer works, good to read this first: Click here
  3. Has Kenmore or Whirlpool ever had a off-balance switch.....
  4. Help for storing an appliance
  5. How does the agitator come off my washer ??
  6. How to prevent socks from getting into your pump
  7. Inglis, Whirlpool and Kenmore belt washers - common problems Like timers, pumping problems, leaking, spinning, agitating and spinning/agitating at the same time.
  8. Inglis, Whirlpool & Kenmore belt drive washers How to take washer apart and how the washer works.
  9. Inglis, Whirlpool & Kenmore style washers which style do I have ?
  10. Inglis, Whirlpool & Kenmore - how to replace the belt
  11. Inglis, Whirlpool & Kenmore - how to tighten the belt
  12. Inglis, Whirlpool and Kenmore - how to replace a pump
  13. Inglis, Whirlpool and Kenmore - how to replace or check the wig/wag solenoid assembly from American appliance
  14. Inglis, Whirlpool & Kenmore - How to remove inner basket
  15. Inglis, Whirlpool, Kenmore belt drive washer - parts breakdowns
  16. Inglis portable washer belt change help From our friend Lee )
  17. Important disclaimer
  18. Missing cycles or timer stalls in middle of cycle
  19. My clothes have a whiting on them that looks like lint.
  20. My washer has a funky odor
  21. Slow water fills
  22. Washer Basics: Filling with water problems
  23. Washer belts: If your belt on any washer looks like this, replace the belt(s).
  24. Washer sample wiring diagrams
  25. Whirlpool newer style apt size newer washer
May 06, 2009 | Kenmore Washing Machines
Water problem
Apr 01, 2009 | Washing Machines
Not sure if manifold is leaking
Leaks water...check the pump first. The fill valve and hoses may be the next step. See how to take apart info. With the use of plastic drain hoses on many machines today, this has become a common leak trouble maker. The drain hose can rub the wall or a pipe and this will rub a hole in the drain hose.
  1. Agitation problems and agitator dog repair aid info
  2. Automatic dispenser information
  3. Common problems with Inglis, Whirlpool, Kenmore direct drive style of washers
  4. Diagnostic Direct Drive washer chart from American appliance
  5. How a washer works, good to read this first
  6. Help for storing an appliance
  7. How does the agitator come off my washer ??
  8. How to prevent socks from getting into your pump
  9. Ohm test a common direct drive motor
  10. How to by-pass a lid switch for testing the washer
  11. Basic information: Inglis, Whirlpool, Kenmore Direct drive washers
  12. Inglis, Whirlpool, Kenmore Direct drive washers - How to take apart - Cabinet off, cabinet on, checking or replacing a lid switch, replace the pump, replace motor coupling or motor.
  13. Inglis, Whirlpool and Kenmore direct drive washer- useful parts breakdowns
  14. Important disclaimer
  15. My direct drive washer will fill ok, agitates ok but when it comes to the spin and drain cycle the washer comes to a screeching halt...no spin, no draining and the timer stops, what's up?
  16. My clothes have a whiting on them that looks like lint.
  17. My washer has a funky odor
  18. Noises
  19. Ohm meter testing a motor capacitor
  20. Slow water fills
  21. The wash tubs on my direct drive washer are leaning to the right...why?
  22. Timer stalls or missing cycles
  23. Timer will not advance
  24. Tips on changing a common washer fill valve
  25. To learn more about washing machines, click here
  26. Washer Basics: Filling with water
  27. Washer leaks water
  28. Washer moves around to much
  29. Washer will not spin
  30. Washer sample wiring diagrams
  31. Washer spins and agitates at the same time
  32. Washer belts: If your belt on any washer looks like these, replace the belt(s).
  33. Washer runs but wont agitate or spin
  34. Washer won't run, agitate or spin
  35. What is that black power powder or filings under my washer??
Apr 01, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Mar 14, 2009 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
63 people viewed this question
Top Washing Machines Experts
