My ac unit fan is working but compressor is not kicking on
  • passeym Jun 04, 2010
    Thanks much for your response. Much appreciated.
    Brigadier General:
  • 3,513 Answers
I hope this helps…Please check the bellow links…
http://toad.net/~jsmeenen/compressor.html
Is the thermostat knob turned to the proper setting?
The compressor is a football-sized case with no apparent moving parts. It is located inside the air conditioner at the center. Is it humming or making any kind of continuous noise or causing the lights to dim? If it is making a continuous noise, and your air conditioner is still not cooling at all, there may be a serious problem with one or more of these areas:
Compressor
Condenser
Evaporator
These items are not user serviceable. You will need to contact a qualified appliance repair technician to repair these components.
If the compressor is not running but you do have power to the air conditioner there may be a problem in one or more of these areas:
Compressor
Overload and/or relay
Thermostat (Open thermostat)
Burnt wiring
Bad selector switch
Capacitor
Let us know if you want something more else please accept the solution.
Thank You for contacting Fixya.com
Posted on Jun 04, 2010
Fan will come on but compressor wont kick in on wall unit ac
The start capacitor on the compressor is bad. Replace it and the compressor will run.
Jun 30, 2013 | Heating & Cooling
Could cluster fuse be prob why ac blowing hot? fan blows but hot air
Does the Compressor kick in when you turn on the AC? If it doesn't, the AC compressor is governed by the ECU. My AC went out along with an acceleration problem. hard starting, and unburnt fuel. I had my ECU rebuilt, and upon installation of the rebuilt unit, all worked perfectly again, including the AC.
Nov 08, 2012 | 1993 Lexus Ls 400
I have my dometic Rooftop ac unit. The heatstrip/fan run perfectly but when I turn on the ac...the fan runs good but when the compressor kicks on it just hums.
The compressor coming on does make a slight "humming" sound which is normal. Is the unit cooling properly? Do you think it is louder than before?
May 09, 2010 | Dometic Rooftop RV Air Conditioner
AC unit not kicking on...
You need a "Y" terminal. "Y" is pretty standard on every heat pump. It is the wire that will energize the compressor contactor at the outdoor unit, allowing the compressor and condensor fan to run.
Apr 03, 2010 | Heating & Cooling
My window Ac unit wont cool, I had problems with the cooling element icing over but now the ac wont kick on the fan still blows, and Iv only had this unit for two weeks.
You are low on freon. There is a pressure switch that will not allow the compressor to kick on in order to protect the compressor. The freezing up of the unit is an indication of a leak or air flow blockage.
Jul 07, 2009 | Heating & Cooling
Compressor on my RV coleman ac unit bogging down
Take a look at your start capacitor. This the capacitor that kicks the compressor over when it tries to start. If the capacitor is bad, it cannot kick the compressor back over after the first cycle because the head pressure has not evened out yet. It is located in the upper unit on the side panel in a small box. Be careful, highly charged capacitors can zap you if you are not careful. Disconnect power and touch across the terminals with a meter or a screwdriver to discharge the capacitor.
Hope this helps,
Jeff
Jun 29, 2009 | Coleman Mach 15 Air Conditioner
AC/Heatpump units cycle numerous times blowing ambient air.
If the compressor never kicks in, I would check the start capacitor, thermostat and the compressor windings. Most times the start capacitor is defective. Some window air conditioners the fan will run while the compressor stop through the thermostat switch. If the thermostat switch is bad every thing runs except the compressor. Let me know, Thanks, Sea Breeze
Feb 07, 2009 | Dometic Rooftop RV Air Conditioner
A/c issue
Could be a couple things - one, if the fan switch for the AC condenser is not working, it'll keep the AC from kicking on, but that's usually seen by the compressor not coming on. When you activate the AC, do your RPM drop down at all? It should. If it does, the compressor is kicking on and you probably have a problem with the expansion valve, which is what flash chills the air. The car is pumping freon around but it's not cooling enough to cool the car. That's likely an expansion valve problem.
If you turn it on and the revs don't dip down momentarily, the compressor isn't coming on, and it could be the fan switch underhood or the AC relay.
Aug 29, 2008 | 1998 Volkswagen Jetta
Heating & Cooling Logo
18 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Mack Baxter
