Question about Kenmore Elite 45986 Front Load Washer
F 20 Error code washer won't fill up.
The washer begins it cycle but won't fill up. Shortly after it shuts off with a F 20 error code. Is there a fix, can anyone help? Thanks
    President:
  • Kenmore Master
  • 662 Answers
Http://www.fixya.com/support/r3608632-f20_error_code
Posted on Jun 04, 2010
For the last few weeks, my 5 year old LG 2487HRMA, has been giving me de code errors shortly after starting. It is because the lock light just goes from red to off for no reason.
Lift up the top of your washer and there will be a code and test sheet in there that will help lead you to fixing that problem, almost sounds like it went into the its own test mode.
Jan 09, 2016 | LG WM2487H Front Load Washer
Kenmore Model 21082000 won't fill during wash cycle
Try checking the lid switch. Sometimes the switch goes bad or the stem breakes and when the lid shuts it will not activate the switch. Usually located on the right side of the dryer. When the lid closes it will allow water to.fill. Washers are easy to fix and the part is cheap. Get it from amazon dont pay the crazy price your dealer wants. Trust me, i just fixed my mothers...
Feb 16, 2013 | Kenmore Calypso
My Kenmore front load washer will not fill--it sounds like it is draining instead. The last load washed did not spin correctly and the clothes were very wet when cycle completed.
Washer Not Filling:
  • Door Not Closed and Locked
    • Front load washers won't fill if the door is not closed and locked. Listen for the door locking when starting a cycle, then pull on the door to make sure the door is closed and locked.
  • Delayed Start Feature
    • Some washers have a delay prior to filling, where the electronic control is checking the dispenser function. This is Normal.
  • Flashing Lights or Error Code on Display
    • When there is a filling issue, the washer may shut off and display one of the following codes: LF, LE, nF, IE, FH, E10 or F20.
    • If the washer is displaying one of the above error codes, then do the hard reset procedure listed below.
If the appliance is not accepting input from the control panel, follow the steps below to reset the control:
  1. Unplug or turn the circuit breaker off for 30 seconds.
  2. Plug the power cord into the wall outlet or turn the breaker back on and wait 30 seconds.
  3. Press the Pause / Cancel / Stop button twice to clear the display.
  4. Start a short cycle, to check operation of the appliance, by selecting a cycle and pressing and holding the start button until the appliance starts.
Oct 15, 2012 | Kenmore Washing Machines
Maytag Bravos error code f1
F1 is a very bad error unfortunately. Try unplugging the unit 60 seconds to see if it will reset the control board. If not, then you will need a new relay control board which is about $200, because F1 means that the board has detected an internal short inside the control board itself.
Apr 24, 2012 | Maytag Bravos MTW6600T Top Load Washer
Error code F 35 and SUD code
Save yourself a lot of time and money and replace the analog pressure switch. This will solve your issues by taking care of both error codes at the same time.
The Appliance Pro
Jun 27, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Motor error with out error code.
use tech sheet to follow test routine. C:05 is Heater test. some steps take time. during normal operation if timer display flashes, may be indication of standby/pause. Door lock sw may be bad(intermittant)
Apr 22, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Has error code F 20 and will not finish cycle
if your water is to cold it will have the same error. Somtimes the water from your water heater is not warm enough so you have to run the water from another source till it is coming out hot. this solved my problem every time.
Nov 23, 2008 | Whirlpool Duet GHW9150P Front Load Washer
How do you fix error F5?
"F5" is a temperature sensor error. The following link explains how to diagnose and correct:
http://www.fixya.com/support/r629462-f05_error_code_whirlpool_duet_kenmore
The first thing to try, however, is to unplug the washer for AT LEAST 30 minutes in an attempt to reset the Central Control Unit (CCU). Sometimes this is all that is required to correct momentary glitches. If the error code reappears, then you know you have a legitimate error. In many cases, the small connector that plugs into the heat sensor either becomes corroded, or comes loose. Make sure you troubleshoot the washer while it is UNPLUGGED.
If you have questions, or require additional assistance, please let me know before you rate the solution. I hope this helps you.
Sep 23, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
176 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
