Question about Jackson JPX-300L Dishwasher
The washer cycle stopped without warning, i thought the timer or the timer motor but it is not the timer works fine and so is the motor. but the timer motor runs til the washer motor starts than is the timer stops and the washer is working but not cycling so no rince or drain or soap etc... just pumping water. if you can tell me what might be the problem, thank you. like i said the timer stops when the washer motor start.
  • Jackson Master
  • 822 Answers
Confirm that the lid switch a common failure is working. A distinct click is usually heard when lid is closed. Temporarily by-pass to confirm and diagnose this type of problem. Confirm tab is in place on the lid.
the washer cycle stopped without warning, i - s-l300-jlcsdtjcsmou2gzo41dox2se-5-0.jpg
the washer cycle stopped without warning, i - washer-jlcsdtjcsmou2gzo41dox2se-5-5.jpgimages/washer-jlcsdtjcsmou2gzo41dox2se-5-5.jpg" alt="washer-jlcsdtjcsmou2gzo41dox2se-5-5.jpg" class="h_mi" />
Posted on Jun 28, 2017
4 Suggested Answers
kermit854
  • 38 Answers
SOURCE: soap pump
There are 2 different models of the JPX300H. One has a digital timer assembly, while the other is a cam-timer. Regardless of type, the timing unit is located under the wash tub, which can be accessed by removing the front panel directly below the door. If it is a cam assy (which I think it is), locate the microswitch on the cam assembly for the pump which is running incorrectly and turn the cam so the arm of the switch rides along the outside edge of the cam when the pump should not be running.
If timer is the digital type, then contact Jackson Tech Support for troubleshooting assistance. Their service is free and you can find the phone number at www. jacksonmsc.com
Posted on Aug 19, 2008
SOURCE: Soap suds and some water not draining out of washer after cycle is complete
if you read the manual, it states that this is normal. so dont let this bother you
Posted on Jan 26, 2010
SOURCE: We have an old Jackson Model 24B. Serial 3
The sensor for the door (top right behind flashing) is no longer working. $48 part. 1 Hour service.
Posted on Sep 07, 2010
Wash cycle are running to long
FIXED Maytag Neptune, Timer Problem - ApplianceBlog
www.applianceblog.com/.../23387-Maytag-Neptune-Timer-Problem
Mar 4, 2011 - 8 posts - ‎3 authors
My countdown timer is stuck at the 33-minute level in the "wash cycle", and repeatedlyruns for a 30-40 seconds, then stops, then runs, then ... Maytag Neptune TL Washing Machine stops in spin cycle ...
Jul 25, 2013
Maytag Neptune Washer Won't Spin/drain
Jul 4, 2013
Neptune TL Washer FAV6800AWW - DC and UC ...
Jul 3, 2007
MAYTAG NEPTUNE WASHER CONTROL PANEL ...
Jun 29, 2005
More results from www.applianceblog.com
Troubleshooting a Too-Long Wash Cycle - whirlpool washingmachine ...
ask.metafilter.com/233920/Troubleshooting-a-TooLong-Wash-Cycle
Jan 25, 2013 - We have a Whirlpool Duet washing machine (about 2 years old). Thecycle is taking WAY too long to complete. The load that's running now ...
Maytag Neptune washer repair: motor/motor control circuit ...
? 12:10
https://www.youtube.com/watch?v=ITTbDh8CFEU
Dec 11, 2013 - Uploaded by daytonaturbofreak
Maytag Neptune washer motor/motor control circuit board ... my board just fried - is your washer still working? wondering how longthe conversion fix will last. ... Other times it will run a completecycle without any malfunctions.
Jan 11, 2016 | Maytag Neptune MAH5500B Front Load Washer
Kenmore 110 Spin Cycle
Assuming that this is a basic top load, direct drive, neutral drain washer it seems as if the problem is likely in the timer.
The transmission and draining are controlled by the motor which gets it's power through the timer. If the timer isn't advancing once it gets to the spin cycle area, the motor keeps getting power, the machine keeps spinning and only by pushing in the control knob will the motor stop.
Here are a couple of places to look at how the machine works and parts for a basic Kenmore washer.
Sears parts site:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number and you'll see a number of sub catagories for the washer components.
Whirlpool Installation and maintenance PDF.
This is a public domain Whirlpool manual describing how the washer works and a good troubleshooting section.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Sep 21, 2009 | Kenmore 22642 Top Load Washer
During normal cycle agitation is a constant stop/start
Yes, the timer mechanism should be replaced asap. the timer has a motor that is responsible for the rotation of the device. This motor is damaged, in return, not allowing the normal cycle to initiate and transfer sequential information to the motor properly.
Replacing the timer will correct this issue.
Aug 31, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
TIMER ON WASHER MAKES A TICKING SOUND DURING CYCLE
HI, this timer is faulty and, these are early warning signs of potential failuer of this device in the near future. i would prepare to replace the timer control soon. the actual mechanism is showing signs of breakdown.
May 23, 2009 | Amana 3.2 cu. ft. Top-Load Washer
Kenmore Fabric Care 90 won't stop washing
It sounds like your timer motor may have died. Pull the knobs off the controls and remove the screws in the control panel to get to the motor. The motor is usually pretty expensive, so you might want to consider buying a new washer over replacing the timer motor.
Apr 18, 2009 | Kenmore 22422 Top Load Washer
Washer will fill fill with water but doesn't start wash cycle
it will fill but won,t spin, will throw out water as if it washed, then it take water to rinse but won,t spin ,then will throw out water as if it did , but clothes are soaked
Feb 21, 2009 | Roper RAS8445KQ Top Load Washer
Washer fills/agitates and stops prior to draining
If pump works fine or still pumps out water, then it is a timer malfunction. Replace the timer and you should be fine. To locate a part number for your timer, refer to www3.sears.com with the model number off your washer.
Mar 14, 2008 | Kenmore 24032\24036 Top Load Washer
Asko w6221 front load washer stops after wash cycle
Do all of your cycles work when you turn them manually? If one cycle does not work when you turn the dial on it then it will be your timer (The dial assembly $100-up) If all your cycles work manually, then it could be your timer motor which is attached to your timer assembly. If you turn the dial pass the wash, on to the rinse, does the dial automaticly move (when finishng the rinse cycle)to the spin cycle? If so then your timer motor is ok. The only wires close to the bottom are the motor, but these should be high enough out of the way.
Apr 01, 2007 | Asko W6221 Front Load Washer
Jackson JPX-300L Dishwasher Logo
Top Jackson Dishwashers Experts
gbob59
jhnolson
Are you a Jackson Dishwasher Expert? Answer questions, earn points and help others
