Question about Philips 50PL9126D/37B 50" DLP TV
I have a ticking noise when i try to turn on the tv..
I took the TV apart to try to change the light bulb in it because it went out. When i got everything apart and got the light bulb installed i put everything back together and the TV started to make a ticking noise i don't have the back piece back on yet because i wanted to see if i installed the light bulb in correctly but now all I'm getting is this ticking noise coming from the center on the TV. What do i do to get it to stop ticking and come back on?
  • Philips Master
  • 5,124 Answers
Try putting on the back piece. Some of these TVs have a circuit protection system that will not deactivate with the back open. (It is like an old circuit breaker with the fuse out.)
I hope this helps.
Posted on Jun 04, 2010
Samsung HLR5667wx/xaa. Power surge took out tv. Replaced bulb and the bulb works, but tv wont come on and lamp light is flashing.
Hello, it sounds like the color wheel may have failed. Was there any noises, like a high pitch sound before it went out? If the color wheel isn't turning at proper speed, the set won't start up by shutting down the lamp protection circuit.
Jul 10, 2014 | Samsung HLR5667W 56" Rear Projection HDTV
When trying to turn on my tv, the green light blinks a few times then the red light blinks a couple of times then automaticaly the tv shuts off. There is no picture at all. It makes a couple of sounds like...
sounds like the projection bulb went bad. change the bulb and it should work. sometimes they make a high pitch noise when they are trying to turn on. the bulbs seem to last about 2 years for me.
Jun 04, 2010 | Zenith E44W46LCD 44" Rear Projection...
Panasonic PT-50LC14 HDTV went caput and stopped working
Ur tv LED light indicator "LAMP"flashes?Then the projection bulb life is over must be change.This tv been watching the tv at least 4 or 5 hours a day,the last 3 years?The projection bulb only last about 1500 hours.
May 26, 2010 | Panasonic PT-50LC14 50" Rear Projection...
Polaroid Tlx-01511c dead set
The only thing you can do is look inside the TV for blown fuses. But, after that. it's hard to tell what's really wrong with it. And taking it to someone to diagnose the problem will cost more than the 15" TV worth. At the moment, I can't find a Service Manual for that TV yet. But, if I had to guess, the power supply board went bad. Cost about $80.00 at shopjimmy.com. It's only a guess.
Sorry I can't help you more.
Feb 03, 2009 | Polaroid FLM-323B Television
Rca tv
I had this happen to mine and I had to have the high voltage transformer replaced. I took it all apart my self to save money and it only cost me about $285
Jan 14, 2008 | RCA P52926 52" Rear Projection Television
Rca HD50LPW62YX1 50 in. DLP TV
Try lamp first #265919 Approx $300. Use ONLY RCA LAMPS from a RCA box
Dec 14, 2007 | RCA HDLP50W151 50" Rear Projection HDTV
Ticking sound when turned on.
Sent me the serial number, and I can check for any re-call ...
my e-mail is <ultraman_s@yahoo.com>
Oct 29, 2007 | Panasonic PT-40LC12 40" Rear Projection...
My tv will not turn on
I took my TV apart and solved the problem on my own. For those of you that have basic electrical skills and can solder it is an easy fix that only takes about one hour. I removed the rear cover and pulled the left side board which houses the flyback transformer, easily identifiable by the big orande wire coming off of the top. If one looks carfully the soulder connection will probably be broken or loose which can be caused by movement or heat. I resoldered all of the connections for the transformer about 12 and the grounding wire to the left, a single black wire that plugs into the board. Once this was done I put ti all back together again and no problems since!
Oct 29, 2006 | RCA HD52W58 52" TV
Philips 50PL9126D/37B 50" DLP TV Logo
136 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
