Question about Jl Audio E2150 Car Audio Amplifier
I just installed a JL Audio M6450. The remote power on/off from my Pioneer indash is able to trigger the power antenna, but does not trigger the amp to turn on. When I bridge from the amp power to the remote power on/off, the amp will come on fine so I know it is not a problem with the amp. I tested and found that I am just below 12v across the remote power wire, so I upgraded to a heavier guage wire & still no go. Any other ideas?
  • Timothy  Lee
    Timothy Lee Jun 04, 2010
    How do you have the remote wire connected? is it coming off of your radio or do you have it wired into the dash at the fuse?
    Problem Solver:
  • 19 Answers
Upgrading the wire wont fix it some players newer models today has two remote wires but if that's the only remote the player has just install a on and off switch so u can turn it on and off when u ready to use it.
hook up your remote wire to a switch that is conneted to 12 volts.
or u can also instal a eq and use the remote wire that is on the back of that more than likely that should work but if u lookin for a cheap fix instal a on and off power switch on the remote
Posted on Jun 06, 2010
I have a jl 1000/1 and a pioneer 600/4 and i have noise from the motor i cheked the ground replaced the 4 gauge still the same
the noise is from the alternater i believe. you just need to buy a noise filter and install it. i believe this problem is from power supply for your amp going straight to the battery. is that helpful?
Dec 15, 2010 | Jl Audio 1000/1 Car Audio Amplifier
JL audio 250/1 not powerful enough for pioneer TS-W307D4?
you should move up to more power....underpowering subs is bad! try not to go under the subs rms by 5o watts?
Jul 02, 2009 | Jl Audio 250/1 Car Audio Amplifier
JL Audio 500/1 Amp, The green power light is on but no sound!
Check to be sure you are on the correct outputs on the head unit, and be sure the outputs do not have a separate volume control.
Mar 06, 2009 | Jl Audio 500/1 Car Audio Amplifier
How to install my car stereo into my 97 for expidition?
get wire harness- get indash kit - get antenna adapter(if needed).
then do it yourself. note. that is why installers exist. so that you wont have to be asking all these stupid questions.
from, worker at Best Buy
May 24, 2008 | Pioneer DEH-P2000 CD Player
Jl audio E6450 cutting out
hi, have you figured out whats wrong with ur amp ...i have the same amp ....and as soon as i finished the connections ...and connect the remote on wire,,, the amp goes on ...making a ticking sound with the green light blinking and the red light staying solid on ...whats the problem please help ....how can i fix this ......my amp is a jl e6450 ....im using a panasonic cd player with a built in amp ....and thats the cd player im trying to connect to the jl amp ...please HELP
Nov 01, 2007 | Jl Audio E6450 Car Audio Amplifier
Only works for RADIO!!!
You're using the wrong control lead. There should be an amp control lead. You're using the power antenna lead.
Oct 31, 2007 | Jl Audio E1200 Car Audio Amplifier
Pioneer DEH-225 Car Audio
The system remote control is usually a blue wire on your decks harness and it is for an amplifier for a sub or other speakers. It sends power to the subs amp when the deck is turned on. You may need to find the wires coming off the antenna and splice them into the red power switching wire 12v on you decks wire harness. Good luck
Oct 07, 2007 | Pioneer DEH-225 CD Changer
Pioneer GM-7300M 800 Watt amp will not power on
This may have a different type of triggered turn on wire. On some of the older Pioneer amps (and maybe some new ones) the trigger wire would SUPPLY B+ TO THE RADIO and when the radio was switched on the amp would sense a current draw on that wire and would then switch on. Unlike most common amps which sense the presence of B+ on the trigger wire supplied by the radio and then turn on. Look in your owners manual to see kind of turn on system you have. If you don't have an owners manual then perhaps you can download one from Pioneer support. good luck
Aug 23, 2007 | Pioneer GM-7200M Car Audio Amplifier
Jl Audio E2150 Car Audio Amplifier Logo
187 people viewed this question
Top Jl Audio Car Audio & Video Experts
Mark Skinner
Tygh Duval
Tygh Duval
hoyzee1
Are you a Jl Audio Car Audio and Video Expert? Answer questions, earn points and help others
