Question about Motorola Mobility RAZR V3m Cellular Phone
My razr just won't come on anymore
My battery was weak so I had to buy a new charger (long story) once I did the phone wouldn't hold a charge. I bought a new battery. Every thing was fine but when I charged my phone again now the key pads light up. That is light up but not come on. Nothing happens now no lights flashing no response. I took the battery out to let it restart once i put it back in but nothing nothing nothing.... Do I just need a new phone or what??
  • 1 more comment
  • tmuench Apr 19, 2008
    my screen will load up but it keeps going from Extended Network to a blank line (verizon customer) it wont allow me to access any menus or to send or recieve any calls or txts.
  • 1notheard Apr 24, 2008
    I plugged the phone into my car adapter and it charged the phone and all was well so yes it was the charger and not the phone or the battery.
  • Anonymous Jan 04, 2009
    Hey, my cell phone did the exact same thing! My friend gave it to me and there isn't really any damage except scratches and so on..and about a week after having it..the screen kept going white. and at even one point, my phone wouldn't turn on at all. Honestly, I threw it up against a wall a couple of times and its perfect now. lol I kinow sounds crazy, but if you aren't willing to risk it..go to a cell phone place and have them take a look.
  • 75 Answers
If the charger is not original it will broke your phone is the battery is not original will not last like a original one since u changed bouth maybe one of them has a problem go back to the store you buy'it and tell them what happen
Posted on Apr 23, 2008
My Motorola electrify won't turn on or charge. It
maybe your battery or your phone os .... try a new battery if nothing happens... try re flash your phone
Jun 02, 2013 | Cell Phones
Charging pad the remote batteries are dead, won't hold charge anymore...
Sadly that's how they make the new rechargable batteries for controllers. You are supposed to recycle that and buy new. Luckily you can find chargers for the wii very cheap nowadays. I have used a few different chargers and have found the Nyko brand ones are junk so steer clear of those. The Duracell induction chargers however work very nicely. You just set the wii remote down on the charge pad and it charges fairly quickly. My kids run around and even if the remote shifts a bit it will continue charging. Hope this helps!
Apr 22, 2013 | Nintendo Wii Remote Control 4 Charging...
Get my galaxy s to stop saying nonsupported battery
Drain the battery completely... Reset your phone. Often this fixes the problem but its likely your battery is weak and it won`t hold a charge for long. If it was not holding a charge well before this happened then i recommend just buying a new battery.
Oct 19, 2012 | Cell Phones
I put my Droid Razr on charger but battery symbol comes on with ? mark. Won't charge or turn on.
1. Turn off your phone when it's not in use. If you're not using your Verizon Wireless Razr, then shut it off. Your battery will last much longer if you regularly do this.
2. Charge your phone less. If you charge your Razr nightly, then your cell phone battery won't last long. Try to charge your phone only a few times a week to extend the battery life.
3. Keep your Bluetooth turned off when you're not using it. Applications, like Bluetooth, are notorious for sucking the power from a cell phone battery.
4. Protect your Razr from extreme temperatures. Your cell phone battery lasts longer if kept at room temperature.
5. Discharge the Razr fully. Before you charge your phone, let it completely die. You can extend the life of the battery by regularly discharging and then fully charging it.
6. Leave the battery in the phone. Keep the Razr battery dry and free of dirt to prolong its life.
Aug 20, 2012 | Motorola Mobility Motorla MOTXT912 DROID...
My One+ battery won't take charge anymore, only after 1 year and not much of use, any way to fix this?
was this battery ever left on the charger too long?
Once rechargeable batteries start to fail holding a charge they should be recycled and you'll have to buy new ones
Aug 09, 2011 | Ryobi (one +) 18v Drill And Saw Combo Kit
My razr will not hold a charge. Changed the battery,helped a little while but now it is doing the same thing.Dies constantly.
The charger is bad, not supplying enough current to bring the battery to full charge.
Or your replacement battery is bad.
There is a small possibility that the charging circuit inside the phone is bad.
So, before you spend money on a charger, see if someone will lend you their charger and let the phone charge over night. If it holds a charge then you know the charger is bad.
Good Luck!
Jan 03, 2010 | Motorola Mobility RAZR V3
Razr not charging -
New charger is needed - Razors are VERY particular about their type of charge - If it is a bad charger - You will see the battery indicator flashing red - and it will be empty - this is the phone saying pretty much that it cannot use this charger -
I have had ALOT of problems with razors and returned chargers - Try to scoop up an original - or take it to a location and test the charger first -
You can try to remove the battery and then put it back in - then try to charger it but i doubt that will work -
Get a new charger - TEST IT FIRST IN STORE!!!
Good Luck!
Jul 17, 2009 | Motorola Mobility RAZR V3
Razr V3 won't power up anymore
try a new battery and also clean the charging port if after the battery and still nothing then you need to take the phone and have it tested.
Sep 10, 2008 | Motorola Mobility RAZR V3
Motorola V3 RAZR won't charge!!!
hmm well i suppose u try with a new charger 1,, b4 you throw it away
Feb 05, 2008 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3m Cellular Phone Logo
144 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
