Will Harman Kardan speakers work with a Dell? If so, how?
Will Harman Kardan speakers work with a Dell computer? The computer doesn't recognize the speakers as being plugged in.
  • Light Yagami
    Light Yagami Jun 04, 2010
    what model is the dell computer? if you are plugging the speakers into the sound out sound jack, the speakers will work. what you need is to make sure you have the correct sound drivers for your PC installed. if you dont have a sound icon on your task tray, it does you no good to plug in some speakers. also have you tested other speakers? and have you changed the setting in the sound panels? what OS are you using? you dont need drivers for external speakers. and it wont recognize external speakers or make a bing noise with them being plugged in as well. if you have sound now, but you plug in your speakers and the sound output does not change to the speakers, then your settings for sound are fuzzed up. or you could have a bad set of harman kardans. how old are they?
  • 415 Answers
If it is through a headphone jack the computer will never recognize the speakers you'll have to right click on the speaker icon on your tool bar lower right corner and select adjust audio properties the click advance and select desktop speakers,
Posted on Jul 27, 2010
How do I access/clean keyboard toshiba p55t-a5116 with harman kardan
You can remove the keyboard and then blow everything clean with canned air. Go here for help - http://cpufandeal.com/toshiba-satellite-p55t-a5116-laptop-cpu-cooling-fan.html
Dec 30, 2014 | Toshiba Satellite Computers & Internet
Will Harman Kardon HK 206 speakers work with Windows 8
I just purchased a Dell XPS 8500 with Windows 8 and decided to keep using my old Harmon Kardon HK 206 speakers because I'm quite satisfied with these speakers. When I hooked them to my new PC, Windows 8 recognized them right away. The speakers work great on my new PC. Try going to the Control Panel and see if your speakers were recognized. (On my PC they're referred to as "Speakers (Realtek High Definition Audio). That's due to the default drivers in Windows 8. As long as you see speakers in the control panel, you should be OK. In that case you should check your connections. If you don't see speakers in the control panel, go back one screen and select add a device and let Windows 8 scan for any device that it hadn't recognized before.
Jan 23, 2013 | Harman Kardon HK206 Computer Speakers
Harman kardan 7000
Check all speaker connections for shorts, and make sure all cables are secure, no change! There may be a problem in the audio output stage, at this point you will need somebody to check out the unit because the problem can be hard to locate.
Apr 05, 2012 | Harman Kardon AVR 7000
Will Harman Kardon HK 206 speakers work with Dell Inspiration 560 with Windows 7 and if so how do you hook them up and install
since they are stereo they should have not issue. just connect the 3.5mm jack to your output port typically the green audio jack.
Jun 27, 2011 | Harman Kardon HK206 Computer Speakers
I NEED THIS PART FOR MY HARMAN KARDAN SOUND STICK II SPEAKER 700-0036-001 Power supply adapter AND 500-0180-001 Power cord CAN YOU HELP ME?
Normally you can buy a universal power adapter that let you set the proper voltage, plug size and polarity, go and buy one and try or take the part to the shop to see if fits before buying, also you can go to a electronics repair shop so they can make you one, normally power adapter for this hardware is made in china and very difficult to find a proper replacement original part
Apr 06, 2011 | Harman Kardon Audio Players & Recorders
I have a set of Harmon Kardan Soundsticks II needing a simple but confounding repair. One of the small pins (#5 I would say as you go over and around the arc of pins) of the satellite speaker connectors...
MiniDIN-4 Connector Pinout. Looking at the male connector from the rear (solder side) Pin 1 = White Pin 2 = Bare Wire Pin 3 = Light Grey Pin 4 = Dark Grey Outer case Ground = Clear
Jan 02, 2011 | Harman Kardon SoundSticks II Computer...
No sound
You can find the drivers on the Dell website under the support section. You will need your computer model or your Dell service tag. Hope this helps & please remember to rate my answer. Thanks.
Jan 09, 2009 | Harman Kardon HK695 Computer Speakers
Harman kardon
Orastie
Wow, general problem here, but the most near your problem could be, power failure, or the Power adapter is bad, or a energy failure at home, time to buy a new adapter.
Carl
Dec 29, 2007 | Harman Kardon Harmon Kardon SoundStick II...
HK206 SPEAKERS WITH USB PLUG
have you plugged anything else in to make sure the usb port is working? does the computer recognize the usb speakers when you plug the usb plug into the computer? do the speakers work on another computer? if you wiggle the usb wires around does it make a sound through the speakers? eliminate these questions so that we can move on to isolating the issue.
Oct 13, 2007 | Harman Kardon HK206 Computer Speakers
82 people viewed this question
 Grubhead
Grubhead
