Question about Daewoo DTQ-25S3FC 25" TV
No matter what i do with the inputs, the only thing my tv will display is a sort of olive colored background with a widely spaced grid of white lines. can you help?
  • nelsonnasmil Jun 04, 2010
    i don't know how to make the repairs suggested.
    President:
  • 1,099 Answers
This can be solve in the following,
CAUTION: To prevent damage to the CRT phosphors, immediately turn down the brightness so the line is just barely visible. If the user controls do not have enough range, you will have to locate and adjust the master brightness or screen/G2 pots.
Several grids of line means that you have lost vertical deflection. High voltage is most likely fine since there is something on the screen.
This could be due to:
Dirty service switch contacts. There is often a small switch located inside on the main board or perhaps accessible from the back. This is used during setup to set the color background levels. (On some sets, this is located on the CRT neck board and may be a jumper plug or other means of selecting service mode - not an actual switch.)
When moved to the 'service' position, it kills vertical deflection and video to the CRT. If the switch somehow changed position or got dirty or corroded contacts, you will have this symptom. Flip the switch back and forth a couple of times. If there is some change, then replace, clean, resolder, or even bypass it as appropriate.
Bad connection to deflection yoke or other parts in vertical output circuit. Bad connections are common in TVs and monitors. Check around the pins of large components like transformers, power transistors and resistors, or connectors for hairline cracks in the solder. Reseat internal connectors. Check particularly around the connector to the deflection yoke on the CRT.
Bad vertical deflection IC or transistor. You will probably need the service manual for this and the following. However, if the vertical deflection is done with an IC, the ECG Semiconductor Master Substitution guide may have its pinout which may be enough to test it with a scope.
Other bad parts in vertical deflection circuit though there are not that many parts that would kill the deflection entirely.
Loss of power to vertical deflection circuits. Check for blown fusable resistors/fuses and bad connections.
Loss of vertical oscillator or vertical drive signals.
The most likely possibilities are in the deflection output stage or bad connections to the yoke.
Thanks for asking
Posted on Jun 04, 2010
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. From what you have described it seems to be a horizontal/vertical circuit issue. You’ll need to open the back of the unit and check/test HOT (horizontal output transformer) and flyback, replace the part that has gone bad. This is only recommended if you have electrical expertise. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
    thanks for the response- i don't have enough expertise to do what you're describing without more instructions- does this mean i have to take it in to a shop or would more instructions help me figure out how to do this repair?
    thanks
    nate
  • Rylee Smith
    Rylee Smith Jun 04, 2010
    As I said repair requires some expertise and you might have to solder/re-solder components, if you dont know how to do it then its better to take help from a professional. Please do accept the solution if the issue is resolved or post a comment for further assistance.
    Thanks
    Rylee
How to turn off backlight on iphone 4
There is no separate "back light" setting like there used to be on some earlier phones.
In the Settings app of your iPhone, there is a section called "Display & Brightness". You can use that to make your phone's display brighter or dimmer, but as you have probably discovered, it dims or brightens both the foreground and the background elements together as one.
You can turn it all the way down, which is very dim and hard to see in normal indoor light conditions, but may be preferable in extreme low light conditions like in a nightclub setting, or in complete darkness.
Why isn't there a separate back light setting?
To fully answer this, I would probably have get into more than you ever wanted to know about displays.
First, there is really no background or foreground on today's smart phone displays. The foreground elements and background elements we see on the iPhone are really a graphic illusion created by lighting individual pixels with different colors. All of these pixels are on the same plane, so nothing is really behind or in front of anything else. It's just artistically drawn to look that way.
Brightness is simply an "intensity" setting applied uniformly across all of the underlying individual pixels within the display matrix, and has no relationship to color. For clarity, let's look at the difference between lightness in colors, versus display brightness:
COLOR LIGHTNESS is a matter of how much WHITE (all the RGB colors summed, for example) is present in a given color. This has nothing to do with display brightness.
DISPLAY BRIGHTNESS is a matter of how much LIGHT INTENSITY is applied uniformly across all pixels in the display matrix.
At zero display brightness, you would not see white any better than black, blue, green, red or any other color. You wouldn't see anything.
Why did you expect to be able to control the back light?
Prior to the smartphone era, the displays on early cell phones and pagers (and lots of other devices that had displays) had a lighted background that contrasted with dark foreground elements.
The background intensity was a separate setting on those devices, but that's because the background was the only thing that had intensity. The foreground elements were solid black LCD (liquid crystal display) segments that were used to form characters and very simple graphics and lines.
Everything we see on today's smartphone displays is dynamically drawn by lighting different pixels with different colors at different times. Individual pixels on a Retina display are nearly microscopic in size--they cannot be separately discerned by the eye.
Imagine a matrix of microscopic light bulbs, each of which can separately change to any of millions of colors and levels of brightness at any time, on command. Just imagine the sheer number and complexity of possible commands to control a Retina display!
Even if Apple wanted to provide a new feature that enabled us to separately control the perceived "back light", it would only be an illusion as well.
Such a feature would require some sort of complex algorithm to determine which pixels are involved in what you perceive as the "foreground" elements at any given time, so it could add intensity only to those pixels considered to be "background" at any given time.
Since "foreground" and "background" elements drastically change shape (and location) at any time, such a feature would be pretty daunting to implement.
You might be better off using a pure black graphic as your background image if your goal is to have more contrast to make the app icons stand out.
Cheers,
-=Cameron
Aug 12, 2014 | Apple iPhone4 4G iPhone 4
Mitsubishi Rear Projection WS
5ebe434.jpg A projection television and a convergence control method thereof are provided. The projection television, which magnifies images displayed on cathode ray tubes (CRTs) for the colors red, green, and blue using lenses and projects the magnified images onto a screen, includes a convergence control apparatus capable of adjusting the convergence while an input image signal is displayed, the convergence control apparatus including: an image signal decoder which processes the input image signal to generate a data signal, horizontal and vertical synchronous signals, and a start signal indicating the start of either the horizontal or vertical synchronous signal; a convergence control unit which normally projects an image signal output from the image signal decoder onto the screen and performs convergence control using a predetermined region of the screen displaced from a visible region of the screen according to a convergence control command; and a main microcomputer which inputs the convergence control command to the convergence control unit when the start signal is input from the image signal decoder, stops the convergence control when a completion signal is input from the convergence control unit, and performs a control operation to continuously display the image signal during the convergence control.
the pro in convergence control circuit only..so better change tat..
Sep 21, 2008 | Mitsubishi WS-65809 65" Rear Projection...
My phillips 2006 hd tv has a black line across the screen with a snowy freeze
If you have parallel horizontal black lines on a white background, you can see the separation between the lines when it is viewed at close range (Figure 1). As you view the lines from further and further away,the image gets smaller, you eventually get to the point where you can no longer see the separation between the lines, and it looks like one line. Losing the ability to see separation in the lines is exactly what happens when you sit too far back from an HDTV set. If we apply the same principle to an HDTV, a 1080p resolution HDTV has to fit 1920 vertical and 1080 and horizontal black lines separated by the white space on the screen, (that is the pixel grid of a 1080p HDTV display). Furthermore the spaces between each cell of the grid need to be very small in relation to the area each cell occupies, or you will get a screen door type effect. A bigger HDTV can increase the size of the cells and the separation between the cells, so everything doesn't run together when you sit further back.
Performance chip
May 22, 2012 | Philips Televison & Video
How to reset a samsung pl201?
.adslot-overlay {position: absolute; font-family: arial, sans-serif; background-color: rgba(0,0,0,0.65); border: 2px solid rgba(0,0,0,0.65); color: white !important; margin: 0; z-index: 2147483647; text-decoration: none; box-sizing: border-box; text-align: left;}.adslot-overlay-iframed {top: 0; left: 0; right: 0; bottom: 0;}.slotname {position: absolute; top: 0; left: 0; right: 0; font-size: 13px; font-weight: bold; padding: 3px 0 3px 6px; vertical-align: middle; background-color: rgba(0,0,0,0.45); text-overflow: ellipsis; white-space: nowrap; overflow: hidden;}.slotname span {text-align: left; text-decoration: none; text-transform: capitalize;}.revenue {position: absolute; bottom: 0; left: 0; right: 0; font-size: 11px; padding: 3px 0 3px 6px; vertial-align: middle; text-align: left; background-color: rgba(0,0,0,0.45); font-weight: bold; text-overflow: ellipsis; overflow: hidden; white-space: nowrap;}.revenue .name {color: #ccc;}.revenue .horizontal .metric {display: inline-block; padding-right: 1.5em;}.revenue .horizontal .name {padding-right: 0.5em;}.revenue .vertical .metric {display: block; line-height: 1.5em; margin-bottom: 0.5em;}.revenue .vertical .name, .revenue .vertical .value {display: block;}.revenue .square .metric, .revenue .button .metric {display: table-row;}.revenue .square .metric {line-height: 1.5em;}.revenue .square .name, .revenue .square .value, .revenue .button .value {display: table-cell;}.revenue .square .name {padding-right: 1.5em;}.revenue .button .name {display: block; margin-right: 0.5em; width: 1em; overflow: hidden; text-overflow: clip;}.revenue .button .name:first-letter {margin-right: 1.5em;}a.adslot-overlay:hover {border: 2px solid rgba(58,106,173,0.9);}a.adslot-overlay:hover .slotname {border-bottom: 1px solid rgba(81,132,210,0.9); background-color: rgba(58,106,173,0.9);}a.adslot-overlay:hover .revenue {border-top: 1px solid rgba(81,132,210,0.9); background-color: rgba(58,106,173,0.9);}div.adslot-overlay:hover {cursor: not-allowed; border: 2px solid rgba(64,64,64,0.9);}div.adslot-overlay:hover .slotname {border-bottom: 1px solid rgba(128,128,128,0.9); background-color: rgba(64,64,64,0.9);}div.adslot-overlay:hover .revenue {border-top: 1px solid rgba(128,128,128,0.9); background-color: rgba(64,64,64,0.9);}6_4_2012_11_48_48_am.jpgTurn The inner bit towards you until it goes in fully then turn it on and it might work. Thats what I did and it worked
Feb 12, 2012 | Office Equipment & Supplies
How i adjust horizontal size and vertical size
To answer your concern, all you have to do is to change the setting of your aspect ratio on your TV.
Here is my suggested way to procede:
1. Apply 1080i signal, which should produce an oversized HD image on ColorStream1or 2.
2. Select an HD channel that is broadcasting standard 4:3 image, not wide screen.
3. Switch to the Service Mode ( Please refer to the above links). In the Service mode, press channel up/down to find the Adjustment parameters needed for the following steps.
4. Adjust HIT with volume up/down control for the image height to 22.5 inches.
6. Adjust WID for image width of 30 inches, (22.5*4/3)
7. Adjust HPOS to center the image.
8. Adjust PARA and TRAP to minimize geometric distortion.
9. Switch into Convergence mode and Adjust VLIN to get equally spaced horizontal grid lines.
10. Measure the length of the central grid lines and note the number of horizontal and vertical grid lines. This information is used to create an overlay grid.
11. Create the overlay grid on 40x25 x0.003 inch clear Acetate sheet, which you can get at the Art Supply store for under $2. Draw the grid with a fine line erasable pen. Draw vertical and horizontal lines through the center of the sheet so that the lengths are the same as the central grid lines. Now draw the grid so that it has the same number of lines as the convergence grid but are equally spaced, with the outer ones at the ends of the central lines.
12. Cut off about 1/4 inch from the right side of the sheet so that the sheet can lay flat against the screen, which is slightly less than 40 inches.
13. Put a reference mark on the TV frame 2.5 inches down from the upper left side of the screen.
14. Place the overlay on the screen so that the upper edge lines up with the reference mark. The overlay sticks by electrostatic attraction.
15. Use convergence controls to remove grid distortion and converge grid colors. Refer to the Anamorphic link for details.
16. Enjoy 1080i.
Other Comments:
I didn't realize I could create the overlay grid before placing the Acetate sheet on the TV screen, until I finished drawing the grid with the sheet placed on the screen. I added grid lines as called for in the procedure. I'm sure this method took much longer no only to draw the lines but some of them were difficult to see.
Part way through the convergence procedure, I became concerned that the image width was off since I did my screen adjustment with wide screen image. Thus, I decided to repeat that step with a 4:3 screen.
I confirmed the need to press 7 often to save results since after I adjusted one grid color without it, I accidentally hit a key that switched me out of convergence mode and when I switched back, all settings were gone.
Another mistake I made was not realizing that the cursor color determines which grid gets moved.
May 13, 2011 | Toshiba 32AV500U 32 in. LCD HDTV
Sanyo lcd-32k40 features
  • Model: Sanyo 32K40 Multi System LCD TV
  • World-Wide NTSC/PAL/SECAM Color System - Watch any video signal on this TV!!
  • World-Wide NTSC M, PAL BG, PAL I, Secam BG, DK/ PAL DK TV tuners
  • 32 inch LCD TV with 3 HDMI inputs and PC input
  • USB input for direct media playback
  • 45,000:1 Dynamic Contrast: While viewing either very bright or very dark scenes, it can be difficult to distinguish main images which blend into the background.
  • Dynamic Contrast dramatically mitigates this problem by adjusting the backlight intensity, providing up to a 4X improvement in contrast.
  • 6.5ms Response Time
  • Widescreen 16 X 9 Format
  • World-wide Dual Voltage 110-240 volts 50-60 hertz
  • HDTV monitor (HDTV tuner required for HD reception)
  • This is a multisystem TV. All Multi System TVs in the market do not have a digital TV tuner: What does this mean?
  • To watch digital channels (ATSC Broadcasting in US and DVBT broadcasting overseas) you need a digital source/tuner like a cable box, digital tuner, satellite service, etc.
  • To get the best quality video on this TV you need a source that has a digital connection like HDMI or component.
  • Wide Screen Mode allows you to watch conventional 4:3 aspect ratio broadcasts in wide screen (16:9) mode.
  • Steady Sound® equalizes volume levels so there is consistent output between programs and commercials.
  • Built-in hidden speakers includes 2 (5W x 2) speakers to deliver dynamic sound.
  • Component Video Input offers the best video quality for DVD (480p and 480i), and digital set-top box (1080p, 1080i, 720p, 480p and 480i) connections.
  • PC Input allows you to connect your PC and display the PC screen on your TV.
  • Surround Sound Audio Effect
Mar 04, 2011 | Sanyo 42 in. LCD TV
After the dvd plays for like 10-15 minutes(when dvd player warms up?) all the colors on the screen turn to black, yellow and purple for the rest of the movie. What's wrong?
I gotta know more clearly about your question, i am going to explain in 'Guide Solutions'
Guide 1: Is it the color just cover the main grid? (Color cover like blocking the others, such as watching 70s TV shows, the colors blocked in black and white.)
Source 1: Audio input problems, your dvd audio input linked with three different 'rops', they are appeared to be push by pressure.
Solution 1: Determine more spaces to them!
Guide 2: Is it the color cover the photon grid? (Color cover at all pictures, each of them doesn't stand the other colors instead of replaced by unique color)
Source 2: Undefined
Solution 2: The TV setting menu seems to b set by specific colors, change it on your own using remote. OR this is a specific part that the DVD need to show the color in unique color (only one)
(No problems, keep watching)!
Jan 22, 2011 | Panasonic Home Theater System System
White has turned pinkish
sounds like the linear adjustment is out of whack.....most projection type tvs, projection, lcd, plasma, have to be correctly aligned so that the color grids overlap each other to properly display the correct hue being created. you'd need the service code to re-adjust it, or have it serviced. also possible that one of the color grids is bad, but if you have all three (red,blue,green) colors showing on the entire screen area i would doubt it
Jul 24, 2009 | Vizio GV42L 42 in. LCD Television
Samsung LE32R87B
The fact that this is on all inputs suggests that teh screen is faulty, i would bring it back and get it replaced.
May 09, 2007 | Samsung LN-R409D 40 in. LCD Television
Daewoo DTQ-25S3FC 25" TV Logo
43 people viewed this question
Top Daewoo Televison & Video Experts
 Grubhead
Grubhead
Are you a Daewoo Televison and Video Expert? Answer questions, earn points and help others
