Question about Frigidaire FEB27S5A Electric Single Oven
Bought a Frigidaire Electric range Model # FEF366EMD and the terminal block has melted and shorted out, what now?
2 Suggested Answers
SOURCE: Require Electronic Oven Control Guide for a drop
the problem with the oven is that,when we start it to bake sumthing it turns of automatically after half and hour,and it doesnt bake anything...can you please help us with this problem...
Posted on Dec 21, 2009
While preheating my electric frigidaire smooth top oven, we heard a loud pop and saw a flash. The breaker had tripped. After resetting it, the clock and digital features still work, and so does the st
I appreciate your inquiry, Stephanie Givan!
From what you are describing it sounds like a possible short with your breaker box or issue with your terminal block within your Frigidaire range. I would recommend reaching out to a professional technician for a proper diagnosis to be completed. The technician will have the correct tools to check for any electrical issues within the range to make sure the correct component is being replaced. This will help avoid any unnecessary part purchases. -Matt
Nov 12, 2014 | Frigidaire Ovens
Why isnt anything digital working on my stove?
you need to check the main power terminal block and ensure there is proper power to the unit.if the power is correct at the terminal block then you will have to replace the main electronic control board
Oct 13, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Broiler will not shut off
no question you have a short in electrical . you do need a tec to ck this out . unless you have electrical expertise . it sounds like control panel or shorted( melted wiring ) mm
Jul 12, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
The terminal block that the power cord plugs into sparks
The part is called the terminal block and is part number 5304409888
It gets burned due to not being connected tight when the oven was installed or worked on last.
Replace the block and repair any burned wire ends. Make sure connections are tight and you will be good to go
May 07, 2010 | Frigidaire FEB27S5A Electric Single Oven
Terminal Block
terminal was loose started arcing like a welder causing heat to melt the block
Apr 09, 2010 | Ovens
I have a frigidaire Elite electric range.The clock/timer control board went blank after a power surge.I can only find a model # on a small sticker,but no one recognizes it.It is approx. 20 yrs old
Take off back pane AFTER unplugging unit. there should be a fusable link, it is usually a large red wire going to the relay block, it might even say on the wire "fusable link" if it folds or bends easily it is probably blown.
Sep 22, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
My oven does not heat up on bake or broil any ideas
check the terminal block, thats where the end of the power cord is attached to the range
Aug 05, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
F3 code and beeping
F3 - F4 Open oven temperature sensor (circuit) (over 2700 ohms) or, shorted oven temperature sensor. Could be a result of:
· contamination on terminals
· pinched wire in oven temperature sensor circuit
· cold solder joint on control. · Disconnect power to range and remove oven temperature sensor connector from control.
· Measure oven temperature sensor resistance at oven temperature sensor connector (take care not to damage terminals in block) - Should read 1100 ohms at room temperature (approx 72 degrees F).
· Measure each oven temperature sensor lead from connector block to ground. If shorted, look for pinched or cut wire in oven temperature sensor circuit.
· Check connector terminals - Look for deformed or corrosion on terminals. Repair or replace.
If all above is ok replace control.
Nov 17, 2007 | GE Profile Advantium SCB2001KSS Stainless...
Fridgidaire stove/ove
I have a Frigidaire electric oven model # PLES389ECE. It is two years old. It has maybe 50hrs of use. I had the oven blower motor go out. Then I had a circuit board malfunction.  The repairman discovered that one of the main terminal connections was loose and caused the terminal block to short. Could this have been the problem all along? Also, we are having a problem with the oven coming up to temp. According to the operating manual, set oven temp. lets say for example  350 degrees. Once the oven is preheated to 350 a beep sounds. With my oven the oven is about 60 degrees to low. You have to wait about 10 more minutes. Is this normal with this model? Has anyone else had problems with this model? I also heard that Frigidaire made a bad batch of ranges. Could this be one of them?
Thanks, Vincent
Oct 27, 2007 | Frigidaire FGB24S5A Gas Single Oven
Frigidaire FEB27S5A Electric Single Oven Logo
122 people viewed this question
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
ashburton
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
