Question about Philips GoGear HDD6330 MP3 Player
Fixed screen, battery went!
I replaced the screen of my hdd6320 according to your instructions (thank you very much!) - but I must have done something wrong. Now it won't hold a charge. The battery icon changes erratically between the plug, the filling-up battery, and the battery with a lightning flash on it. I guess I've left a connection loose - before I take it apart again, could you give me a hint what to look for?
Thanks very much, Ben
  • spunto Apr 17, 2008
    The battery is connected (I thought of that one before I posted the message even!) so I guess I've clumsily damaged the circuit myself. Bugger.
    Thanks a lot for your help anyway.
  • 476 Answers
There is a single plug with 3 connections for the battery. It can be accessed simply by removeing the back cover. (Don't forget to remove the 2 screws either side of the usb/charging connector first)
If the battery is not connected, then re-connect it.
Unfortunately, the batteries rarely fail on this model. Usually, a charging fault is caused by a faulty charge circuit on the main board.
Posted on Apr 15, 2008
  • David Simpson Apr 20, 2008
    You're welcome.
    You probably didn't damage the board yourself, it's a known problem with the HDD63X0 range.
I have a mitsubishi wd 65738. My picture suddenly went dim. I can still see a picture but the room has to be very dark and its still hard to see. Do I just need to replace a bulb?
Hello
Its bulb has got traoubled or its control circuit has some faut with it. it is not a user serviceable item. Replacing bulb can be done by the user according to the instructions in its user manual. But trouble shooting its control section must be done be any experienced service technician. OK.
May 27, 2011 | Mitsubishi WD-65738 DLP TV
Both screens went blank can make a call but cant see what is on the screen battery is charged when i press a button i can hear it beep
The problem with your phone is just flex problem, the flex on the screen of your phone is weak or worn out, this is a common problem among slide or flip phone.
What you need to do is to replace the flex on the screen of your phone, you can get this done by going to any local phone repairer within your vicinity to help get it fix or replace.
Once the flex is replace, your phone display problem is solve and the screen will start displaying.
Take care.
Aug 05, 2010 | Motorola Mobility RAZR V3
94 honda accord ''D4'' gear shift shift selector blinks
Theres a transmission cooling sensor and somtimes the wire comes loose from other repairs being done around it. or its just out. its on the left side sitting on the tranny. THATS WHY your d4 light is blinking
Jul 06, 2009 | 1994 Honda Accord
Hello experts. I have the following problem with my Accord 2003DX. It seems that it has to do with the radio or the computer. When the car is not used, the screen of the radio flashes, but not always, and...
There was a recall for the 03-04 Accord radio. It had faulty circuitry that caused the screen to go dim. Check with Honda to see if they'll still honor the recall. If not I can fix it, drop me a note at www.autoclockrepair.com
Jun 28, 2009 | 2003 Honda Accord
Battery light comes
hey
is your battery leads loose?? iv a feeling the alternator you got might be slightly defective!! if its brand new give it another month other wise bring it back!!
Damien
Aug 21, 2008 | 1991 Honda Accord
Phillips HDD6320/05
On the product CD, there are two parts to the Media Player installation. Try re-installing the sotfware on the CD.
May 24, 2008 | Audio Players & Recorders
Actually a HDD6320
The HDD6320 is not compatible with Windows Media Player 11.
You will need to uninstall Media Player 11, to roll back to version 10.
Also, it is not compatible with Windows Vista.
If you haven't already, install the Philips Device Manager from the product CD.
Connect the HDD6320 to the mains and PC.
Select the repair/restore option and follow the on-screen prompts.
If the HDD6320 is still not recognised, let me know if the player shows the connection icon on-screen, and I'll try to help further.
May 06, 2008 | Philips GoGear HDD6330 MP3 Player
I dropped my HDD6320 philips mp3 player and it registered as having no songs on it, but when I synchronized it with my pc they are all on it. I want to clean it completely and reinstall all the music. ...
Sounds like the file list is corrupt on the player. This means that the player ignores the files, because it doesn't scan the drive on start up, it only reads the file list.
Formatting the HDD6320 is straight forward:
Install and run the Philips Device Manager software from the product CD. The software is only compatible with Windows XP.
Connect the player, and wait for Device Manager to recognise it.
Select the Repair / Restore option and follow the on-screen prompts.
This will format the player and re-load the system files.
If you don't have the CD, it can be downloaded here:
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?scy=GB&slg=ENG&cat=MP3_PLAYERS_CA&sct=HDD_AUDIO_JUKEBOX_SU&session=20080411075449_82.5.155.87&grp=PORTABLE_ENTERTAINMENT_GR&ctn=HDD6320/05&mid=Link_Software&hlt=Link_Software
Apr 11, 2008 | Audio Players & Recorders
Cracked screen
Try bidding for a faulty gogear on ebay. Just make sure that it has a good screen.
Information on how to do the exchange I have posted earlier on this site, Good luck
Jan 05, 2008 | Philips GoGear HDD6330 MP3 Player
Philips hdd6320 30gb
Replace or get an extremely expensive repair service.
Jun 27, 2007 | Philips HDD1630 MP3 Player
Philips GoGear HDD6330 MP3 Player Logo
121 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
