Is leaking water at the back and running in the floor the hoses are tight drain pipe is in right
Here's what I've seen. Water will be full, machine goes to spin/drain and expects the water to be pumped out as predicted. If pump is clogged, the pump cannnot pump out water quickly enough and the spinning causes the water to spill over the back of the tub, between the tub and balance ring. The balance ring is never sealed tightly to the tub so water will get through. Fill the basket with water, extra high, hold lid switch down, and see if it drains out fast enough so water doesn't spin out. If this is the case, pull pump, dislodge debris.
