Question about Whirlpool Ovens
Rbd275pdb12 - trouble codes f2 e6 - what do these codes mean?
  • 84 Answers
E6 F2 on a whirlpool double oven translates to "Cancel Key drive open". We see this frequently and is always a problem with the control board. At www.fixyourboard.com it can be repaired quickly and reliably at a fracton the cost of a new board.
Posted on Nov 01, 2010
Tip
How to Repair Whirlpool E6 F2 Oven Code
Your Whirlpool Built-in Oven has failed and the electronic control is no-longer-available. You can have this control board rebuilt!
The common symptom is a display that intermittently goes blank, accompanied by an error code E6-F2. This is caused by a failure in the electronic control board (EOC).
The courteous technicians at www.fixyourboard.com in Austin Texas can rebuild this for you!
Control Board Part Numbers: 8302967, 4451856, 4451991, 4452890, 4452898, 4453664, 4453664.
Applicable Models: GBD277PDB6 GBD277PDB7 GBD277PDB8 GBD277PDQ6 GBD277PDQ7 GBD277PDQ8 GBD277PDS6 GBD277PDS7 GBD277PDS8 GBD277PDT6 GBD277PDT7 GBD277PDT8 GBD307PDB6 GBD307PDB7 GBD307PDB8 GBD307PDQ6 GBD307PDQ7 GBD307PDQ8 GBD307PDS6 GBD307PDS7 GBD307PDS8 GBD307PDT6 GBD307PDT7 GBD307PDT8 RBD245PDB11 RBD245PDB12 RBD245PDB13 RBD245PDQ11 RBD245PDQ12 RBD245PDQ13 RBD245PDS11 RBD245PDS12 RBD245PDS13 RBD245PDT11 RBD245PDT12 RBD245PDT13 RBD275PDB11 RBD275PDB12 RBD275PDB13 RBD275PDQ11 RBD275PDQ12 RBD275PDQ13 RBD275PDS11 RBD275PDS12 RBD275PDS13 RBD275PDT11 RBD275PDT12 RBD275PDT13 RBD276PDB11 RBD276PDB12 RBD276PDB13 RBD276PDQ11 RBD276PDQ12 RBD276PDQ13 RBD276PDS11 RBD276PDS12 RBD276PDS13 RBD276PDT11 RBD276PDT12 RBD276PDT13 RBD305PDB11 RBD305PDB12 RBD305PDB13 RBD305PDQ11 RBD305PDQ12 RBD305PDQ13 RBD305PDS11 RBD305PDS12 RBD305PDS13 RBD305PDT11 RBD305PDT12 RBD305PDT13 RBD306PDB11 RBD306PDB12 RBD306PDB13 RBD306PDQ11 RBD306PDQ12 RBD306PDQ13 RBD306PDS11 RBD306PDS12 RBD306PDS13 RBD306PDT11 RBD306PDT12 RBD306PDT13
on Aug 17, 2015 | Ovens
I keep getting the following error message: E6 F2 - what does this mean?
If you have a Whirlpool oven, the F2 E6 error means that the Cancel key line is open. You will need to replace the keypad or the keypad and controller board (if a single assembly) if the keypad doesn't respond to a press of the Cancel Key.
I hope this helps.
Dec 12, 2011 | Whirlpool Ovens
Displaying E6 & F2 code
F2/E6 fault code implies a Cancel key drive line open. This means the key pad ribbon connector could be loose or dirty where it connects to the oven control board or a faulty oven control board.
Press Cancel. If the error code returns after 60 seconds, replace the key pad. If it continues to display F2/E6 after replacing the key pad, replace the oven control board. The parts can be ordered from Sears PartsDirect
NOTE: Disconnect the power supply from the oven before servicing.
Check additional details in THIS IMAGE LINK.
Hope this helps; also keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using Fixya, and have a nice day.
Nov 13, 2011 | Ovens
Our oven read a problem # E6 F2 what that's mean?
The E6-F2 error code means that the control board thinks there is a problem with the cancel button on the touch pad. Sometimes its due to a loose connection from the ribbon cable on the touch pad. You can push cancel and clear it and if within 5 or under the error code returns the touchpad needs to be replaced. But first check/have the connection checked to make sure its tight. The way modern things work though is grand and Whirlpool say if after replacing touchpad the error code returns once again the clock/control board is what needs to be replaced.
Gene
Aug 11, 2011 | Whirlpool RBD305PD Electric Double Oven
I have a Whirlpool model RBD275PDB12. I am
Hello,the error E6 and F2 you are receiving could be describe as "Cancel Key line open".Follow the following steps
1. Check keypad connector for firm connection(Keypad connection to control board).
2. Press CANCEL if error code returns after 60 seconds,replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replay control board (also called ERC or clock).
TThanks
Jun 03, 2010 | Whirlpool RBD275PD Electric Double Oven
On rbd275pdb12 what is the code E6 F2 means
HI, this is referring to the cancel key on your key pad. It is stuck open. follow the procedure below.
1. Check keypad connector for firm connection (keypad connects to control board).
2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock).
Oct 27, 2009 | Whirlpool RBD305PD Electric Double Oven
My whirlpool oven is displaying E6 and F2. It
Your cancel key is defective at this point. follow these steps below?
Aug 08, 2009 | Whirlpool RBS305PDS Electric Single Oven
Ovens Logo
147 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
ashburton
Sal De
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
