Question about Garden
My briggs engine is misfiring .popping. new engine,old carb.Recently replaced head and valve train due to a valve seat that failed.Do you think a carb rebuild or replacement will fix /model 28N707 1990 vintage.
  • 177 Answers
carb rebuild
Posted on Jun 07, 2010
What did i miss
Valves have to be seated by lapping. If you skipped this then the valve seat is not correct.
Aug 11, 2014 | Poulan Pro Yard Tractor 2006 and Newer...
My 19hp engine is flooding out the motor. if i take the bottom line off the carb it will run for a minute or more and then die. with the line on it floods immediately
Sounds loike the float is either stuck open or there is dirt in the carb. You might want to take the carb off, remove the float bowl, and inspect the float and needle valve. Spray the carb with carb cleaner, especially where the needle valve seats and all of the passeges inside. I would suggest getting new gaskets because the old ones usually break when they are removed. I hope this helps, Good luck.
Jun 14, 2014 | Briggs & Stratton Briggs Stratton...
Cub cudet 31p7770299e1 briggs stratton engine
check and see if intake valve seat is loose as motor gets hotter condition worsens
Apr 23, 2013 | Cub Cadet Garden
17.5hp OHV Briggs & Stratton w/ Nikki Carb sputters & backfires thru carb & muffler
Hi, run a number drill through the main jet. Even though you have carby cleaned it a thin layer of residue will remain on the walls of the jet. The problem you have is a lean misfire. Regards Phil.
Jun 11, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Flymo 46s won't start. Starts to fire when turned
Possible blocked air filter, try as a test running the engine with filter removed, if ok replace with new filter.
May 02, 2012 | Briggs & Stratton Garden
Generator is leaking gasoline out through the carburator when not running. Also, fuel shutoff valve at bottom of gas tank will not shut off completely. What are probable causes and price to fix ??
Most often fuel leaking out the carb is caused by a needle and seat problem in the carburetor / the float level shaft screw may have come loose due to the vibration of the engine ,this will cause a leak issue with the needle and seat as well. To complete the repair the carb will have to be removed and cleaned. Replace the needle and seat if necessary an then replace the carb.
May 30, 2011 | Coleman Powermate Powermate 5000W...
Replace valve guide seals toro zero turn
i don't think those are replacable i may be wrong but i have never replaced valve guides in a small engine about the only thing that can be done is grounding the valve seats and lap the valves into the new seats..good luck
Mar 08, 2010 | Garden
84 s15 2.8l misfire, popping carb, and gas and coolant in oil
Wow, sounds like head gasket &/or timing problem. First thing you need to do is a pressure test on cooling system to see if head gasket gone, then I'd do a compression test as well. Have you pulled any spark plugs to see what they look like?
Aug 03, 2009 | 1985 Chevrolet S-10
I have gas going into my oil. 17.5 Briggs solenoid on carb bowl
The problem is the float needle and seat are leaking. It is not shutting off the gas when the bowl is full. The bowl fills up, then runs down the intake through the intake valve into cylinder, past the rings into the crankcase. Fairly common problem. Just replacing the rubber tipped needle probably will not stop the leak. The pressed-in brass seat needs to be pulled out and a new one pressed in also. Possibly there is some trash or rust in the carb that has gotten between the needle and seat, but in my experience, it usually takes replacing both to fix.
Jun 25, 2009 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Have a 20 HP twin cylinder briggs engine on Yard Machine mower.
Sounds like it might be the air breather filter, remove it and see if it works
May 16, 2009 | Craftsman 20 hp 42 in. Deck Yard Tractor
Garden Logo
452 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
