Question about NetGear : WG111 54 Mbps Wireless USB 2.0 Adapter, RETAIL (DSNGWG111)
Signal comes and goes ,internet explorer cannot open anything
Signal strength says good then goes red
    Guru:
  • 868 Answers
If it conencts but gets disconnected as mentioned it turns red possible that something is interfering with the network signal from your system to the router...... try checking for applications programs that can casue your wireless to fail from conneting, check if you have network magic on the computer uninstall it it can cuase network conflict and failures to conenct wirelessly or if your laptop is a Lenovo and if it has readycom 4.0 or readycom 5.0 uninstall it as well.
Also have you tried reinstalling the drivers for your wireless card in the laptop possible that the drivers installed is incorrect or corrupt, you can download drivers for your systme possbily from your OEM Original Equipment Manufacturer ^_^
Posted on Jun 04, 2010
My hp mini 1000 will not open internet explorer
Go to control panel then click on internet options after the internet options window opens click on the advance tab then look at the bottom you will see reset. Click on reset then try to launch the IE again.
Sep 25, 2012 | HP Mini 1000 Netbook
How can i tell if my internet explorer signal level is high enough. do certain things i get a message that internet explorer cannot be displayed
Hi
quite often there is a internet icon down bottom right of screen sometimes a box which looks like a tv screen mine is just a series of thin bars showing me full signal
if you click on it and open the box if you can find it then click on the connection itself it should hopefully tell you the strength of your signal
also it may help if you open up your internet explorer page go up to the top of page and try to find safety and click delete browsing history
or tools
click on the tools and go down to internet options
go down to browsing history and delete it
this may help to get you back on the internet
Feb 25, 2011 | Computers & Internet
I have the belkin router in my home and one of my laptops are not picking up the signal for the router
Probably the Router signal strength is low.
You need to open the EWS page ( Router configuration page ) and increase the signal strength to 11 ( it must be Auto or 1,2,3, etc )
EWS Page ( Router page ) can be opened using the Router IP Address which may be 192.168.1.1 or if you know it. Open Internet Explorer and enter the ip address and hit enter ( without www or .com )
Under Wireless configuration or settings you will find the Channel Strength. You need to restart your Laptop to get connected again to the network after saving the settings are you will loose the internet connection.
Regards,
Shawn
Feb 01, 2011 | Acer Computers & Internet
RCA Thomson digital cable modem internet light is flashing and no connectivity. Is it the modem or the internet service? Comcast was less than helpful...
looking at the internal modem page.usually:192.168.100.1. on your browser.explorer works best for this look up. you dont need internet access for this. once inside you can look at signal strength coming from the street and signal going back. if its out of spec.then that needs to be corrected. Note :call your provider and ask for down/up stream
specifications. also weather or not your modem is ( EOL) End of life.
Good Luck.
Mar 27, 2010 | RCA Thomson Digital Cable Modem (DCM305R)
Internet access comes and goes
this is a simple problem with simple solutions. if your signal strength is low move router to an open location or wrap the antenna in foil. also try rebooting your router. also note that it is only logical for it to get weaker if you get further away from it. best of luck bud! hope this helps!
Feb 16, 2010 | Samsung N310-13GB Netbook
Internet Explorer cannot display the web page
There are many possibilities that you are unable to connect to internet.
Can you check your internet explorer is not in offline mode? in IE goto File->Work Offline must not be ticked.
Open command prompt, and type "ping yahoo.com" and press enter, you will see the % rate of dropping whether is connected to internet or not will tell too. Write me what do you see in the command prompt.
Note: It will be good if you can call me over the phone and explain in details to solve your problem quickly.
May 08, 2009 | Dell Microsoft Windows XP Home Edition
Internet explorer cannot be found...
Check if you maybe have some IP and DNS settings to your WL network adapter:
Control panel
Network connections
Right to your WL adapter and click Properties
On the end of the list in the middle you'll find:
Internet protocol (TCP/IP)
Double-click it and set IP and DNS to Automatically. . . .
(OK, and than, again OK).
Check Internet Explorer settings:
Control panel
Internet Options
Click on Security Tab
Set ALL zones to DEFAULT
Click Apply and OK
Regards.
Mar 28, 2009 | Toshiba Qosmio F15-AV201 PM-1.8 Ghz,...
Could be a vista compatibility problem.
check Linksys website for updated driver and or connection manager.
check that you still have permission in firewall.
remove the software of the usb wireless adapter,reboot ,then re install.
just a couple of thoughts
good luck
Terry
Mar 26, 2008 | Compaq Presario 5000 PC Desktop
Will not open internet web pages
Hi , chech you enthernet cable does it hook up push it and try to switch off and on again in order to gain to open sometimes it is very busy line us of now.
Mar 19, 2008 | Computers & Internet
Wireless internet
You could try to manually set your IP address in the TCP/IP, the gateway and your ISP DNS
Feb 09, 2008 | 2wire (1000-400108-001) Router
NetGear : WG111 54 Mbps Wireless USB 2.0 Adapter, RETAIL (DSNGWG111) Logo
191 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
