Question about Bissell 7901-P ProHeat Upright Vacuum
Bissell steam pro model 79019 gear for belt out of place
I have a bissell steam pro model 79019 that the gear for the belt came out and won't stay in now. would plumbers tape helpe keep it in place?
SOURCE: Bissell Pro Heat 2x steam cleaner, problems!
I took the side plastic protectors off because my brushes stopped working. I found one belt almost broken (held together by the fiber to the interior) and when I moved the brush rollers, I found mucho dog hair on the ends. Your rollers might be removed and see if you have the same problem. IT just takes two screws on each end to do this, so if your belts are good, take a look at each end where the metal post goes into it. I have two dogs and their hair is just everywhere!
Posted on Jun 25, 2008
  • 17 Answers
SOURCE: bissel pro heat carpet shampooer 1699
The following link is the owners manual. Hope it helps! Post back.
http://www.bissell.com/images/UserGuides/7901_207.pdf
Posted on Jun 27, 2008
  • 20 Answers
SOURCE: directions for pro heat steam cleaner
If you go to http://www.bissell.com/customer-support/ and type in the specific model number of your Bissell in the space headed by "Find Replacement Parts & Download User Guides", it will provide you with a list of documents for your model. This is presuming that your model is not too old.
Posted on Feb 27, 2010
Vac Belts
  • 701 Answers
SOURCE: i need instruction manuel for bissell pro heat
You can view the manual here:
Bissell Proheat Manual
Posted on Mar 02, 2010
Vac Belts
  • 701 Answers
SOURCE: Bissell pro heat steam carpet cleaner, not releasing water.
That means that you need to replace the pump belt. Here is the belt you need and a manual you can view:
Bissell 7901 Belt and Manual
Testimonial: "just what I was looking for thank you"
Bissell carpet cleaner belt fell off, how do I replace it
Which belt? There are 2 on a Pro Heat. The pump belt which is pretty straight forward to put on. If it's the brush belt you will probably have to take the brush off. Re-rail the belt and then put the brush back in the holder arms while keeping the belt in the groves. BUT if the belt came off in the first place it's probably shot. Before you go to the trouble, get a new belt.
Sep 25, 2014 | Bissell 1699 ProHeat Clear View Upright...
I need to change the belt on my Bissell Pro heat. I dont know how to get to it!
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
bncmdgh
May 19, 2010 | Bissell 1699 ProHeat Clear View Upright...
I bought a Bisell Pro-heat carpet shampooer and had the belt break after one use. Tried to buy replacement belts only to discover that store out of stock. Question: Is there such a thing as a "generic" or...
No unfortunately not. Some brands of vacuums and steam cleaners have similar belts that can be used on several different models, however this Bissell carpet cleaner has a very unique belt, that is really unlike any other belt on the market today.
I'm sorry to hear that your local store was out of stock on these. We do however have these belts in stock ready to ship today if you haven't already found them. We do offer free shipping & no tax (except VA). Here's a link to the brush belt for your Bissell:
http://www.govacuum.com/bissell-proheat-steam-cleaner-replacement-belt-part-0150621.html
Please feel free to add a comment if you'd like help installing the belt, I'd be more then happy to walk you through this.
If you found this helpful, it would be greatly appreciated if you rated the repair helpful, or left feedback.
Thanks so much,
Chris Jones
GoVacuum.com
Apr 23, 2010 | Bissell Carpet Cleaner Powerbrush Deep...
How do I change the belt on my Bissell Pro Heat
heatman101
twerw
Apr 16, 2010 | Bissell ProHeat Turbo Deep Cleaner Upright...
Mar 01, 2010 | Bissell 7901-1 ProHeat Scotchgard Upright...
Bissel pro heat cleaner won't expell water -- seems no suction
The reason that it won't expel water is because your pump belt is stretched and worn. You need to replace that belt, it is pretty easy. Here is the belt you need:
Bissell ProHeat Pump Belt
Jan 30, 2010 | Bissell ProHeat Turbo Deep Cleaner Upright...
All lines are clear and the darn thing still won't
The reason it won't dispense solution is because the pump belt is worn or stretched. You need to replace it. Here is a link to the belts you need and a manual you can view:
Bissell 1699 ProHeat Belts and Manual
Dec 10, 2009 | Bissell 1699 ProHeat Clear View Upright...
Need to replace a broken brush belt on Bissell Pro Heat Model # 88910-W
easy, unscrew the bottom plate, keep in mind that most bissell shampooers have one belt longer than the other based on the left vs right side
hope this helps
Sep 14, 2009 | Bissell 8910 ProHeat Clear View Upright...
How do you change the belt on my Bissell steam cleaner Model #1692
There are two belts. One is a geared drive belt that goes on the pump and the other is a flat belt that goes on the roller brush. The roller brush belt is the same as a regular vacuum. The geared pump belt is a pain in the **** and should be replaced by a vacuum repair tech. You have to disassemble the vacuum to get to it. It's really not worth the hassel when you can pay someone $10 to do it for you.
Sep 10, 2009 | Bissell 1697-7 Powersteamer Pro Deluxe...
Bissell 7901-P ProHeat Upright Vacuum Logo
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
