Question about GE J Series 18.2 cu. ft. Top Freezer No-Frost Refrigerator TBX18AABWW
GE TBX18SKE REFRIGERATOR IS AROUND 55F AND THE FREEZER IS AROUND 22F. I took the heating tube out and did a continuity test, tested good, visually it looks great. I cannot seem to locate the defrost timer. I put a new thermostat switch, the one that clips on the coils behind the freezer cover. I would just replace the heater and the defrost timer if I could just locate the darn thing, it doesn't seem to be behind the temp controls in the fridge either. Can anyone help?
  • GE Master
  • 43,501 Answers
As the weather is getting warmer for many people their freezerGE TBX18SKE REFRIGERATOR IS AROUND 55F AND THE - 2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Posted on Jun 03, 2010
I have a GE Profile refrige model PSS26PSTASS. The ice maker has been making ice okay, it's after it is in the bin it melts and then subsequently refreezes into large solid chunks of ice. I've changed the...
Ice Maker Is Frozen Up This ice maker repair is even easier. If your ice maker has frozen up, take the following steps to thaw it out:
1Unplug the refrigerator.Remove the ice bin from the refrigerator and remove any loose ice from the ice maker.
2Find the fill tube.This is awhite rubber-like hose that delivers water to the ice maker. Pull down the small metal clip off the housing that holds the fill tube (though not all ice makers have this clip).
3Warm the hoseand surrounding mechanism. To do this, you can train a hair dryer on the ice maker to melt any ice blocking the mechanism. But be very careful (sop up any dripping water with a rag) as electricity and water can present a serious risk of electrical shock. Also, be careful not to melt the plastic parts.
4If you don't want to use a hair dryer,you can soak the supply tubing with hot water, using a turkey baster and catching the overflow in the empty ice maker bin. In some cases, it may be easier to remove the ice maker than to thaw out the fill tube.
On heat release ice makers You will want to check the heating element within the ice maker for continuity and a visual inspection of the board and conductors for burns and seizing, chared marks.
How to Test the Ice Mold Heater There are two types of ice makers, those in which all of the parts can be individually replaced and those in which some of the parts are clustered together into a control module. To determine which model you have remove the outer face plate. If there is knob, pull it off first, then pry off the face plate with a small screwdriver. Modular units have holes in the module's face plate for test probes. If you see several holes, each marked with a letter, it is a modular unit. It is easier to work on this type of unit by first removing the entireicemakerfrom the freezer compartment. The unit is usually mounted to the freezer case by two or more screws. Remove the bottom screws first. While supporting the ice maker, remove the remaining top screws. Unplug the ice maker from the freezer cabinet if you have not already done so. Along the edge nearest the shutoff arm, a pin protrudes through the mounting plate . The arm pin has a spring under the mounting plate. Reduce the tension on the spring by moving the shutoff arm into the "on" position, down, against the ice maker.
Test the heater for resistance using amultitester. Set the multitester to the ohms setting X1. Touch one probe to each of the two terminals (or wires). The reading should be in the range of 60 to 90 ohms. If you get a significantly different reading, such as zero or infinity, then the mold heater is bad and needs to be replaced. Conduct this test with the refrigerator unplugged. Test the moldheaterfor resistance using amultitester. Set the multitester to the ohms setting X1. Place one probe into the hole labeled "H" and the other probe into the hole labeled "L". The multitester should read in the range of 60 to 90 ohms.
Also be sure to check and test water valve with a meter for continuity and voltage..( a full 120 and nothing less) And a visual inspection for any ice build up or blockage in tubing and flow line. Remember u may get a close circuit reading of continuity however it may still be bad in that it may remain constantly closed and water keeps flowing more than suppose to. Hence chunks of ice build up.
Feb 24, 2015 | GE Refrigerators
Ge profile bottom freezer model # PGSS5NFXA SS. Got up this morning and freezer thawing. pulleD back panel cleaned the condenser fins with compressed air. runs fun but can't get the temp to fall past
Hi and thanks for using fixya!
This could be any one of 3 problems on this french door GE refrigerator. So lets trouble shoot.
First let me say the most common problem (95% of the time) on this model refrigerator and other GE models like this one is caused by the main control board pt # WR55X10956. I'll leave a link below where you can purchase parts.
1st, (unplug unit) , pull the freezer door out and look on the back wall. (all cold air in fridge comes from the freezer behind the back wall.) Is there a snowy frosty ice build up on the back wall? If so, you have a defrost problem. In this case, remove the freezer drawers, take all food out and remove the back wall (usually 1/4 inch nut driver needed). Also look where the evaporator fan is (vents in middle-top) and you'll see a picture of flat-head screw driver. You'll need to insert screwdriver where it tells you to and pry off vent. Once you have back wall off you'll need to defrost any ice you see. After that you will notice a glass heating element at bottom with one wire connected on both sides. unplug those wires and test element for continuity. Around 0 is good. If you don't have continuity then the heating element is bad. pt# WR51X10094 Link to parts site below. Next, test the thermostat, round-cylinder thing, width of a quarter attached to the evaporator coils (usually at top right and has two wires connected to it, one yellow, one orange). You test this just like the heating element. No continuity means it's bad. pt# WR50X10069. If both test good (and most of the time they do) then you'll need to replace the control board listed above.
Here is link where you can purchase parts listed above. They have good shipping and good return policy.
Appliance Parts
Feb 03, 2015 | GE Refrigerators
My GE 2008 side by side , the freezer is working but the food storage is not help ?
one of 2 things can be wrong,#1) if theres a heavy frost buildup on the rear inside wall of the freezer compartment then its a defrost issue,which will block air flow to the refrigerator side,take off back panel and test defrost heater and thermostat both on evaporator coil for continuity,thermostat has to be below 32 degrees to test good,most of the time its the hearter on G.E.. #2)if no frost buildup,then check the damper vent door between the freezer and refrigerator compartments and make sure its not stuck or broken shut and can no longer open and close to keep temperatures in refrigerator cold
Sep 29, 2012 | GE GSL22JFR Side by Side Refrigerator
Freezer coil freez up
its most likely the defrost heating element as G.E. is notorious for a poor defrost heater,you need to remove the inside rear panel in the freezer and this element is located at the bottom of the evaporator core,you can test it with an ohmmeter,its in a glass tube and if bad will pull apart,be careful of broken glass tube,the new heater is a dual tube G.E.# WR51X10101,it uses 2 tubes side by side,it will fit like the original,the only thing you need to do is route the longer pink or blue power wire down the opposite side with the other power wire because there will be a jumper wire on one side of the new heating element,very rarely does the defrost terminator go bad,if it does,to test it it needs to be below 15 degrees to test good as this is a bi-metallic switch and closes below 15 degrees
Aug 26, 2012 | GE Refrigerators
Freezer not freezing
If freezer is icing up, you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
You can test defrost element with an ohm meter(located inside freezer coils-will have two wires going to a plug connection), if OK replace defrost timer (located in various places depending on make and model
Aug 14, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer is cold emnough, it's the refrigerator
Hi..
If your refrigerator is not cold enough you need to check this
  • Check the temperature setting
  • Assure that there is enough room for air flow in the refrigerator or freezer
  • Check for air flow restrictions in vents
  • Test the temperature control
  • Clean the condensor coils
  • Check the door seals
  • Test the door switch
  • Test defrost heater
  • Test defrost timer
  • Test evaporator fan
  • Check for a clogged drain tube
  • Check for refrigerant leak
Hope it may helpful for you!!!
Regards
PCmania
Jul 13, 2009 | GE GSH25JFR Side by Side Refrigerator
Ice build up bottom of freezer and water on floor GE Monogram
I had the same problem. The drain tube is located below the pan below the fins at the rear of your freezer. The drain tube has a trap (s-shaped curve) to prevent air flow out of the freezer. The problem is that water gets in this tube and freezes. I took the sheet metal cover off the back, got a turkey baster and flexible tube, and continuously flushed hot water (after the freezer had been turned off around an hour to thaw). Eventually the plug gave way.
Apr 09, 2009 | GE Monogram ZICS360NR Bottom Freezer...
Freezer on the ge refrig will not freeze
Dear Brendadurran,
please rate this solution if it meets ur need,else choose fixya.
please perform the following checks,
  • Unplug the freezer, wait two hours and plug it in. If you hear it running, a problem is causing the compressor to overheat
  • Test the evaporator fan
  • Test the defrost timer
  • Test the compressor relay
  • Test the overload protector
  • Test the compressor motor
  • hope this would help,please rate this solution if it meets ur needs,else choose fixya.Thank you.
    Dec 17, 2008 | GE Profile PSS26NGS Side by Side...
    Freezer and fridge defrosting.
    that is just one of the probable problem. you still need to check the other two.
    the defrost heater ( heating element).
    and the bimetal ( thermo disc).
    the heating element, you need to test the resistance. there should be a resistance lower than 100 ohms depending on its wattage and voltage.
    the thermodisc or bi-metal, you need to test this while it is frozen. there should be a continuity between the two wires while the unit is frozen. it will open up when it is thawed.
    tnx 4 using fixya,
    drcool
    Nov 30, 2008 | Whirlpool ER6AHKXPQ Top Freezer...
    Water issue in the GE Refrigerator.
    Put a hair dryer on the door for awhile. Mine freezes up
    Mar 31, 2008 | GE GSL25JFR Brushed Steel Side by Side...
    Refrigerators Logo
    222 people viewed this question
    Top Refrigerators Experts
    Sal DeAngelo
    dweatherby
