Question about Tappan TGFS26C Gas Kitchen Range
Oven/Broiler doesn't work. Stove top works
Oven/Broiler doesn't work. Stove top work. Tried cleaning inside and out, checked for kinks in the gas line and cord, can set oven temp and clicks on but no whoosh or flame. Worked fine then later the same day didn't work.
  • Tappan Master
  • 43,501 Answers
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
Oven Problems Replacing the Igniter http://www.fixya.com/support/r4572625-oven_problems_replacing_igniter
heatman101
Posted on Jun 07, 2010
Testimonial: "Thank you , this was very helpful. I thought that was the problem but didn't want to tear apart my stove before knowing for sure."
Model ew30gs65gsc. Why is broiler not igniting?
Electrolux Oven Broiler Not Working - Model E30DF74EPS ...
www.repairclinic.com/...Range-Stove-Oven/...-/Electrolux-Oven-broiler-...
Most Frequent Causes for Oven broiler not working. See All Range/Stove/Oven Parts for model E30DF74EPS. Cause 1 Temperature Control Thermostat.
Electrolux Oven Broiler Not Working - Model EW27EW65GS6
Electrolux oven broiler not working? Use our DIY troubleshooting & videos. Then, get the parts you need fast. Return any part for 365 days.
Oven Broiler Not Working - Repair Parts - RepairClinic.com
www.repairclinic.com/...Range-Stove-Oven/...---/Oven-broiler-not-worki...
Oven broiler not working? Use our DIY troubleshooting & videos. Then, get the partsyou need fast. Return any part for 365 days.
Gas Oven/Broiler not working/igniting - ApplianceBlog
Jan 13, 2016 | Electrolux Kitchen Ranges
Our new home has a GE XL44 gas stove the top works fine but when I use the oven it smokes and sets off the smoke alarms.The stove is over 3 years old Any ideas before I have to call the repairman in?
A gas stove shouldn't smoke. Is is clean? There is some grease that has eluded your cleaning efforts of interior surface?
Here are some tips that may help you resolve this problem:
Check the broiler flame. If the broiler flame is not adjusted properly, you could be creating soot from the burner flame.
Position the items that your are broiling lower so that they do not splatter grease up onto the broiler baffle.
Use a broiler pan that will drain grease and drippings down below the top surface.
Broiling many items will naturally produce some smoke. If you have the oven door closed when broiling then the only place that the smoke can go is up and out of the oven vent. If you partially open the oven door, some of the smoke will come out of the door opening.
You may have residue on the top walls of the inner oven cavity. Do you have self-clean feature on your range to clean the oven? Follow all of the procedures in your owner's manual to properly clean the oven using the self-clean cycle. This may clear out any undetected residue that could be causing excessive smoke during broiling.
Aug 26, 2015 | GE Kitchen Ranges
Magic Chef oven & broiler do not work
you know i am thinking more towards a bad temp probe.
May 28, 2009 | Magic Chef 31000 Gas Kitchen Range
Our Electric Amana Self Clean Oven, the broiler is not working? Help! The oven and stove top work just fine, but when we go to turn on the broiler the broiler doesn't come on, the selection buttons all...
canoyu physically inspect teh element for damage, perhaps its broken. or as wireleadingto the rearof elemnt has buntoff. you can check , but turn offpower first, the wires are always live
Feb 21, 2009 | Amana ARGS7650SS Gas Kitchen Range
I don't seem to be getting gas to the oven and broiler.
top of stove work but the oven dont work the igniter come on and glows but no gas
Jan 24, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Oven and Broiler not working
The gas supply valve to the oven/broiler is the likely culprit. It is a separate valve from the stovetop. I've had the same problems and had to replace mine twice now. They are very expensive, (about 100 dollars) considering the cost of the whole stove. It is located
inside the broiler drawer on the very back wall.
Jan 01, 2009 | GE Spectra JGBP35 Gas Kitchen Range
Caloric gas stove prestige series
to jenna 12 Does your stove have a stop and start timer? When you set your clock you may have inadvertantly moved the stop or start time on that timer. Check them, if they have knobs for setting the stop and start time, make sure the pointer is pointing to the current time and that the knob is popped out and not stuck in. when you have it right both the stop and the start knob should be out, not pushed in. They will pop out when you turn them to the current time.
These timers allow you to start something cookin at a time delayed several hours. this means they will not allow the oven to come on until it hits that time that you may have set in error.
If your stove has a digital stop and start timer check each one so that both show the current time, then your oven should light.
Oct 13, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Tappan TGFS26C Gas Kitchen Range Logo
868 people viewed this question
Top Tappan Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Sal DeAngelo
Are you a Tappan Kitchen Range Expert? Answer questions, earn points and help others
