Question about Moen & One Handle Tub & Shower Faucet
How do I remove the cartrige from the valve? - Moen & One Handle Tub & Shower Faucet
  • jeffseivers Jun 04, 2010
    Does this valve simply turn on by twisting the knob counterclockwise or does it come on by pulling on the knob and turning left or right for temperature?
    You need to share the brand of valve with us before any attempt to solve your problem can be attempted. About the only thing in common with shower valves is the difficulty in figuring out how to get the handle off.
    Scholar:
  • 81 Answers
Assuming you have a single handle valve, Moen has 2 types of cartridges. The Posi-Temp (replacement cartridge # 1222) turns on and off simply by turning the handle left to right and right to left. The Moentrol (replacement cartridge #1225B) turns on by pulling on it. Handle style does not aid in identification.
Buy your new cartridge before you start and buy genuine Moen! OEM cartridges can give Moen a bad name.
Once the water to the valve is off, remove the handle.
The procedure is the same for either type of valve so use the link below as a reference.
Firmly grab the temperature limit stop and pull it off the valve body. Using pliers, pull out the brass retainer clip. Place the notched end of the white plastic tool that came with your new cartridge onto the old cartridge and rotate as needed until completely seated on cartridge. Put a wrench onto the squared end of the white tool and turn back and forth several times. Remove the tool, grab the brass center of the cartridge with pliers and pull the cartridge out.
Briefly turn the water on ond off to flush the valve of any possible lingering particulate.
Insert new cartridge and use white tool to assure cartridge is all the way in then use the squared end to rotate the cartridge as necessary into an alignment position to reinstall the retainer clip.
http://www.moen.com/shared/pdf/3170pt.pdf
Posted on Jun 04, 2010
If you have no hot or cold water the 1423 Balancing Spool could have its piston jammed with calcium and lime deposits. how do I remove the cartrige from the valve? - 1_14_2013_5_28_56_am.jpg
Posted on Jan 14, 2013
No cold water
the cartrige might be it upside down or might be pluged turn water off to house remove handle unsrew cap and remove cartrige then flush out reassamble then turn water back on
Apr 29, 2012 | Moen & Posi-Temp Single Handle Shower Or...
I need troubleshooting help with my three function transfer shower valve .
valve is bleeding by remove and check the condition of cartrige look for wear or dirt
Apr 28, 2012 | Home
My friend had a problem of his printer, cause the printer didnt recognize the ink... it has 6 colors epson ink. we dont know how to fix it... all the cartrige shows x
Is your friend use CISS. If so
Move Ink cartrige holder to cartrige change station.
Put off cartrige ( genuin or CISS) from carrage
Take a soft erager try to remove dry in or dust or waste everything smothly
reassemble the cartrige again
push top of the cartrige gentaly sothat it struck acurately.
Turn on printer.
I think you will get rid from your pprinter problem.
Thank you
Aug 21, 2011 | Office Equipment & Supplies
On my samsung fax sf5100 machine there has been a new ink cartridge installe dand the machine is still asking to insatll new cartridge , do i need to tell the machine new cartridge installed if so how
you will see there is a fuse on the cartridge. replace it with a new one. it can be biger becouse you will remove it again.
put the cartrige back with other fuse and close door for 3 secons. take cartridge out and remove the fuse.
put cartrige back with out the fuse. it sould work.
the other way is to push setup and then # 1934.
push setup again check for new cartrige or egnore cartrige.
swich m/c off and on.
Aug 10, 2011 | Samsung SF-5100 Plain Paper Laser Fax
Don't print in color
It's your printer head problem. Your printer head is now block. To remove the problem try to follow the proces:
1. Take some amonia solution ( amonia30%+ water70%) in a plastic seringe.
2.remove cartriges from cartrige holder.
3. Then set the seringe nipple in one stick (that is into cartrige holle all time while cartrige is push).
4. Then push the solution in to the black plastic stick.
Use these proces 5/6 time one after another to a black stick.
I think you may relive from your problem.
Thank you
Jun 16, 2011 | Epson Stylus C82 InkJet Printer
My hot water suddenly stopped flowing. I have a good water supply, the cold is fine. The water heater is full and is hot, but, no water comes from any tap. PLEASE HELP !!!!! Dennis K.
I had the same problem and I took out the two shut off/by-pass valves (unscrewed handle and removed cartrige) to find that lime build-up had virtually sealed the lines so that no water flowed!
Cleaned out the lime deposits and reassembled valves and water flowed once again.
Sep 20, 2010 | RTO Atwood DSI-RV Water Heater-6 Gallon
I just installed a single handle tub & shower faucet, when I checked for water flow there was barely a dribble. I suspect there is blockage in the valve. I would like to take out the valve unit, to...
If you soldered the faucet without removing the cartrige you may have damaged it. they have to be removed before soldering. if not, too much solder while soldering may plug port.
Sep 10, 2010 | Peerless Industries Peerless& Single...
Metering faucet drips, installed two new cartriges and filters and I still have a drip.
Using a parts breakdown picture, disassembe of the valve carefully @ the stem by removing the handle then the bonnet with the seals. Check, with a magnifying lens, the condition of the valve seats. There could be some particles or some damage to the surfaces that touch each other. Sometimes a 300 grit sandpaper rotated around those parts remove slight problems. Usually changing the stem (part that turns) or the seat (part that it tightens against) is the cost effective approach. Put it back together cleaned and carefully. Plumbing stores and most large hardware stores have this. Bring the parts with you for a pewrfect match.
Sep 09, 2009 | Plumbing
I don't know how to get the cartrige out of my american standard two handle bathroom sink faucet. Help.
Turn off the water supply valve.
Open the faucet to bleed pressure.
Remove the bolt holding the handle on.
Remove the handle.
Remove the spool retaining nut.
Remove the spool.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 20, 2009 | Washing Machines
Moen & One Handle Tub & Shower Faucet  Logo
1,015 people viewed this question
Top Moen Home Experts
Mike
john h
Andrew Bugbee
Are you a Moen Home Expert? Answer questions, earn points and help others
