Question about Dometic RM2852 Refrigerator
Just bought a brand new camper and the refr/freezer does not seem to be cooling very well. It took 2.5 days to make ice cubes. I saw a setting in fridge for cold to coldest but it is a plastic peice that slides on a fin and the thermometer was not connected. Any ideas on how to set the tempature?
Take it back to where you bought it.If it is a new camper there should be a warranty with it . Let them fix it .
Posted on Jun 07, 2010
Getting no water in the filter it is being by pass, when I took out filter there was no water in it put a new in and still the same, it is a kenmore elite 795.77543600
its most likely a frozen water tank. try and clean the coils by the compressor and then make sure the temps for refr are set around 38. it might need to be warmed up inside the refr section. you can tell if its too cold by the vege's if lettuce, carrots and celery are crispy, then you might need to clean the coils.
Dec 30, 2013 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
GE Profile, bottom, freezer Freezer does not stay at 0 degrees. With uses during the day it gets up to 20 degrees. Ice cream does not stay frozen. This happens mostly in the summer. Once it get cold...
most refregerator..usually open the door at day time..so it will not keep on required temperature o degreefrequent opening refrigerator,must be adjust the thermostat to higher setting..
Jul 11, 2011 | GE Refrigerators
We have a GE side-by-side refrigerator (GSS23QGTA); it's about 6 or 7 years old and has been working just fine until about a month ago when we noticed that the freezer was not freezing food. The temp had...
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Feb 16, 2011 | Refrigerators
Kenmore fridge not working, ice cubes wet, freezer frosting up
You may need a new defrost module. The coils ice up when it is not working. This makes the fridge and freezer only a little cold. About 150 to 250 bucks to fix if you call a service person. Under a hundred for the part.
Apr 13, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Ice cubes made by ice maker become large fused chunks over time.
Ice cubes will deteriorate over time if not used. They shrink due to defrosting of the freezer and will become stale.
Once the ice bin is full, turn the ice maker off until you use the cubes and or dump the cubes every 3 or 4 days and start over.
Mar 03, 2009 | GE Refrigerators
Kenmore 596.72289200 Freezer fine, but refrigerator not coolin
you must not be getting any air flow into the refr section. make sure the fan is running and if so then you may have a defrost problem. look at the freezer section rear panel, if it has heavy frost on it then it is not defrosting properly. there are a few problems that could cause a defrost issue. defrost heater, thermostat, or timer/control board. most likely the defrost thermostat.
if it is frosted over, then shut off the unit and get ready to catch the extra water that will run onto the floor, after a full day turn it back on and if it cools, you will know that you are not defrosting. it will work ok until it frosts over again, in about 2 weeks. then you will need to find out which part is bad causing the no defrost.
Dec 28, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Remove panel
the freezer panel has 2 fan motors, one for the i/m area and the other for cooling. there is 1 screw in the center of the panel, remove it and then the panel will have to be wedged out. it may seem like it is tight but go ahead and pull on the panel and it will come out.
before you can do this, you will need to remove the drawer and rails so you can get into the panel easily.
p.s. you didnt say why you want to remove this panel???
by the way, these units have problems with the fan motors causing poor cooling in the refr section.
Dec 27, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
ICE CUBE MAKER SMELLY ICE CUBES
Hello margrek
Welcome,
YOU SAID, YOU HAVE KENMORE ELITE BOTTOM FREEZER WITH ICE MAKER THE ICE CUBES SMELL HORRIBLE ALWAYS, I EVEN TOSS THEM OUT EVERY FEW DAYS, STILL SAME PROBLEM
Ice has bad odor and taste.
1• Ice has picked up odor or
flavor from strong food stored
in refrigerator or freezer.
2• Water running to ice maker
has poor taste or odor.
3• Ice not used frequently enough.
4• Cover foods tightly. Discard stale ice. Ice maker will
produce fresh supply.
5• Add filter to water supply line. Consult a water purifying
company.
7• Discard stale ice.
Huuum
Please remember to leave a rating!
Oct 11, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Side by Side Refrigerator Always dispenses crushed ice regardless of setting
I know it will be a pain but take it apart again and lube the metal shaft in the solenoid and the plastic slide with petrolium jelly, that should keep it from freezing up. It's what we do...
Dec 25, 2006 | GE GSH25JSRSS Stainless Steel Side by Side...
Dometic RM2852 Refrigerator Logo
231 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
RV REFER LLC
Level 1 Expert
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
