Question about Audiovox DV1201 System
I want to connect my surround sound up to regular tv
    Problem Solver:
  • 10 Answers
You will need that 5.1 amplifier for that,
Posted on Jun 07, 2010
No surround sound
Your not goingto achive true dobly sound you need a HDMI solution for this and hence you dvd player is rather old since it does not use HDMI if you want true HDMI sound you need to purchase a DVD with HDMI outputs to the TV
May 24, 2009 | Sansui 19 in. LCD TV
Need to know how to make the surround sound work through regular T.V. with durabrand surround HT-3915
Your regular TV set must be able to process the surround encoding through its output to where the Durabrand is taking the sound from.
Also, if you are using the TV set on a converter, Cable Box, or Sat receiver, and you are not taking the output from the component output there will be no surround from the source.
Surround sound is critical to how it is processed and applied.
Jerry G.
Feb 22, 2009 | Durabrand HT-3915 System
Lg home theater to lg plasma tv
This is a typical problem with TV broadcast UNLESS you use a matrix DSP surround sound mode, most DVD audio is either Dolby digital 5.1 surround or DTS multi-channel surround sound, unless you are viewing a HDTV broadcast with 5.1 Digital sound connected from the TV to the receiver then you are probably receiving a 2 channel Stereo sound format, I would suggest that you try to set your TV input mode to a audio Dolby Pro- Logic which will yield 5.1 and should engage all speakers.
Feb 17, 2009 | LG LHT854 Theater System
Tv built-in dvd player wont play thru surround sound
goto your menue setings and slect sround sound and set up to external sound system.
Jan 10, 2009 | Toshiba LCDTV/DVD Player 19HLV87
use your t/v audio out with RCA cables to your reciever input like(vcr in, dvd in, dtv in)
Dec 20, 2008 | Yamaha HTR-5930 Receiver
No sound when using dish or regular tv
This may be old news but just in case ...
Typically you need to consider the surround system as the central point for sound distribution (and in newer receivers, the distribution point for video signal as well). So you need to think of your TV and Satellite as sound sources and connect them to the IN side of your surround sound system. From the back of your TV then, look for the Audio OUT (commonly Red for right and White (or black) for Left. Connect these to the IN on the back of the surround system. Likewise for your satellite box. Then make sure you select the appropriate source on the surround system. If the system supports the video signal, you can route that as well. Beware that you'll need some sort of simulation (provided by the Phillips unit) to upconvert stereo to surround ... check the manual online. If you post model numbers for the Phillips and satellite units, we might be able to direct you more specifically (provided we can find manuals online)
Feb 24, 2008 | Audio Players & Recorders
Surround sound hook up
av/out on tv to av/in on vcr / av/out on vcr to av/in on home theater pls rank
Jan 23, 2008 | Televison & Video
Home theatre problems sound
Did you try to connect AUDIO OUT from your TV to AUDIO IN on your package?
Oct 04, 2007 | Sony DAV-C700 System
Audiovox DV1201 System Logo
52 people viewed this question
Top Audiovox Audio Players & Recorders Experts
John
John
phil
Andrew Taylor
Andrew Taylor
Are you an Audiovox Audio Player and Recorder Expert? Answer questions, earn points and help others
