Question about GE Profile PFS22 33" Artica French Door Refrigerator w/ 22.2 Cu. Ft. Capacity, ClimateKeeper System ...
No water but do get ice
I get ice but no water comes out. I replaced the water filter for the first time in 3 years hoping that would solve the problem but alas it did not.
    Genius:
  • 1,073 Answers
Check the water valve i could be bad, if you push in the paddel on the freezer door and you get 120 volts at the coil that has the larger plastic line replace the valve assy.
Posted on Apr 10, 2008
Whirlpool Gold Series Refrigerator has foul tasting water and ice.
and what does the water elsewhere in home taste like .is it city water or well water . usually you can take a sample to local health dept and they will test it free .
May 20, 2015 | Whirlpool Refrigerators
Frss36af25 3
Try replaceng filter with new one some have more than one filter. hope this helps
Nov 29, 2013 | Refrigerators
I have checked the valves, the inlet, the temperature, and there is no off switch that I can locate for my ice maker. The unit is only a few years old, I replaced the filter and yesterday I emptied the ice...
Try to remove the ice bucket and replace it. Make sure the ice maker is completely in the "Up" position. Make sure that the water line is not crimped. Remove and replace the filter again. I hope this helps and solves the problem. Please let us know if we helped you and have a great evening.
Ella
Aug 03, 2010 | Refrigerators
Water filter question
WOW! I'd say that the filter is definately due for replacement.
The manufacturer recommends the filter be changed every 6-8 months, as with ice and water dispensers in the door, folks tend to use the chilled water and ice more often, hence you get alot of gallons of water thru the fridge each month.
Once you replace the filter, you'll need to flush out the lines, (see the instructions with the new filter) to get rid of any loose carbon in the filter element, but once you done this, you should also notice better water flow and better tasting water and ice cubes too.
I tend to change my ice/water filter on my fridge every year when I change my smoke detector batteries. That way, I don't forget, sort of like my personal "once-a-year" house task list to change batteries, filters, resetting timers, etc., etc.
It's a good idea to change these smaller filters at a minimum of once a year, as they are no longer providing the filtration you want, and can actually be letting some of the contaminents fow out and into your water and cubes.
Hope you find this Very Helpful and best regards!
Aug 20, 2009 | KitchenAid KSSP48QMS Side by Side...
Water not coming out of fridge
First, I'm not a Whirlpool Tech.
*** Following is for information only.***
* Sputtering or no water from Ice machine and tap indicates a clog on the water line.
* Most of the newer (last 15 years) refrigerators come with a built in filter. It's probably clogged. Check the link below for changing out filter or type in "Whirlpool refrigerator water filter replacement'
* There could be ice blockage in water line if you have a very low temperature setting on your fridge. Most are set in the middle of the dial. If your set at maximum could then this setting may be too cold for the water line (it's coiled in the back of the refrigerator and may have frozen up.) Back the temperature a bid and give it a day or two to melt.
* The ice tray is missing a cover.
* Ice tray "Ice Full" lever is stuck in the Full position. Check if the Ice level (usually a stiff wire) is in the down or empty position. (some lock in the full position to turn off ice maker manually.)
* Check the water line to the refrigerator (or In-Line water filter) for water pressure. Turn off water supply. Remove water line from refrigerator and place end of line in empty bucket. Hold line down and have someone turn water back on then off after a few seconds (they may be too far to hear you yell "turn it off?!") If it just sputters then the line needs to be cleared. Check the needle valve for clogging. Close it off and re-open it several times. Otherwise this valve needs to be replaced.
* Follow the flow of water through each part: Supply line, supply valve, Water filter, Refrigerator inner filter, Tap point and Ice maker.
* Final, Check your warranty as any work (other than a MFR recommended customer water filter change out.) will void it. Call your vendor for service to be safe. (Have them do an annual maintenance while they are servicing your unit.)
Aloha, ukeboy57
Whirlpool link; https://www.bing.com/videos/search?q=whirlpool+refrigerator+water+filter&&view=detail&mid=B5D436DFC162C03FB4FAB5D436DFC162C03FB4FA&&FORM=VRDGAR
Feb 21, 2018 | Whirlpool Refrigerators
Not making ice
Hi: Change or just remove the water filter first. As your water dispensing slowed that is a clue. If the water filter is that clogged it will cause a problem with the ice maker. Plus the water you drink is not filtered anymore. City water is being run through 2 years of crud. If you don't replace it just remove it. I hope this helps, Jeff
Jun 03, 2009 | Frigidaire FRS3R5EMB Side by Side...
Ice from ice maker does not taste right
Hi
Ice storage bin needs to be emptied and washed. Unsealed packages in the refrigerator and/or freezer compartments may be transmitting odors/tastes to the ice cubes.
Interior of the refrigerator may need cleaning.
Water chemicals. Installing an in-line filter can help with many odor/taste complaints.
An open box of baking soda in the refrigerator section can help with preventing the transmitting of food odors.
This is a common in-line water filter, they are fairly easy to install and usually come with instructions.
Even when your well or municipal water supply provides healthy, potable water to your ice maker, some impurities may remain. These can affect the smell or taste of the ice cubes, and therefore the beverages in which you serve them. A taste and odor water filter on the incoming water-supply line--such as our charcoal "Universal Replacement Water Filter"--can help a lot.
Also, over time, the ice cube bin can absorb difficult-to-remove odors from the freezer. Some manufactures recommend that you replace the bin every 2 to 3 years, whenever it seems to be retaining objectionable odors and transferring them to the ice cubes.
A Fixya Rating would be appreciated.
Thanks
Rylee
Feb 11, 2009 | Whirlpool ED2GHEXN Side by Side...
GE side by side refrigerator: water/ice dispensor
I bought a brand new smartwater replacement filter and after a very short time, my water stopped coming through the door.. took out the new replacement filter and inserted a brand new one .. problem solved.. apparently some of the g.e. smartwater filter replacement cartridges don't have the high enough two plastic inserts which are attached to them at the top of the filter when you screw them on... if you have taken your cartridge in and out a few times, i think it wears down the plastic so it doesn't fit properly and won't put up whatever it is supposed to push up to make the water come through.. I personally think this is a g.e. problem with the replacement filters...
Jan 31, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Plastic Taste in Refrigerator Water
Hi there, I noticed the same condition when I left the filter in ours a little too long. The optimal performance from the filter is achieved (I have found) when you change it after 3 months. This is about the same amount of time it takes for the light to change from green to red on the filter light.
Hope this helps. ~Steve
Jan 24, 2009 | KitchenAid Refrigerators
Water has stopped coming out of the filtered water dispenser
I just had this same problem and finally figured it out. The water in the line was frozen because my freezer was turned to 6 (note on inside of freezer says recommended temp is 4) so I turned the freezer to 4 and the refrigerator to 3. Next day the water was flowing.
Hope this fixes yours,
Sherry in Pittsburgh
Jan 10, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
GE Profile PFS22 33" Artica French Door Refrigerator w/ 22.2 Cu. Ft. Capacity, ClimateKeeper System ... Logo
69 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Ilia Bichin
