Question about Saws
For the Skil 77 worm drive circular saws what type of oil is required?
  • 391 Answers
Use 90 weight gear/differential oil but if you use it outside in the cold weather it's too thick, use 40 weight oil then and switch to the 90 weight in the summer.
Posted on Jun 04, 2010
I need the outer flange/blade clamp for my Skil model 77 type 15
This sounds like a worm drive. Try going to this web site to order your part.
http://www.ereplacementparts.com/skil-shd77-f012sd7700-worm-drive-skilsaw-parts-c-130_160_7479.html
This is the part for the blade clamp washer $5
Blade Clamp Washer
This is the flanged plain washer $4
Blade Clamp Washer
and retaining ring $4
Retaining Ring 2610341359 for Power Tool eReplacement Parts
Dec 03, 2014 | Skil Saws
What type of oil does the saw require and how much?
Your Skil tool has been properly lubricated and
is ready to use. However it is recommended
that the gears be relubricated only with Skil
lubricants: No. 80111 (8 oz. tube), No. 80112
(pint) or No. 80113 (1/2 gal. can).
Always check the
oil level before
using the saw. To
check and add oil:
Remove plug from
power source and
place the saw's foot on a horizontal surface.
Remove oil plug using the same wrench used
to remove the saw blade. The oil level should
never be below bottom threads in the housing.
When adding oil, fill until oil starts to run out of
oil hole at arrow on housing and replace oil
plug.
part #80111 and is available from http://www.ereplacementparts.com.
Sep 27, 2012 | Skil MAG 77-75 7-1/4-Inch Magnesium Worm...
What kind of oil do i put in my skill saw 77
This saw requires Skil's heavy-duty, worm-drive oil, part number 80111. If you can find a local vendor that has some great otherwise, type 'skil 8011' in your search engine and shop around for an 8oz tube, they can run from $5 to $10 plus shipping.
Jan 28, 2011 | Skil 7 1/4" Magnesium "Mag 77" Wormdrive...
I need to know what kind of oil do I use to change the oil in my skill saw 77? Mine is pretty dirty, runs great but thought I should change the oil. Thanks Bill
Use Skil worm drive oil #80111 ($5-$6.00) at Home depot, or Bosch WD7LUB 2.3 FL. OZ. (I bought for $3.50 at Bosch service center.)
Aug 28, 2010 | Skil 7 1/4" Magnesium "Mag 77" Wormdrive...
Need to know the type of oil that the skilsaw 7 1/4'' mag 77 use
skil recommends using their lube 80111 for an 8 oz tube or 80112 for a pint. however any good quality worm drive lube will work. Don't use a gear lube because the worm drive has additives for anti foaming and gear wear added. Let me know if you need more help
Nov 17, 2009 | Skil 7 1/4" Magnesium "Mag 77" Wormdrive...
Need lower blade guard for Skilsaw Model Model 77
Yes I do Know where, here you go !
http://www.toolpartsdirect.com/skil/skil-34.html
Nov 09, 2009 | Skil 7 1/4" Magnesium "Mag 77" Wormdrive...
I need the outer flange/blade clamp for my skil model 77 type 16
The replacement part is 1619X02969. And you can get it from directly from boschtoolservice.com ($3.75).
Oct 11, 2009 | Skil 7 1/4" Magnesium "Mag 77" Wormdrive...
I need to know how much oil goes into a skilsaw worm drive resvr.
Haven't heard anything so I checked the Milwaukee worm drive saw and they recomment about 1/2 oz. Make sure you use an oil for a worm drive that is not foaming. Hope this helps. Also when checking oir level have the shoe set for max depth and on a flat surface remove the oil plug, when filling tip the saw on its side and fill, turn back over and allow excess oil to run out if overfilled.
Jan 20, 2009 | Skil 7 1/4" Magnesium "Mag 77" Wormdrive...
Saws Logo
122 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Saw Expert? Answer questions, earn points and help others
