Question about Plumbing
Where can i get an impeller for a shur dri sd a10l pump
3 Suggested Answers
  • 832 Answers
SOURCE: Where can I find a replacement impeller for a
Connect to the internet and type;
http//www.merchantcircle.com/business/Shur.Dri 419-289 1144.
This is where you can find your ShurDri Pump parts.
Posted on Oct 26, 2009
SOURCE: I have a Shur-dri SD-106 pump. I am looking for a
call 888-987-8677 this a division of pentair they make shur-dri pumps
Posted on Jan 10, 2011
I have a Shur-Dri 1 HP above ground pump, Model No. SD-100-01. The propeller is cracked and needs to be replaced. I cannot find anyone who sells just the propeller. They say I have to get a new pump. ...
There is a possibility that this model is not supported any longer. What you are needing is an IMPELLOR. The company that makes sure dry has a lot of information here: http://www.pumpproducts.com/myers-m-39.html
Jan 23, 2015 | Pool & Spa
My shur-dri model sd-100-01 well pump will run for a while and then shut off but will restart after an hour or so. What's wrong?
It is a heat sink in the motor. Most all electric motors come with it. Once it cools down, they work again. The heat sink keeps them from burning up.
Oct 26, 2014 | Cars & Trucks
Where can Iget impeller #16622B010 for a shur dri water pump
I can only help on a Honda 50hp 2003. Any Honda center or parts center. That's all I know. JMC
Jun 09, 2014 | Honda Water Pump Impeller Outboard 35, 40,...
Need to prime Shur Dri SD-520C T7
OK, prime away. May be you should reboot the computer first.
Dec 15, 2012 | Computers & Internet
Shur-dri sdts10-01 water leaking from shaft around impeller housing
Mine is too. But I have not had any useful replies to my simple question about "where is the level sensor".
SoI agree FIXYA looks a complete scam!!!
Dec 13, 2012 | Dishwashers
I installed a shur-dri 4"
Hello
If this is a 220 volt pump then it needs to have 2 hot wires,so it would be connected to 2 15 amp breakers.The ground shold run from the pump back to the fuse panel box ground bar.
If this is a 115 volt pump it should be connected to one hot, one nutral, and one ground.
Possible a hot wire is making contact with water and tripping breaker.Or the pump motor is going to ground which means its no good.
Aug 01, 2011 | Heating & Cooling
I have a Shur-dri SD-106 pump. I am looking for a source to purchase replacement impellers. Please advise
Sep 15, 2010 | Plumbing
Need head pressure on 1hp shallow well pump SDTS10
reducing the pipe size helps build head pressure.
Mar 18, 2010 | Plumbing
My Shur-Dri Backup Sump Pump does not activate with a power outage.
I presume your pump is having a separate power supply.
It is to operate if and when there is power outage. Am
I right? Check your Shur-Dri backup pump. Plug it to
another power source, and switch it on. If it runs, then
the problem could be power supply. Have this checked
using voltage tester (multitester set at 300 volts) or you
may use an electric bulb.
Dec 03, 2009 | Plumbing
Where can I find a replacement impeller for a Shur-Dri SD-106 pump?
Oct 25, 2009 | Plumbing
Plumbing Logo
362 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
