Question about Whirlpool Duet 4.0 Cu. Ft. Steam Washer
It wont spin nor will it drain
I have a whirlpool duet wfw915ww00 4.0 cu ft it wont spin most of the time and it will not drain the water out....
    President:
  • Whirlpool Master
  • 662 Answers
The filter on your pump is probably clogged with lint and stuff. You have to remove the bottom front panel, 3 torx screws underneath. The panel will drop and come off. Drain off the excess water from the hose you see. The white filter cover is right in front. Get yourself a bunch of towels or a good big plastic bag to collect water. Unscrew the filter cover and twist the filter out. Clean out all the stuff and put it back in carefully.
Pl rate me nice for the free help, thanks
Posted on Jun 04, 2010
Door won't open on front load washer
How to Unlock a Whirlpool Duet Washing Machine ' Home ...
homeguides.sfgate.com > Mortgages > Mortgage Options
If you must manually unlock the washer door after each wash cycle your drain ... to Change a Water Inlet Valve for a Whirlpool Duet Front-Loading Washing Machine ...Causes and Repair for a Whirlpool Washing Machine That Won't Spin or ...
How to open a washing machine door that won't ... - YouTube
? 3:57
https://www.youtube.com/watch?v=-65_eoT6zuk
Aug 22, 2013 - Uploaded by how-2-repair.com
Your washing machine door won't open this video will show you a technique ..... Front Load Washer Repair - Not Draining or Spinning - How to Unclog ... Washing Machine Repair - Replacing the Door Bellow (Whirlpool Part
Nov 05, 2015 | Whirlpool WFW70HEBW Duet 4.1 Cu. Ft. Front...
Whirlpool Duet Sport F21, F01, SD
Drain pump may be clogged or need to be replaced may run but not pump blade stripped in pump
Apr 28, 2017 | Whirlpool Duet 3.8 cu. ft. Front Load...
Will not spin and will not drain water. error message says sud
Usually when the drain screen is clogged, the cycle will not spin or drain. You will need to open up the rear and remove the pump to get to the screen located inside a rubber boot. This is not an easy job, unless you are very handy. Call Whirlpool for some suggestions before proceeding. Good luck!
Sep 06, 2011 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Water is not draining out when thru with cycle?
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Oct 11, 2010 | Whirlpool Duet 3.8 cu. ft. Front Load...
Whirlpool duet 4.0 washer 3 weeks old suddenly beeps 3 times after start button will not run
3 Beeps/E30--Error: Drum overfilled. Cause: Inlet valve,pressure switch or control board failure.Select drain/spin to remove water. Restart.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Aug 09, 2010 | Whirlpool Duet 4.0 Cu. Ft. Steam Washer
Whirlpool duet gas dryer. was working fine now all light and time amount work but will not start and beeps 3 times
May 17, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
My whirlpool duet washer will not spin all of the water out after the spin sycle. There is a flashing F2 on the screen.
F/02 = Long Drain
If the drain time exceeds 8 minutes, the water valves are turned off and "F/02" is flashed. Most likely cause is item 1.
  1. Check Screen Filter Assembly for foreign material lint, socks, coins, nails ect. To access the filter remove the lower front panel. The filter (white is located before the pump. Place a pan under the filter and remove it and clean then reassemble.
  2. Check the drain hose and make sure it is not plugged or kinked.
  3. Check the electrical connections at the pump and make sure the pump is running.
  4. If the above does not correct the problem, replace the pump.
Oct 31, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
Whirlpool Duet HT Has F error & won't drain & spin
I agree a F code of 21 or 2 I would clean the pump and check the bellow behind as well the pump entry from the trap for debris or a broken impeller.
Sep 08, 2008 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Whirlpool Duet 4.0 Cu. Ft. Steam Washer Logo
347 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
