Question about GE 27957GE1 Phone
My phone dosn,t works.the batteries are good.the screen is dark.
Why does my screen go dark when I am making a call
It should go dark when you put throne up to your face. That keeps it from getting to warm on your face. If you don't want it to go dark, you can turn the auto dim off in settings under display. It will use more battery, but it shouldn't go dim. Then that may be under another setting.
Aug 26, 2014 | Cell Phones
Electrical problems with a 2002 Satun SL 200, the electrical door locks dosn't work, the mirror adjustments dosn't work, the dome light dosn't work. The engine runs good. head lights work
check all your fuses in engine compartment and under dashboard engine check light comes on every 3000 miles for oil change reminder
Jul 23, 2012 | Cars & Trucks
My lg kp 500 is hanged and dosn;t on
remove the battery for about ten minutes. put the battery back on and turn on the phone that should fix the issue
Aug 19, 2010 | LG KP500 Cookie black on T-Mobile U-Fix...
My phone shows a dark screen when turned on. it's nokia 6124c
Hi, when a phone displays a dark screen,it means that the screen of the phone has shifted or has stop working.
Unscrew the phone to check if the screen shifted. adjust if shifted.
But if not shifted, that means screen will be replaced.
Take care.
Jun 02, 2010 | Nokia 6124 classic Battery
I have a similar problem.
Actually it sounds like the phone is merely off. Perhaps the battery actually died. If so and then the phone is off. When you plug in the phone with while it is off it will show the logo then it will say please wait and the the battery icon and say charging. If the phone is charged it goes dark.
Just hold down the "end call" key for a minute and see.
This actually happened to me once. I thought my phone was broken. Just as I was about to call AT&T I decided to try turning it off which is done the same way as you turn it on. Imagine my surprise when it started right up!!!
Aug 10, 2009 | LG Vu CU920 Cellular Phone
THIS INSIDE SCREEN I DARK, BUT THE OUTSIDE LIGHTS UP. HAVE NOT DROPED IT OR ANYTHING JUST OPENNED IT AND IT WAS DARK
Open your phone and look at the hinges, while you are looking at the black screen it is the hinge on your left. Inside that hinge is a small wire, this wire is no longer connected.
Remove your battery and look for 4 small screws, remove these screws and carefully open the casing. You should be able to find the wire, it will be a challenge to put it back together.
Good luck
~Phil
Dec 29, 2008 | Nextel BOOST i835g i835 LTD. ED UNLOCKED...
Dark screen
go to your dispaly setings and check on the contrast and ilumination, if they are low, increase them and the screen will be bright
May 16, 2008 | Nokia 6133 Cellular Phone
Dark spot on the screen
Sounds like the screen burned out. Any water damage? Check the sticker on the phone (white box near battery) if not. Call your cellular provider and get the phone replaced.
Apr 28, 2008 | T-Mobile Dash Smartphone
Kenmore HE3 blink the light on delay dosn`t works no botton
Press "end of cycle" button to clear the screen. Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Jan 06, 2008 | Kenmore Elite 45986 Front Load Washer
GE 27957GE1 Phone Logo
43 people viewed this question
Top GE Lands Phones Experts
Computer Repairing
Computer Repairing
Dudeman321
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
