Question about Apple iPod nano 5th Generation
Can i unlock my ipod without itunes? - Apple iPod nano 5th Generation
  • 50 Answers
1) Open your iPod as a flash drive (you'll see it from the "My Computer").
2) Enable hidden folders and go into the folder "iPod control".
3) From within the "Device" folder, find the file titled "_locked" and rename it to "_unlocked".
Then just disconnect the thing and you should be on your way. If this doesn't work (I haven't tested this on any other iPods), deleting the file instead should work
Posted on Jun 04, 2010
Ipod disabled connect to itunes
Hi dimitri77
If you have forgotten the code, you can unlock the IPod by doing the following:
Connect your IPod to the primary computer you use it with (the first one IPod synced with), and open iTunes.
When you disconnect iPod from the computer, it will no longer be locked.
If you can't unlock IPod using either [the code or connecting it to the computer you use to manage its songs]. . . you can restore your iPod to factory settings using iPod Updater. Please note that this will erase all data on your iPod.
Afterwards, you can add your music and data back to your iPod.
If you want to change the primary computer that your IPod is associated with, do this:
1. Restore your iPod. WARNING: The restore process cannot be undone.
All of your songs and files will be deleted. Always make a backup of your important data.
2. Connect your iPod to the computer that you want to be the primary computer.
3. Open iTunes and synchronize.
If you can't unlock your iPod and you don't have access to the primary computer, your only option is to restore the IPod, which will erase all music and data.
Please take time to rate me
Bud
Sep 28, 2012 | Apple iPod Touch 8GB 32GB 64GB 3rd...
Tip
Unlock locked ipod touch without passcode
After reading couple of threads it came to my attention that one of the major issues that a general ipod touch user faces is that some how he or she has locked his/her ipod touch and now can not unlock it. so i am going to give a easy free procedure which will help to unlock the ipod
You can use it for any Version of Ipod touch (1g,2g,3g)
CAUTION:
you will loose all of your data if they arenot backed up.
you will need internet connection for your computer.
let's begin:
#1. Download itunes from here
Install it on your computer and run.
#2.Connect your ipod touch to your pc and press and hold both home(below the display small button) and power( on the top left corner) of the ipod touch untill it turns off and restarts and shows you the connect to itune sign.
#3. your itune will know recognize your ipod touch and it will ask you to restore. Restore it.
wait till it is done restoring. now you have your ipodtouch back on its factory status and unlocked.
hope this will help.
please comment
on Mar 17, 2010 | Apple iPod touch
Tip
Unlock your locked ipod touch without combination
CAUTION:
let's begin:
please comment
on Mar 09, 2010 | Apple iPod touch
Hi basically my problem is my ipod wont do anything but show me an image of a usb wire with an arrow pointing to itunes logo (connect to itunes) when i do that itunes tells me to unlock the screen using...
I can help.
So with the device plugged into your PC, iTunes open, if it shows up in iTunes eject it, or cancel the prompt to unlock the screen.
Hold down the Power button for 3 seconds
Without releasing the power button, also hold the Home button for 10 seconds
Without releasing the home button, release the power button and keep holding the Home button for 20 seconds.
iTunes will detect an iPod in recovery mode, let off button and set down device and hit RESTORE in iTunes.
Hope it works!
Mar 21, 2011 | Audio Players & Recorders
How do i unlock ipod nano without code
there are two options by which you can unblock the code on your ipod. Follow any of the procedures tomorrow.
Unlock with the Primary Computer
  1. Plug the iPod into the primary computer linked to that iPod, the first computer you synchronized it with unless you have designated another computer as the primary computer.
  2. Open itunes and sync the iPod as normal.
  3. Remove the iPod, following the normal removal procedure. The iPod unlocks automatically as you remove it.
Unlock by Restoring
  1. Restore the iPod to factory settings if you do not have access to your primary computer. This erases all of the data you have stored on the iPod.
  2. Plug your iPod into the new computer you want to be the primary computer. Open iTunes and click on the "Restore" button.
  3. Reload your data, if it is available and sync your iPod. Remove it following normal procedures.
Good luck.
Jun 25, 2010 | Apple Ipod Nano Second Gen. Green (4 GB)...
How do i unlock an itouch without my password?
How to unlock IPod touch Password? You can unlock your IPOD Touch passcode or password by following these simple steps.
  • Connect your IPOD Touch to iTunes
  • Press or Hold the power and home keys 10 seconds.
  • Screen goes black, now release the power button
  • Make sure you do not release the Home key until your iTunes says "We have detected an itouch in recovery mode."
  • After this its simple all you got to do is a simple restore using your iTunes
Apr 19, 2010 | Apple iPod touch
Why is my iPod touch disabled for 5009752 minutes
The iPod touch is disabled when the incorrect unlock code is entered too many times. The time the iPod makes you wait increases each time an incorrect unlock code is entered.
There are two ways you should be able to unlock the iPod.
First, connect the iPod to the computer it was last synced with. After iTunes recognizes the iPod, you should be able to enter your unlock code and unlock the iPod.
If the first method doesn't work or you don't remember your unlock code, then do this:
1) Turn the iPod off.
2) Hold down the Home button and connect the iPod to the computer it was last synced with.
3)Release the Home button when the iTunes image appears of the iPod's screen.
4)Wait for iTunes to recognize the iPod and then follow the onscreen directions to restore the iPod.
If neither method works, you will need to contact Apple Customer Support.
Nov 25, 2009 | Apple iPod touch
My ipod touch will not sync my music from itunes
Hey! There are some other iPod Transfer tools which can transfer music between iPod and PC, iPod and iTunes freely. I am now using this Wondershare iPod Transfer which is very easy-to-use. Now I can transfer music between iPod and PC, iPod and iTunes easily. You can have a free try of it.
Hope that will be of help to you.
Nov 11, 2009 | Apple iPod MA446LL/A MP3 Player
Forgot ipod passcode
simply plug your ipod into itunes to unlock the code
Jul 23, 2009 | Apple iPod touch Second Gen (8 GB,...
My ipod is lock how do i unlock it my sister put a code in and it wont unlock.
plug it into your computer.
open itunes.
click on your ipod in the bar on the left side of itunes.
click the button under the picture of your ipod that says "restore". this'll delete all your songs, but it'll unlock the code that your sis put on it, or at least, it should.
if it doesn't do it automatically, click the "Sync" button after the ipod has been restored, and you should be good to go with all your music, and without that code.
Mar 21, 2008 | Audio Players & Recorders
Apple iPod nano 5th Generation Logo
277 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
