Question about Garden
Having trouble getting my swisher Trim-Max to start...primer ball does not seem to be working... Any suggestions ...
  • 402 Answers
Check the fuel lines, you may have an air leak that requires new lines and a new filter.
Posted on Jun 04, 2010
The primer bulb doesn't fill with gas
sounds like you hasve a cracked fuel line or a cracked primer bulb. that is why it cant prime.
Aug 29, 2015 | Swisher 190cc 22" String Trimmer Mower...
Dyson animal ball
Hi Max, I had a similar problem with mine a couple of years ago. I had just cleaned all of my filters on my Dyson, One of them being the one in the ball. Was almost impossible to roll across the floor, I messed with it for a couple of days, no solution. Called Dyson, the technician I talked to thought it might be the entire head causing problems, they sent a new head it was under warranty so no cost to me. Problem still existed. I took the ball apart and looked closely at it and it seems I had screwed it back together wrong after the filter cleaning. Long story short, check to see if the ball is put together correctly. Hope this solves your problem
Mar 25, 2017 | Vacuums
Gas is leaking from the primer on my swisher walk behind trimmer. What would cause this?
i believe you have a cracked primer bulb or cracked fuel line. you should also check and see if the screws are loose that connect the primer bulb to the assembly.
Sep 25, 2013 | Swisher Walk-Behind High-Wheel String...
Swisher Mower dying when cutting
I've had a 60" Swisher finish cut (13.5 hp) for about 7 years and have found that the valves have to be adjusted on a VERY regular basis. When they get out of adjustment you can hear the starter trying to spin the motor but can't. I'm almost positive this is your problem. Go to You Tube to see how to adjust the valves to .004. It's simple. Stan Wilhite
Aug 17, 2009 | Swisher 60" 13 Hp Trailmower #T1360h
Pearl ball will not move up and down. Can it be
My blackberry does this all the time. I keep a supply of alcohol swabs available and rub it over the ball for about a minute and it always works. They seem to get dirty easily and need to be cleaned fairly often.
Jun 27, 2009 | RIM BlackBerry Pearl 8100
Primer Ball Sticking
Your carburetor needs cleaned. Disassemble the carb. and spray with carb. cleaner. Use a Den Tek Brush,(http://www.dentek.com/shop.php?target=products&product_id=7), to clean the small portals in the carb. Make sure that the small screen in the carb. is free of debris. Test the primer bulb after you get the carb reassebled and before you put it back on the trimmer. This will keep you from doing extra work.
If you need further assistance, just let me know.
Jim
Jun 07, 2009 | Troy Bilt Tb70ss Gas Trimmer
Ryobi 725r 31cc
Ryobi is Japanese for "Piece of ****" My suggestion is to throw it out!
My 767r has had fuel line and carb trouble from day one. I'll never buy another Ryobi or Craftsman tool again.
Jun 13, 2008 | Ryobi 15" Electric Factory Reconditioned...
Garden Logo
95 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
