Question about Nikon COOLPIX S570 Digital Camera
The battery wont charge and it is only the second
I have had the camera since christmas. The battery wont charge and it is only the second time I charge it....I was told it was the charger and bought a new one...but I continue to have the same problem.
charger lamp turns on and flashes for a short period of time and then stays red and never turns green.
Thanks,
Anna
Try turning the battery over in the charger. It sounds like the wrong side is up.
Posted on Jun 04, 2010
  • KIRASH Apr 03, 2011
    I have the same problem, with the light on the charger never turning green, the battery should be the right way up though because the battery gets charged a little, the charge will last for only a few hours though and then just suddenly the camera wont turn on again (without the low battery warning) until I charge it again.
    How long should it take for the light to go green on an empty ENEL10 battery?
My Porter Cable 20maxv charger is blinking red and won't charge the batteries. Just got it for christmas and has only charged the batteries twice
do you live in a cold region? batteries or the charging pack wont charge when cold and often display rapid red blinks
Jan 20, 2017 | Porter Cameras
Camera wont stay on
If you have checked than ignore this. Some cameras have a time out setting and it may be the problem.
Mar 19, 2014 | Pentax Cameras
Why wont my nikon coolpix s3300 charge and when i put it on
Your battery has probably expired...;they only take so many charges. Try a new one (before you buy it!)
Mar 05, 2014 | Nikon Coolpix S3300
Camera not turning on
Remove the battery and charge it again. If you only can make just a few shots with the battery and it stops again, think of buying a new battery. Special when you have not used the camera for a long time, the second and third charge can be better. If not the battery is on its end of life.
Dec 30, 2013 | Olympus E-520 Digital Camera with 14-42mm...
My sl102 samsung wont turn on
Are you sure the battery is correctly charged?
Most USB connectors on most PC's don't deliver enough power to charge the battery. Try to charge the battery with the power cord till the green LED is on.
If you'r sure the battery is fully charged and the same happens again, remove the battery for a small time and put it in again.
Feb 20, 2013 | Samsung SL102 Digital Camera
My camera will not power up at all, My Batery is full charged. Christmas is looming and I need a camera. HELPPPP!
Try this: with camera power switch in the "ON" position, remove the battery. Then press and hold the shutter release for approximately 30 seconds. Turn power switch "OFF", reinsert battery and turn back on.
Look on bottom of camera for a very small Hardware reset switch. If one ther, turn camera on and press for about 2 seconds.
Dec 21, 2010 | Nikon D40x Digital Camera
Camera Won't Charge
my finepixz3 got wet. but after a few days it worked! but when the battery ran out it wont charge. is it the battery? it turned on a few sec when its in the cradle but it wont last after a few seconds it would turned off. is it the battery or the camera itself?
Sep 01, 2008 | Fuji FinePix Z3 Digital Camera
CasioEX-S880 will not charge.
Hey ITDude,
You do need to charge the camera by putting it in the camera dock and the ac cord should be plugged into the camera dock. It is possible that the battery has gone bad so you could try getting a new battery. If neither of these options work I would have the camera looked at by an authorized service technician. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
Jun 18, 2008 | Cameras
Battery won't charge...
You can take you battery to a place called batteries plus they can check out to see if it is you battery if the battery is good than you have a bad charger. you can get one cheap off of ebay. They are 45.00 plus at batteries plus lots cheaper off ebay and some time you can get a charger and battery combo for half the cost of the charger from them. hope this helps.
Mar 28, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Nikon COOLPIX S570 Digital Camera Logo
362 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
