Question about Craftsman 20 Hp 42" Deck Lawn Tractor
My steering on my lawn tractor is not working, i currently have to push down on my steering to help it turn. what is happening and how do i fix it?
  • 420 Answers
There is a brass or bronze pinion gear at the bottom end of the steering wheel rod, take it off and turn it around (upside down) to make the unworn parts of the pinion engage the rooster gear or replace both of the gears for tight steering again.
Posted on Jun 04, 2010
Wiring diagram for a john deere sst18 lawn tractor
Russell if you truly want to figure out this problem you need to look at the wires and ware they connect .And what they connect to then drew your own wiring diagram its not that difficult if you break down and do a few tests with an OHM meter to see what is connected and what happens when you through a switch or run a jumper wire to a ground .
If you think about its not really that complex .
Jun 08, 2016 | John Starter Deere Sst18 Spin Steer Deere...
What causes the front wheels to spread out making turning and steering impossible on a husqvarna lawn tractor.
the tie rod between the two wheels has broken or come off
the steering rod works on that rod or on one wheel which is connected to the other wheel by that tie rod.
Sep 04, 2015 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
How do I adjust he turning radius on my cub cadet rider?
actually you need to fix the steering stops and these should be on your steering castors
Sep 02, 2014 | Cub Cadet 2012 - LTX1042 KW - 42 Inch Lawn...
I have a 42" craftsman tractor... when you turn all the way to left the wheels get stuck... can I adjust anything?
What happens when you turn right? Does it turn as sharp as it used to? Almost sounds like the steering gear teeth have slipped and now it is steering to far to the left. You'll have to check the steering sector gears at the bottom of the steering column.
Oct 24, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 19.5 42 lawntractor, steering started clicking, then would nto turn wheel. Bar underneath unattached hitting ground. Do not know where it goes. How can I fix.
not a expert just trying to help,,sounds like you have two or mor problems,, first the bar will only go to one side of the front wheels,if it does not snap into place,you will have to replace the joint.,, the clicking sound maybe the steering unit sliping,,look down from steering wheel follow the shaft down to the steering gears,, they might be worn out.. hope this help you
Feb 15, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Difficult to start -- bad kill switch?
You have 3 safety switches located on the tractor, any one of which can cause the tractor to not crank over.
I assume the deck lever is not engaged, you are sitting in the seat and you push the clutch down when trying to start?
Start by lifting the seat and disconnecting the seat switch, push the clutch in and try to start.
Start there and we'll go from there.
Regards,
Aug 21, 2009 | Craftsman Garden
Steering has let go on my craftsman 17.5 lawn tractor
take it in it should be fixxed & ask them if its covered under warrenty
Jun 07, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Hi. I have a 19.5 HP Sears Lawn Tractor, model # 917.270821. The problem I'm having is with the steering in that it has become increasingly more difficult to steer. I greased the two fittings with a tube...
jack up front of tractor and remove clip at top of spindle move steering wheel back and fourth to get spindle to slide down clean and grease then reassemble this will fix most of them unless you have a bushing priblem you will see when removed .
May 12, 2009 | Craftsman 20 Hp 42" Deck Lawn Tractor
20 Year Old Craftsman Lawn Tractor Steering Gear Slips
check top of sector gear mounting plate for waer this is the gear that hooks to you steering gear . the plate that it mounts to will ware down causing it to be loos and slip . the only way i know to fix it is to pull the cross member out and take it to a welding shop and have it built back up.if the bolt is as tight as itcan go .
Mar 28, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 20 Hp 42" Deck Lawn Tractor Logo
301 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
