Question about Refrigerators
Hi there I have water settling in the bottom of my refrigerator. What can I do?
  • 713 Answers
Hi,Before jumping to conclusions about why your refrigerator is leaking, do a thorough inspection. Many times, it will be easy to see where the water is coming from and from that point deduce the problem. For instance, water leaking from the back is usually due to an ice maker issue, water from the side of the refrigerator is usually due to a faulty door or gasket, a leaking drain pan,a clogged defrost drain pan.
Thanks and good luck
Posted on Jun 03, 2010
Water leaking out bottom of freezer. settles & builds ice on bottom shelf. where is it coming from? how do i stop it?
Check out these tips...they can help you figure out what is going wrong withyour refrigerator
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
May 23, 2011 | Frigidaire Refrigerators
Water comes into the fridge from the freezer.
You have the drain from the coild froze up. The coils defrost and the water cannot run down the drain so it goes into your fridge.
This tip is all about that and how to fix it.
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
Heatman101
Jan 24, 2010 | Whirlpool 17.6 cu. ft. Top-Freezer...
The freezer drainage
you have a clogged defrost drain, remove the bottom basket, and freezer shelves to expose the screws for the back panel remove back panel,carefully chip away ice, and or use boiling water to melt the ice from the drain hose, check complete drainage by removing back panel behind frige at bottom and inspect that the water is draining completely into defrost pan. reoplace all parts.
Aug 27, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Compartments are not real cold/ ice maker stopped working too
It sounds like your refrigerant was leaking out. There may be some settled at the bottom that would explain the frozen water on the bottom. a good appliance store should be able to find the leak fix it and add more refrigerant.
May 14, 2009 | Maytag MSD2454G Side by Side Refrigerator
Water is dripping inside refrigerator
This ia a common problem that indicates the drain from freezer is clogged or blocked. I will send you to another link to help explain how to resolve this, Thanks, Sea Breeze
http://appliancejunk.com/forums/index.php?topic=22.0
Apr 27, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Water at the bottom of the GE side by side refrigerator
Check annd see if the fridge is level and the drain hole inside the fridge is clear , its at the bottom at the back of the fridge , if it is pull the fridge out and check where the pipe runs into the condensate tray on the motor at the bottom this also can block very easy!!
Mar 05, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
149 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
