Question about Sharp LL-173C-B (Black) 17" LCD Monitor
When I connect my monitor to my lab top the green power light comes on then turns orange and I get "no signal" message on the monitor
  • Light Yagami
    Light Yagami Jun 03, 2010
    does this laptop have multiple monitor support capabilities? when you plug the monitor in turn it on and goto your laptop. right click on the desktop and select.... what operating system are you using btw?
  • mrhartlen Jun 04, 2010
    I am using Vista
  • 11,361 Answers
You need to use Fn key in combination with either F4, F5, F6, F7, or F8 depend on your laptop to select either the internal screen, external, or both. Alos verify that the monitor works OK with desktop PC.
http://s807.photobucket.com/home/budm/allalbums
Posted on Jun 04, 2010
  • 33 Answers
You may need to tell the lap top to display from that screen the new screen has no image or signal so goes to sleep to save power.on your lap top try the (FN) key on your laptop then select a blue picture on the keyboad of to squears one black one blue this will alter the display.OR in windows look at Start>controal pannel>display
My dell gx260 ligth come green if i turn it on but for a few mins time it turn orange why
Do you mean the monitor's power light starts green and then turns orange when you turn it on? Most monitors will go to a power saving mode when they do not get a signal from the computer.
The Dell GX260 has a green power light when on. When the computer is off, the light is off. If it is green and blinking, then the computer is in a power saving mode.
Diagnosis: start with the obvious: is the monitor cable plugged into both the computer and the monitor (if not permanently connected to the monitor)? Are you connected to the active port? (You can add a video graphics card in most desktops. The motherboard video port usually needs to be disabled to use the card ports. If you plug in the monitor cable to the disabled port, it won't work.) Is the monitor set to the correct input? (This applies if the monitor has several ports. In that case, there will be a Source or Input button on the monitor.) Is the computer on? The GX260 has the power button on the front. (Other computers have the power button on the top.) There is also the power supply switch on the back which needs to be on.
Next try a different data cable between the monitor and the computer (if you can). Try a different monitor. If a second monitor works, than the monitor has a damaged main board. If the second monitor doesn't work, then the video graphics adapter has probably failed. Replace the add-on card, if in use, then boot in the safe mode to remove the old graphics driver. Then install the correct driver for the graphics adapter.
Note: the computer and the monitor should both be off when you connect the cables. Then turn on the monitor first and set it to the correct source before turning on the computer.)
I hope this helps.
Aug 21, 2011 | Dell OptiPlex GX260 PC Desktop
The monitor itself is black, and the power light is changing color from green to yellow to orange and flickering.
Hi there!
Changing the monitor light from green to yellow/orange/amber means that the monitor is in power saving mode. Make sure that the video signal cable is properly connected to the back of the monitor as well as to the computer.
Hope this helps.
Apr 23, 2011 | Acer H233H bmid Monitor
The monitor will not turn on. When power button
First--was it working?
Did it suddenly stop?
When you see the LG logo, then it goes away, does the power light turn from green to amber? Sounds like that doesn't happen.
So--if you are getting a signal, you should see something.
If there is no signal, then the power light should change from green to orange.
With no lights at all, I suspect a faulty monitor.
Feb 22, 2010 | Computers & Internet
Projector screen displaying "Searching" message. Does not recognize computer. Worked with one of your associates (Guru?) and we tried a number of solutions but none worked. She asked that I come back to...
If you are connecting to a laptop then you may need to hold the function button down and press F1, F2, F3 etc. there should be a sign with the latop on there and a sign with an external device (monitor,PROJECOR)
hope this information was useful to you.
Jan 21, 2010 | InFocus Office Equipment & Supplies
AcerAL1714 LCD Not Connecting With DELL Inspiron 15 Vista Laptop
There is a symbol of Two monitors on F3 Or F4 button
1. Press Fn key and hold it
2. by holding Fn key press F3 key
Your monitor will start displaying
Oct 05, 2009 | Acer AL1714 17" LCD Monitor
Computer monitor won't tur on
check the connector to the pc from the monitor. it may have come loose. if you have a mouse, try moving it and see if the light on the monitor turns to green. it is possible the video has failed.
Dec 02, 2008 | Dell Dimension 2400 PC Desktop
MONITOR NOT COMING ON . RGB NO INPUT SIGNAL .
You first take post( power on self test) connect power cord & disconnect signal cable you will see massage no signal check siganl cable then problem will be in cpu this problem may be solved by cleaning dust in cpu if montor shows no display then problem will in monitor open it check o/p of smps if not disolder path of eht if o/p comes then eht is faulty replace it
Oct 28, 2008 | Computers & Internet
Monitor won't come on
Check the power cable of the monitor make sure everything is properly connected.
May 10, 2008 | Acer AL718 17" Flat Panel LCD Monitor
Monitor has no picture
Yes! :)
Your monitor is not the problem. Check all the connections from the back of the monitor, to the computer.
"No Signal Analog" means your monitor is working perfectly, however is not receiving signal from the computer.
Didnt find any loose cables?
Try unplugging everything. Leave it unplugged for at least 5 minutes. You need to give the system time to drain all the excess power.
Again your monitor is fine, blue light > No signal > orange light is totally normal for your montior.
Oct 12, 2007 | ViewSonic VX922 19" Monitor Flat Panel
No display
if your monitor is not connected to a pc, then it cannot find a vga signal input and therefore go into power saving mode, which is indicated by the orange light, but as soon as you connect to the pc and power on the light will go green and the monitor will power up.
May 07, 2007 | BenQ T701 TFT 17" LCD Monitor
Sharp LL-173C-B (Black) 17" LCD Monitor Logo
187 people viewed this question
Top Sharp Computers & Internet Experts
Jason Harris
Jason Harris
Ricky Ostrom
Ricky Ostrom
pontelemon
pontelemon
Are you a Sharp Computer and Internet Expert? Answer questions, earn points and help others
