Question about RS1000 OLED 2Way OLED Remote Start w 6 Channel Alarm
How to re program my pager? (autopage 1000 - RS1000 OLED 2Way OLED Remote Start w 6 Channel Alarm
    New Friend:
  • 103 Answers
REMOTE TRANSMITTER PROGRAMMING
Enter:
1. Turn the Ignition 'switch ‘OFF/ON’ 3 TIMES and stay in
ON position. Within 15 seconds.
2. Push the Valet switch 2 times and hold in on the 2nd
push, when a long chirp is heard then release the valet
switch. You are now in the Transmitter programming mode.
Program:
1. Press the Lock button on transmitter 1 until the siren
responds on Car with a confirming chirp; the first
transmitter is now programmed to Car.
Exit: Turn Ignition to 'OFF' position, or leave it for 15
seconds. 3 long chirps will confirm exit.
Note: If more than 4 transmitters programmed, the system
will only keep the last four.
The Valet switch is a little Red Push Button that should be
mounted under the lower left side of you dash or in the lower
left kick panel near the E-brake pedal
Posted on Aug 13, 2010
Vertex 231 set to receive an alert tone will not trip while pagers set the same way do. They used to, 8 radios stopped performing properly within 1 1/2 months of each other
It is most likely the encoder. It sends the signal to make the radios act like pagers. Two tone radios and pagers use almost the same exact format for programming. Has anyone worked on the base station or encoder? That is where I would start. Do you have the Vertex software and cables? It could be called a timing setting. This may not be a simple fix. Is there a service shop nearby? We've worked on pagers over 30 years and VX 231's for 12 years. They simply do not stop working unless someone adjusted something.
Feb 10, 2017 | Vertex Radio Communications
Autopage XT-1100
Try to search for Autopage XT-1100 Manual. im sure you will be able to find the functions there
Apr 01, 2014 | C3RS730 LCD (C3RS730LCD) 2way 4Channel...
Autopage xt74 alarm in silent mode
The only reason that your alarm would not chirp when locking and unlocking the doors is that the system is in valet. A visual notification that the alarm is in valet mode is the LED light is on solid. If the LED is on solid and you wish to make the alarm active again, turn the ignition on then, press and hold the valet/programming switch for two seconds. The LED light will turn off.
If the LED light is not on solid then, the issue may be with siren itself.
Sep 25, 2012 | Megatronix - TW71 - 5 Button 2 Way LCD...
Program remote
Enter:
Program:
left kick panel near the E-brake pedal.
Jul 09, 2010 | RS855LCD AutoPage MultiChannel 2 Way...
I need to program an autopage xt-33 remote. the remote needs to be programmed im not sure if it has a valet chip or not
Autopage is a pretty trouble free system...but if the battery is near-dead or dead they can do evil things...swap out the battery and try again...If you can't...go to your local car stereo installation shop and ask them NICELY to help...lots of times it's free..if it is, buy the dude lunch...what, $10?
Good Luck
Jun 15, 2009 | Vehicle Parts & Accessories
Programing pager tone alerts
The scanner itself does not directly support decoding of pager tones, but if you know someone who can manage their way around a bit of soldering and hacking, they might be able to rig something up with an old pager which could be triggered from the audio output jack from the scanner.
May 15, 2008 | Radio Shack Pro-2055 Base Scanner
RS1000 OLED 2Way OLED Remote Start w 6 Channel Alarm Logo
733 people viewed this question
Top Autopage Vehicle Parts & Accessories Experts
John
John
Charles Osborn
Are you an Autopage Vehicle Part and Accessory Expert? Answer questions, earn points and help others
