Question about Frigidaire GLTF1670A Front Load Washer
How to repair door lock mechanism? Front load washer.
Re: Frigidaire front load washer # FWT449GFS1
I opened the front door of my washer and a part fell on the floor. It was the door lock latch. I got another one and installed it. When I close the door and turn on the machine, the lock light comes on and the door latches, but the washer will not start. I note that if I put pressure on the door with my hand, i.e. close it tighter, the washer activates and begins to fill. The problem is that if I release the pressure, it stops again.
My guess is that it is the expensive door lock assembly. I am reluctant to call a repair guy because of expense. If I get a new one, how do I get to the old one to r&r it? I have never had a washer apart, but am somewhat handy with tools.
4 Suggested Answers
  • 60 Answers
SOURCE: Door Rattles
Get the rubber door boot loose, reach inside to where the door latch is and remove the 2 screws holding it in. Then put the screw back in but add a washer on the inside before you screw it back into the latch. Do this on both screws and it will set the latch further in the thickness of the washers. If one doesn't work you can try 2 but make sure the door can still lock or the unit won't run.
Posted on Feb 12, 2008
SOURCE: FWT449GFS1 front door buzzing Frigidaire front loading washer
Could be rubber door boot needs replacing. I am in the midst of replacing mine because door won't stay closed and buzzer sounds till I hold in door.
scott
newcastle on.
Posted on Jan 04, 2009
SOURCE: frigidaire washing machine fwt449gfs1
Check to see that the switch is actully being activated when door is closed. I wiggled the door upward to notice the machine started working. I then wedged a piece wood or wooden pencil in the botton of the door crack and that caused the switch to activate.
Switch is okay but the door alignment needed to be fixed.
Posted on Aug 25, 2009
Frigidaire washer door catch is stuck, washer won't run
After looking at the schematic of this machine it seems that the door AND the control board have to work perfectly together in order for the safety mechanisms to operate correctly. You may have a bad control board or a loose wire. The best thing to do is look closely at a schematic and make sure that everything looks right. here is a blueprint: http://www.pcappliancerepair.com/model/index.php?id=FWT449GFS1
Jan 03, 2014 | Frigidaire Affinity ATF7000E Front Load...
I have a Affinity frigidaire front load washer and need to replace part number 131763202. The model number of the washer is ATF6000FS1 Thank you in advance
Disconnect power then open the door and remove the spring-hoop assembly that secures the door gasket. Peel off the part of the door gasket near the door lock and switch assembly. Remove the screws securing the door lock and switch assembly to the front panel then pull the door lock and switch assembly out. Transfer the wires to the new door lock and switch assembly then install into place. Put the door gasket back and secure it with the spring-hoop assembly. Click on the link below for the detailed procedure.
Replacing the Door Lock and Switch Assembly on Frigidaire Affinity and Gallery Front-Load Washing Machine
Nov 12, 2010 | Frigidaire ATF6000ES Front Load Washer
Door will not close
Make sure you are allowing the washer to completely finish its cycle before opening the door. It is normal for the door to lock at the end of a cycle. The locking mechanism keeps owners from opening the door before all of the water has been drained. If the door on the washer is locked, select the "Drain" or "Spin" options on the front-load washer. This will completely drain the water from the system and unlock the door, allowing you to open it.
Thank you !!
Jul 09, 2010 | Frigidaire ATF6000ES Front Load Washer
Can't get the door open
Thank you !!
Jul 06, 2010 | Frigidaire ATF6000ES Front Load Washer
Door lock light is on door is not locked and
Thank you !!
Jun 19, 2010 | Frigidaire GLTF1040A Front Load Washer
Frigidaire affinity door will not lock when door is closed or register door is not closed when open
Apr 21, 2010 | Frigidaire ATF6700F Front Load Washer
Frigidaire washing machine fwt449gfs1
Aug 09, 2008 | Frigidaire FWTBB30DS Front Load Washer
scott
newcastle on.
Jul 30, 2008 | Washing Machines
Frigidaire Front Load Door Lock Broken and Noisy FWT449GF
Its looks like a lid switch issue. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it. Good luck!
Sep 08, 2007 | Frigidaire Affinity ATF7000ES Front Load...
Frigidaire GLTF1670A Front Load Washer Logo
139 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
