Question about HP PSC 2175 All-In-One InkJet Printer
Its printer very very slowly -- like it spitting out a couple of lines, then pauses for 30 seconds or so and spits out a few more -- have never had this problem before; changed the ink cartridges initially as thats what it requested; have un installed and reinstalled the software; any other suggestions
  • 666 Answers
Http://www.fixyourownprinter.com/forums/inkjet/26257
this is a very detailed description of how to disassemble the printer in order to clear any ink blockage that would be causing this
hope this helps
Robb
Posted on Jun 03, 2010
How do I get my HP OfficeJet Pro 8725 printer to spit out the printed paper without force and an extra sheet?
Have the memory inside the printer tested. Add as much printer memory as you can to the printer to speed it up.
Mar 16, 2017 | HP OfficeJet Office Equipment & Supplies
HP photosmart c8100 all in one printer 10x15 photo paper spits out when ever you try to print a photo from printer .new printer thanks Ray
do the normal copies of microsoft worf comes out properly without any spitting.then its the setting problem in your printer .you can change the settings through printer properties --just adjust the photo settings in your printer and it will print the photos.
but if the word document are also having the same problem its the printer problem get the replacement as the printer is new.
feel free for further queries.
thanks.
Sep 20, 2008 | HP Office Equipment & Supplies
Every time I try to print any document, the printer will take in the first page, pause then spit the page out blank. It will then pull in a second page and stops halfway through the feed process, never to...
Your best bet would be to uninstall the printer, then shut down, and then reinstall with the most up to date drivers. Pay attention to the model you select, as it is important that it matches the driver.
Nov 08, 2012 | HP "officejet 4500 all-in-one inkjet...
What makes the bike spit and sputter then get full power for a bit then go back to spit and sputtering
check your shutoff valve on the tank you might have a small piece of junk blocking it inside your tank...easy way to tell is when you have loss of power stop and shake bike side to side
Sep 08, 2012 | 2006 Harley Davidson XL 883R Sportster
GAS SPIT OUT WHEN IM PUTTING IN THE TANK
There's an air return pipe that's supposed to prevent this. Look on the filler neck for a finger sized secondary pipe or hose. Make sure this is not damaged or otherwise blocked.
Spit back can also occur when the tank is nearly empty on hot days. The tank is full of gas vapour and this pressure has to go somewhere. Try adding gas slowly for a couple of seconds, then stopping. The added gas is colder and will cause the vapour to condense, after which you can usually add gas at normal speed.
Sep 07, 2011 | 2002 Kia Sportage
Turns over but won't start - spits only on full chook
Since it's on '01, if you've never cleaned the fuel filter, start there. Remove the tank, turn it over and remove the 2 bolts holding on the fuel tap. There is a small bag like filter in there. Remember how you take it apart. There are 2 rubber gaskets (reusuable) that have to go back correctly. The '01's have a problem with a bad gas tank lining and you will find chips of paint in the filter.
May 15, 2010 | 2001 Triumph Triumph Bonneville
HP K550 Prints One Line, then shows error message.
this sounds like, for this model, more like an os issue....try to remove and then reinstall the printer...
Aug 09, 2009 | HP OfficeJet Pro k550 Printer
1995 Jeep Wrangler 2.5 4cyl spits and sputters while driving
if you have an electric fuel pump that would explain the hum. unhook your incoming fuel line and blow the line clear, sounds like you've got some junk in your tank.it'll build up on the screen in the tank then fall off (at least partially) when your making turns or hitting bumps or holes. next time it's only got a gallon or so of fuel i'd drop the tank and check the pickup tube inside. sux but that's the only way to get to it. while you've got the tank off and out from under the jeep, might as well clean it out real good and replace anything inside (usually the screen) that doesn't look right, dirty etc. wouldn't hurt to run a bottle of fuel system cleaner in the next full tank of fuel either. preferably as soon as you put your tank back. good luck
Mar 25, 2009 | 1995 Jeep Wrangler
Tape deck spitting tape out
Time for a new car stereo. I recommend something that you can plug a flash drive into that will provide hours of listening pleasure. Repairing the factory tape deck is not going to be economical. Since the stereo has to be removed to diagnose it, much less repair it, just fill the hole with something else. If you absolutely love the factory deck, salvage yards everywhere have them available for less than the cost of a repair.
Jul 06, 2017 | Car Audio & Video
HP PSC 2175 All-In-One InkJet Printer Logo
24 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
