Question about Husqvarna EZ4824 24 hp 48" Zero Turn Lawn Mower
Electrical problem My dad has a husqvarna zero turn residential 48''cut with 24 hp briggs and stratton engine. it has an electrical problem. it would start and idle fine, then when the brake was let out it would die. we found a switch on the brake lever and replaced it. now it won't start at all. we jumped the safety switch under the seat and got it started and drove it around, but when you engage anything it dies. would this be the safety switch under the seat? it was replaced last year.
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 146 Answers
Strange as it may seem, if the mower dies when the brake is released, the problem is in the seat switch circuit. The safety circuits are designed to let you start the engine even if you're not in the seat, as long as the brake is on and PTO is off. While it might be the seat switch again, I'd also look at the the switch mounting or adjustment. If out of adjustment, it won't operate even though you sit in the seat. Also I think the associated wiring and connections to the seat switch may hold your problem.
If you're up for troubleshooting it yourself, try this:
Get an automotive test light (10 bucks or less). Clip the black lead to the negative battery terminal. Touch the pointed test probe to the positive battery terminal to confirm the tester is actually working. Lights up? OK, onward. Note that the pointed probe can be touched to a connection, but can also used to pierce through the insulation of a wire to test it.
Examine the wiring to the seat switch. One wire will go to a relay - a black module the size of an ice cube. Call that the "relay wire". The other should go to an area with several connections. Call that the "hot wire".
Engine off, nobody sitting in the seat. Turn the ignition on -- don't crank or start the engine, just turn the ignition switch to the first position. Probe into what we called the "hot wire". The test light should go on. If you can't get it to light, that wire or its associated connections is probably bad.
If the "hot wire" is, as they say, "hot", then probe the other wire to the switch -- the one we called the "relay wire". You'll have to operate the seat switch manually, or put tape over the button to keep it operated. The test light should light up, and if so, the seat switch and its connections are good. If not, then the seat switch or its connections are bad.
If everything's good so far, tape the seat switch in the activated position while you trace along that "relay wire" to where it connects to the relay. Perhaps the connection at the other end is loose, or the wire broken off inside the insulation. Use the probe to test along it and to test the relay terminal where it connects.
I hope this has been of help. If so, please rate my answer, thanks and good luck!
Posted on Jun 04, 2010
I have a zero turn lawn mower (Husqvarna R 4824 ) that it will crank and cut right back off. and then will crank but want started
Posted on Jun 03, 2011
23hp vanguard briggs & stratton repair manual
I Googled this in 15 seconds. Here's the manual in PDF:
http://www.husqvarna.com/ddoc/husi/husi2007_usen/husi2007_usen__539131361.pdf
Jun 12, 2016 | Husqvarna EZ4824 24 hp 48" Zero Turn Lawn...
Husqvarna Z246
Husqvarna Z246 Briggs and Stratton Zero Turn Mower ...
? 1:28
https://www.youtube.com/watch?v=Ohx8nxNrgNs
Feb 23, 2015 - Uploaded by SleEquipment
Husqvarna Z246 Zero Turn Lawn Mower 46" - 23 hp Briggs and Stratton Engine: Briggs and Stratton ...
Nov 30, 2015 | Husqvarna Garden
Type engine
Yes, The Engine is Briggs Model No. 445577-2187-G1
For more information, see the manual at the following link.
http://www.husqvarna.com/ddoc/HUSO/HUSO2010_NAen/HUSO2010_NAen_YTH2348_532441716.pdf
Apr 16, 2014 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
New 24 hp B&S engine running out of fuel
There is a restriction somwhere before the fuel filter, this is assuming gravity feed and there is no fuel pump for the engine.
Jun 07, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Briggs & Straton 20 HP, two cilinder engine idle speed
Surging is usually caused by a lean condition You can try to turn the mixture screw ccw about 1/4 to 1/2 turn. If this does not solve the problem your carb will have to be removed, cleaned thoroughly, and reinstalled.
May 17, 2010 | Briggs & Stratton Briggs Stratton Intek V...
20 hp intec runs wide open
24 hp briggs. replaced cam, exhaust lobe was unhardened. now it doesnt fire on that cylinder. plug is wet. spark tester shows spark,please help.
Mar 30, 2010 | Briggs & Stratton Briggs Stratton Intek V...
I have crafsman 48" riding mower with a 24 hp intek motor
Bent push rods are a function of the valve guide coming loose in the head. The valve binds and you end up with a bent pushrod. Fix: Replace head. $94.00
Jul 13, 2009 | Briggs & Stratton Briggs Stratton Intek V...
What kind of oil for a husqvarna riding mower?
Yes SAE 30 is the recommended oil for B & S engines. You can find it on amazon for good price. here: Amazon com oil 30w . Hope this was helpful. cheers
Jun 14, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Husqvarna EZ4824 24 hp 48" Zero Turn Lawn Mower Logo
984 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
