Question about Jl Audio 12W3 Car Subwoofer
One of 2 subs stopped working.
I have a kenwood KAC-9103D amp pushing 2 jl audio W3 4 ohms speakers. The amp is 500Wx1 RMS. One of my subs just stopped working. I wired it just like the JL website and amp manual explained. The subs worked great for a year. I've checked all the wiring and nothing is lose and the fuses are good. both channels in the amp are good because I checked it with the other sub. can anyone explain?
  • tylerknutson Jul 03, 2008
    I have a pioneer 760 amp powering my two obcon 10s. they worked flawlessly for about 8 months now the left one just stopped worling. I checked the wireing and all the fuses and everything. I even rewired my whole system and it still isnt working. I dont know what to do. please help.
  • 185 Answers
Ya the sub is blown or the amp channel is blown
Posted on Apr 10, 2008
You have too much power. Although the power is 250 watts a piece. you should never apply the full strength of what the speaker is made for; and if you do the reliability of your speaker will deminish. Hense only one year in your case.
Posted on Apr 18, 2008
Two questions. 1) can my amplifier over-power this sub; kicker L7 15 inch dual voice coil 1,000 watts RMS wired for 2 ohms? 2) is my amp too small for this sub-woofer? thank you for your time.
No, your not over powering your L7, your underpowering your subwoofer.
Your Kenwood is
500W x 1 at 4ohms [20-200kHz 0.5% THD]
900W x 1 at 2ohms [100Hz 1.1% THD]
Your L7 is:
Max Rec Amplifier Power (WATTS PEAK/RMS)* 2000/1000But its ok for your subwoofer, alteast your not giving it to much stress. But personaly, get another mono amplifier that would match your subwoofers rating.
Apr 08, 2011 | Kenwood KAC-9103D Car Audio Amplifier
My kenwood kac 9103d just crapped out on me and i am looking to buy a new amp but when i bought my sub the guy specifically wanted to know what type of amp i had to match it to the sub. so now do i have to...
More specifically, the amp must support the resistance of the sub, or subs. If your amp is 2-ohm stable, it can run a sub, or subs wired for a 2-ohm load. Also, whatever the recommended maximum wattage is for the subwoofer, try not to exceed this much, if at all, with the amplifiers wattage.
Jan 18, 2011 | Kenwood KAC-9103D Car Audio Amplifier
I want to know how to wire up 3 12' subs to the kac-9103d amp my 12's are 8 ohms
to get the most power to your subs from that particular amp and those 8 ohm coils just wire the coils in parallel and that will give you a 2.66 ohm load. You will be close to the maximum rated rms output power for the amp that way
Jan 29, 2010 | Kenwood Car Audio & Video
I wonder if i get two kicker cvx 10 can be push by jl audio 500.1
It can but it'd be a waste for your subs. 1 of those by itself will handle that amp. it'll push them just not really hard, i'd recommend an upgrade to a 1100-1200 watt rms amp if you're gonna run 2 cvx's. if you only run one sub that amp'll work well...
Oct 08, 2009 | Kicker CompVX CVX104 Subwoofer - 10" Dual...
Why does the kenwood kac-9103d has two sets of terminals if its a one channel amp so how do i hook up a dual 12 phoniex gold 1200 watt sub to it
Hello damasogrizzl,
The 2 sets of terminals are connected internally. Having 2 sets just makes it more convenient when wiring multiple subs. The amp is rated for 900 watts RMS into a 2 ohm load. The specs claim that it is stable at 1 ohm but does not give a power rating.
The Radial SD competition series from Phoenix Gold are rated to handle up to 600 watts RMS. If you have the model RSdC124 with dual 4 ohm voice coils, it would be best to wire the voice coils in parallel for a 2 ohm load and connect the sub to one set of terminals on the amp. If your sub is the model RSdC122 with dual 2 ohm voice coils, you should wire the voice coils is series for a 4 ohm load and connect the sug to one set of terminals on the amp. Wiring the voice coils in parallel will result in a 1 ohm load. And, while the amp may be stable at 1 ohm, the sub will be seriously overpowered.
Hope this helps.
Sep 23, 2009 | Kenwood KAC-9103D Car Audio Amplifier
Repeated blown subs
Unfortunately some of these speakers today... DO NOT PERFORM up to peak as they should.The on logical reason for this to be happening it that the speakers are NOT very DURABLE and cannot take constant playing. I would recommend to L7 the can take alot more abuse than your average speakers. Good luck and thanks for using FIX YA
Mar 23, 2009 | Kenwood KAC-X401M Car Audio Amplifier
Adjusting wattage on kenwood kac 9103 class D mono amp
That amplifier is 900W x 1 @ 2ohms.
If your subs are 4ohm SVC wired Parallel, resulting in a 2 ohm load, each sub will only see 1/2 of the rated power. (450W ea.)
Your gain (sensitivity) setting should be between 75% and 85% to max. You will be fine.
Jan 02, 2009 | Kenwood KAC-9103D Car Audio Amplifier
Power from the kenwood 9103D to the Kicker comp 15's is on n off
Most times I hear of people turning up the volume on a head unit and cutting off on the amp it tends to be wired to a speaker with the wrong impedance. I googled kicker comp and got tons of different models, not to mention almost all of them were 250 watt rms. That amp is 900 watt RMS at 2 ohms. If you only have 1 woofer, you can't possibly wire it wrong being all the subs I've seen in the results were 4 ohm. If you are using just one though, you should get a larger speaker, both 2 ohms and 1000 watt rms to prevent distortion. I'm afraid I can't answer your post without further information on the sub you are using.
Nov 20, 2008 | Kenwood KAC-9103D Car Audio Amplifier
Jl Audio 12W3 Car Subwoofer Logo
333 people viewed this question
Top Jl Audio Car Audio & Video Experts
Mark Skinner
Tygh Duval
Tygh Duval
hoyzee1
Are you a Jl Audio Car Audio and Video Expert? Answer questions, earn points and help others
