Question about Mitsubishi WD-Y57 57" Projection HDTV
My 1080P mitsubishi tv is saying I have blocked airflow. I have cleaned the light housing and made sure there is adequate air around tv. what is problem temp. sensor? It will turn off. If I put a fan to the airflow side then turn it on I have no problem.
2 Suggested Answers
  • 1030 Answers
SOURCE: Mitsubishi WD-52631 "Check airflow"
mitsubishi is aware of the problem and has issued a bulleteen on this the sensor is the problem. and needs to be replace.,.. i know of no way to bypass the sensor. sense this is a bulleteen issue item it might be covered under warrenty.... check wirh you local service center
Posted on Jan 18, 2009
I have a mitsubishi 1080p wd-65731 just replaced lamp , tv comes on works fine for about 30 minutes and then shuts off , cleaned vents good , has good air flow light that says lamp turns red in the fr
Could be the fan. It will cool tv but could also be to much for tv to handle.
You can also try reseating the lamp. It may say ok but be wrong.
I have a Mitsubishi 5500 projection tv . have had the type of issue you have had and I have replaced a lamp as well.had to reseat the lamp three times before it worked without shutting down.
Hope this helps.
Jan 14, 2015 | Mitsubishi Televison & Video
Says I need to fix airflow problem
It is telling you that the unit is overheating for a lack of air flowing over the globe. Check that the air slots are not blocked. the fan motor is working and any filters are clean and not blocked.
Apr 07, 2013 | Mitsubishi WD-62525 62" Rear Projection...
Area around TV is clear, nothing is blocking TV or air flow. When we use the TV we frequently get this message: The TV will shut off in one minute. Check to see if air flow is blocked. Happening more...
you need a new power supply unit these after some time get old and start over heating causing the tv to heat up intermediately if you take it to a repair shop and have that replaced it will be like new again
Feb 25, 2011 | Mitsubishi WD-52525 52" Rear Projection...
My tv monitor says "TV
YOU NEED TO REPLACE THE THERMOSTAT ON YOUR SET TO CORRECT THIS ISSUE .
Dec 14, 2010 | Mitsubishi WD-57732 Projection Television
Mitsubshi tv says airflow is blocked
TAKE THE BACK OF YOUR TV OFF , IT ONLY COMES OFF AT THE BOTTOM , ABOUT 6 SREWS PULL IT OFF , MAKE SURE TV IS UNPLUGED, AFTER BACK IS OFF, YOULL SEE YOURE LIGHT ENGINE RIGHT IN FRONT OF YOU, YOU WILL SEE TO THE RIGHT SIDE A LTLLE PLACE WERE THE LIGHT BULB IS ,IT HAS TWO SREWS LOOSEN THE VERY CARE FULLY PULL IT OUT ,DO NOT TOUCH THE BLUB SET IT DOWN CAREFULLY NOW GET A CAN OF COMPRESSED AIR FROM WALL MART AND A FLASH LIGHT LOOK IN WERE YOU PULL YOUR LIGHT BULB OUT AND IN THE BACK OFF THE LIGHT GEN , YOULL SEE A FAN WHEEL IT GET CLOGGED WITH DUST CLEAN ALL OF THAT AND THE OTHER WHEEL ON THE GEN BLOW THE **** OUT OF IT AND CAREFULLY PUT IT BACK TO GETHER YOU SHOULD BE GOOD
Aug 10, 2010 | Mitsubishi WD57831 Television
Jan 14, 2009 | Mitsubishi WD-52631 52" Projection HDTV
Error message
Good Day, drdeath57;
Make sure your air vents are clean but more than likely you should suspect the TV's Lamp Thermal Sensor
Aug 21, 2008 | Mitsubishi WD-52525 52" Rear Projection...
57" DLP Mitsubishi
It is possible that either the heat sensor or the protection circuitry has a problem. The protection circuits will always err on the side of caution. If the fan is good, I'd be looking for the sensor. Can you update this with the model number please? I can check for more details once I have that info.
Thanks,
Dan
May 06, 2008 | Mitsubishi VS-5043 50" Rear Projection...
Mitsubishi wd 57731 1080p
see if there is dust inside blocking it.
Jan 17, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi 1080 72in diamond seris
52" mitsubishi 1080p t.v. warning shows up on screen AIR FLOW IS BLOCKED. Check owners guide and they don't tell you how to clean it or where it si at.
Aug 29, 2007 | RCA F38310 38" TV
Mitsubishi WD-Y57 57" Projection HDTV Logo
360 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
