Question about Fisher Paykel EcoSmart GWL15
My Fisher and Paykel is broke again! It is a
My Fisher and Paykel is broke again! It is a Ecosmart. Pumps water in and pumps it out just as quickly. I have tried to unplug for several hours and plugged back in but it did not work. The warning sound goes off and light 3, 4 and 6 is on.
Mine is doing the exact same thing :S Boyfriend is going to be very mad.
Posted on Jun 10, 2010
  • Fisher Master
  • 713 Answers
OK you have a fault called recirculation error.the reason why this has occurred is the mechanical diverter inside your pump is stuck in the drain position.does your model have an EFFICIENCY button?if it has then all you need is probably a new pump .please reply and tell me if it has that EFFICIENCY button and i can guide you throe the rest of the repair
Posted on Jun 04, 2010
How do I see what is causing my Fisher & Paykel EcoSmart washer to leak water?
If it is leaking when draining this would point to the main seal of the WATER PUMP. (Quite common for older machines.)
The pump can be easily removed by leaning the machine backwards, remove wires and see picture. NOTE: about half a litre of water will gush out so it is best to take machine outdoors. Go to a recycling centre or online auction for a replacement. They can be fiddly to replace.
Jul 20, 2014 | Fisher Paykel EcoSmart GWL15
Fisher and Paykel Ecosmart GW612 rinse cycles not working all other cycles working fine
Could be that your water pump is blocked. If you have a burning smell then you need a new water pump
Apr 04, 2014 | Fisher and Paykel Washing Machines
Fisher & Paykel ecosmart GWL11 fill problem
Your diverter valve is cloged with lint and not fully closed and is letting wash water go down the drain.
Feb 22, 2012 | Fisher and Paykel GWL11 Top Load Washer
I put heavy wool items in my ecosmart Fisher & Paykel washing machine (approx 9 yrs old) and after it filled with water and drained the water, it beeped unbalance so i added something else to balance...
You should not continue to run the machine until you rectify the issue with the pump. Check the resistance of the pump's coil. It should be 7 ohms for the model GWL15. If the resistance is different, there is a problem with the pump electrically and it needs to be replaced.
Jan 12, 2011 | Fisher Paykel EcoSmart GWL15
My fisher and paykel ecosmart glw 15 fills wash but do not drain. Can it be the water pump?
yes likely to be drain pump ...more than likley obstruction ( foreign debris in pump chamber)
Feb 23, 2010 | Fisher and Paykel Fisher & Paykel Washer
Fisher Paykel Ecosmart (about 6-7 years old. Spin
better get e a new one, it is most likely the bearing , can u see small amounts of water under the machine, if u want to take the top off all there r is 2 screws under 2 D shaped covers under the lid towards the front of the machine ,,,,wont help , but it also cud be a wire in the drain pump
Jan 28, 2010 | Fisher Paykel EcoSmart GWL15
Water won't drain out of the washer
Hello there! Pump issue.....small items typically get lodged in the pump over time and plug things up. another issue could be that you broke a belt, these can be seen from underneath the washer.
Good Luck,
Geodesy
Sep 22, 2009 | Fisher Paykel EcoSmart GWL15
Washing machine faulty
needs a new pump and control maybe, its the most common sollution for that problem
Jan 21, 2008 | Fisher and Paykel GWL11 Top Load Washer
Fisher Paykel EcoSmart GWL15 Logo
130 people viewed this question
Top Fisher Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Fisher Washing Machine Expert? Answer questions, earn points and help others
