Question about Optimus STA-3500 Receiver
The right channel on my Optimus STA-3500 speaker does not work
The right channel on my Optimus STA-3500 receiver is not working properly. It does not output to my speakers. If I shake the receiver/wiggle wires/just mess with it, i can sometimes hear noise trying to get through to my speaker but with little success. This happens with both A and B speaker outs.
techman
  • 3130 Answers
SOURCE: Only 2 channels working
If your new reciver does not have a turntable input, you can purchase a phono preamp and simply plug the turntable into the preamp and the output of the preamp to an aux or tape input of the new reciver. they should have it or be able to get it at radio shack. Or look up online or build one as I had to do as im a cheap skate, but I know what I have now..Check this out. i included the preamp i built so i can still use my collection of vinal with my surround sound system. Good luck and please dont forget to rate this thread.
Posted on Oct 19, 2006
SOURCE: how to hook up TV so it can be heard on Optimus STAV 3770 system
how to hook up on my hd tv
Posted on Oct 28, 2008
robotek
  • 1512 Answers
SOURCE: My Optimus STA 3190 has no AM/FM
Hi rowdy
The fact that you are getting static at least is good. Without knowing allot of the background to your problem, first thing to check is if the aerials are correctly connected. If it is any help to you, here is an excerpt from the original owners manual about the connection of the AM loopstick.
If the aerials are coinnected right, then let me know and we can investigate other options. Cheers
regards
robotek
Posted on Dec 10, 2008
  • 4234 Answers
SOURCE: How do I reset the protection mode on my Optimus
You can not "reset" protection mode. This is an indication of a defect. Disconnect the speaker wires completely and if the protection mode remains, then the problem is internal to the unit and is likely to be shorted output transistors. Expect a parts cost in the $20-$50 range for this repair.
Dan
Posted on Mar 26, 2010
Testimonial: "Thanks"
SOURCE: I have a Optimus STA-3750 am/fm stereo receiver
I have the same receiver, but have been unable to program it with my Universal Code. I do not have the original remote. Did you find a code that controlled it? I found one website that had the owners manual online, maybe that would help: http://support.radioshack.com/support_audio/doc58/58124.htm
Posted on May 20, 2010
No sound on left channel on home stereo optimus sta-795 will changing fuse out restore sound
Not likely! Suggest swapping input connection, red RCA connector to white and white to red and see if problem swaps speakers.
If still left channel bad swap speakers left to right see if problem follows speaker.
Check balance adjustment and confirm that it is set to the middle!
Check all other inputs and confirm always no left output.
The goal is to confirm that the left channel is defective!
The service manual is MS3102101 would normally be available from Radio Shack.
Check for defective capacitors or failed solder joints on the PC board. These units are repairable even by DIY however replacement recievers are relatively inexpensive.
Hope this helps?
Nov 20, 2016 | Optimus Audio Players & Recorders
Optimus stereo receiver universal remote codes
go to link below and click the green "Notify Me" button when this item is stocked. We will inform you when we put one in stock. You must purchase a new OEM remote, universals will not work. OPTIMUS STA3750 3760 Remote Control
Apr 17, 2014 | Optimus Sta-3750 Sta-3760 Stereo Receiver...
Sta 3190
Check amplifier IC, check all board solder for dry one's.
Feb 12, 2014 | Audio Players & Recorders
I have an Optimus STA-3500 Digital Synthesized AM/FM Stereo Receiver. If I buy an i-pod is there a place on the back of the receiver that it can be plugged into? If so, what kind of i-pod wire/cable...
It won't have "iPod" functionality but it can be played through the receiver.
Any audio device that has a headphone output can be adapted to feed an RCA cable pair for standard stereo to any audio device with a standard RCA input (except one labeled "PHONO"). Get a cable like the one described here: http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10218&cs_id=1021804&p_id=665&seq=1&format=2
and connect it into any available analog input EXCEPT one labeled "Phono".
Jul 25, 2011 | Optimus STA-3500 Receiver
The volume is barely audible even with it turned all the way up. I have tried different audio cables. It occurs in different modes also, CD Tuner, etc.
Maybe you have it muted or a Tape Monitor engaged??? Never troubleshoot anything at high volume. If you can't hear it at medium it's effectively noth there. A flip of a misplaced switch would possibly blow your speakers.
Jan 16, 2011 | Optimus STA-3500 Receiver
Oct 18, 2006 | Optimus STA-795 Receiver
85 people viewed this question
Top Optimus Audio Players & Recorders Experts
Ben Armstrong
Larry Stiles
Larry Stiles
Are you an Optimus Audio Player and Recorder Expert? Answer questions, earn points and help others
