Question about Whirlpool Gold AD70USS 70 Pint Per Day Ultra Low Temp Basement Dehumidifier with AccuDry Sensing Sys... Dehumidifier
We have a hose hooked up and no water coming out...for over 24 hours. Fan going but cool air blowing out the side. Filter has been cleaned and we've had three days of rain..so there is humidity in the basement. We do have it plugged into a belkin surge protector because the cord is too sort to reach the wall plug. This machine was given to us by a fellow that moved out of the country and three weeks ago it was running fine. Maybe it's mourning it's original owner? Thanks for any help, a gaadt
  • gaadtstudio Jun 04, 2010
    We have a hose hooked up and no water coming out (so not using the container in the machine)...for over 24 hours. Fan going but cool air blowing out the side. Filter has been cleaned and we've had three days of rain..so there is humidity. We do have it plugged into a belkin surge protector because the cord is too short to reach the wall plug in the basement. This machine was given to us by a fellow that moved out of the country and three weeks ago it was running fine. Thanks for any help.
  • 2,272 Answers
If you do not hear the compressor running and the unit says that the humidity in the room is higher then the setting, then you have a problem with your dehumidifier.
A few things that can cause this are:
The circuit board relay has gone bad…replacement of this board will often cost more then a new unit. This also is a very common problem with many DE-humidification units.
The compressor has failed…if you hear a buzz for a few seconds, every few minutes, then you have a bad compressor or at least bad start components on the compressor. Either way it again is a costly repair.
If the compressor is running and the coils are not getting cold then you have a refrigeration system leak. Recharging or fixing these units is very difficult and is another costly venture compared to the price of a new dehumidifier.
If the compressor is running but the fan is not, this also will cause low water production and continual freezing of the coil.
If the compressor and the fan are running but the coil is totally blocked then you will get no water production. Air needs to be continually moved over the cold coil to get the water out of the air.
If nothing is running, then you may also have a control board failure. Or the humidity sensor or hemostat has gone bad which tells the machine to run. If the sensor says that the humidity is low enough then it will never run.
Also if nothing is running check the float switch or the bucket switch. Many of these switches are very touchy and if you do not have the bucket in place just exactly right it will not trip the switch to allow the unit to run. These switches often are more fragile then they should be and break easily. The good thing is that when available they are easy to replace and relatively inexpensive.
Thanks. keep updated for any more query.you can rate this solution and show your appreciation.
Posted on Jun 04, 2010
    Fan and compressor seem to be running fine... How do you check to see if the coils are clogged?
    My solution to this problem was to just shut it off and use our old dehumidifier that we got at Sears 25 years ago...still works. Big and clunky but they certainly don't make em like they used to.
    Thanks for the info.
    Top Expert:
  • Whirlpool Master
  • 75,797 Answers
These don't work in humid climates, the humitiy must be bleow 25% or you are wasting your money running it, if the water is running and the filter is wet then that is all you can do, just make sure the float valve is working and the pump running.. sorry.
Posted on Jun 03, 2010
  • gaadtstudio Jun 03, 2010
    These don't work in humid climates?....I thought that was the purpose of dehumidifying? We live Near Pgh PA so humidity is not a constant problem. It worked three weeks ago 15 miles from here.
  • yadayada
    yadayada Jun 04, 2010
    it is pretty obvious the machine is defective, whether or not u want to spend the $100 on a service call is the question here, since i really doubt u will be able to repair it without professional help.... Wiz
I HAVE AIDYLIS DEHUMIDIFIER#0526011 THAT WHEN HOOKED UP WITH A FLOOR DRAIN STILL LETS WATER GO DOWN INTO THE CATCH BUCKET AND NOT COMPLEATLY OUT THE DRAIN
id ck the drain hose connection for build up of fouling material , the symptom you describe usually occurs when the hose cant drain all the water the machine makes
a wet/dry vac is perfect for this (set to wet) and some even allow you to turn airflow around to blow air as well , this is perfect to clear a stopped up hose (point end into bucket)
Nov 28, 2015 | Dehumidifiers
What should I do when the air filter light comes on?
Good Afternoon Friend, that's a great question!
Typically the FILTER RESET light will illuminate after 250 hours of operation. To locate the filter, remove the bucket and the pull filter downwards. The filter can be clean by using clean water or vacuum cleaner extension hose. If you use clean water, please allow the filter to dry. Once you reinstalled the filter then replace the bucket. To extinguish the light simply press the FILTER button and your dehumidifier should resume normal operations. Remember it is best to clean your filter every two weeks based on normal operating conditions. Hope this helps! - Z
Sep 11, 2014 | Frigidaire FDL50R1 Dehumidifier
No water collected
check to see if the fan is blowing across the condenser. there should be warm air blowing out the back. if there isn't, the fan may need to be replaced so the heat exchanger can cool down. may be running too hot. also check the condenser in the front to see if the air flow is blocked with dust. if so, change the filter if it has one. if there is cool air blowing, the compressor may not be turning on.
May 11, 2012 | Dehumidifiers
My dehumidifier just started not producing water. It has a hose hooked to it so it can drain all the time. It will turn on and the motor speed will raise and lower continually. The filter was cleaned and ...
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Sep 04, 2011 | Maytag M7DH65B2A Dehumidifier
Lg dehumidifier lhd30 normally removes an almost full bucket of water from my basement every 24 hours. Now in July it stopped doing so. I get about an inch of water per day now. If i turn the control down...
There are 5 basic, but solvable reasons for what you described. Please pay particular attention to numbers 1& 2.
1. The humidity extraction level is set to HIGH. Lower it to 32-35%. If you have a mechanical unit,
uni, set the control knob to Maximum.
2. Air intake filter is dirty or clogged. Turn unit OFF, & Unplug the
Unit, before removing to inspect & clean it, if necessary. If washed,
allow filter to completely dry before reinstalling. DO NOT operate
the unit without the filter.
3. Obstructed air flow. Maintain a minimum of 12 to 18" of clear air
space around the entire unit.
4. Cooling coils are dirty and need to be cleaned. Use warm water & dish washing liquid to
clean the coils. Rinse and wipe dry. Apply a light coating of WD40 to the coils.
5. Ambient air temperature at floor level is between 40 - 60 degrees.
dehumidifiers do not work well between those temperatures
(Unless, you have a Low Temp Unit). This applies mainly to
where the air temperature at floor level is colder than at shoulder level
in basement applications. Raising the unit up off the floor,
onto a sturdy table, counter top, etc, that can handle the weight
of the unit, plus a full tank of water, will usually resolve this
problem.
If none of the above solves the problem, it may be a case of the compressor needs to be recharged with refrigerant gas or that the humidity condenser sensor may have failed. These things usually occur in units that are 5 years old or older. It's rare in a unit younger than that. But, it can happen.
Hope this helped you to troubleshoot & solve the problem.
Aug 07, 2011 | LG DH305 Dehumidifier
My dehumidifer collect water but the fan blows hot her so it makes the room hotter
This may be caused by running the unit in continuous mode, rather than timed mode. The heat is generally is generated when the defrost mode cycles on, to defrost the cooling coils. This happens more frequently, if the air space around the unit is obstructed or it's operating in a temperature range of 40 to 60 F. Cleaning the air intake filter at least once a week, can help solve this problem, too.
Maintain a minimum of 12" free air space around all sides of the dehumidifier. Use a timed mode rather than a continuous mode. Make sure the room is within the proper operating temperature range and clean the air intake filter weekly.
Hope this helped you troubleshoot and solve the problem.
May 28, 2011 | Maytag M7DH65B2A Dehumidifier
I have the same problem--no water comes out.
make sure the front vent/filter is clean and free of debris. if there is not sufficient airflow across the condenser coil (front), it will not cool down. if it does not cool down, it won't remove the water from the air.
Aug 07, 2009 | Amana D545M Dehumidifier
Humidifier Runs but no water collected
Are you talking about a dehumidifier or a humidifier. If you are talking about a dehumidifier, it works by blowing air across a cooling coil causing condensation and the water will drip and pool. The cooling is caused by a compressor working like refrigerator, but using the effect to dehumidify. To check if the cooling coil is working there will be a metal can like in it with tubes in and out. One of the tubes should be warm(input) and the other tube should be cold, if not your compressor is not working. If freezing up, low freon. Check to see if the compressor shuts off very quickly, that would be too much freon. This is not user servicable. Now a humidifier works several different ways. One way is a fan with cloth belts rolling through water using evaporation to humidify. Another way is for a circular fan like on a motor to turn. It has a hollow piece into the water. It picks up water and then through centrifugal force aerates. One way is for a sonic humidifier. All the types have a problem with eventual calcification or mineral build up in the water handling paths. Lime-away or Concentrated Lemon Juice will dissolve this. The lemon juice is the most fun. It will turn your toilet bowl white and also remove rust stains from laundry...
May 01, 2007 | Maytag M7DH65B2A Dehumidifier
Whirlpool Gold AD70USS 70 Pint Per Day Ultra Low Temp Basement Dehumidifier with AccuDry Sensing Sys... Dehumidifier Logo
177 people viewed this question
Top Whirlpool Dehumidifiers Experts
Bill Long
Michael Van Der...
Michael Van Der...
Mike Squire
Are you a Whirlpool Dehumidifier Expert? Answer questions, earn points and help others
