Question about Frigidaire 16.5 Cu. Ft. Top-Mount Refrigerator - White
Freezer is defrosting. Compressor turns on, then off
  • Frigidaire Master
  • 43,501 Answers
As the weather is getting warmer for many people their freezerFreezer is defrosting.  Compressor turns on, then - 2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Posted on Jun 04, 2010
Tip
What do do if your fridge/freezer is not cold
5 reasons for fridge and/or freezer getting warm:
1- the evaporator coils are icing up and won’t let air circulate.
2- the evaporator fan is not working to circulate air.
3- there is no refrigerant in the system.
4- no power to fridge or compressor.
5- the condenser coils have no air circulation
check under the fridge behind the vent. if it is too dusty or the fan isn’t working, it is not getting enough airflow to cool down. replace fan and/or vacuum out the dust.
if there is no power to the fridge, the light will be off. if the compressor is not running, there is a defrost timer that cuts the power temporarily to the compressor to melt ice on the coils. it’s located under the fridge behind the bottom vent. If the timer is off and the compressor is not going, the compressor or the main board is bad and needs replacing. there is also a temperature sensor on the evaporator coils that tells the defrost coil to turn on and when to turn off. if the defrost timer is on but the coil is not heating up, replace the sensor. if it still won’t heat up, it’s the timer or the coil.
the easiest way to tell if there is no refrigerant- the freezer wall is warm and the compressor is loud. if there is no refrigerant, it may be more cost effective to replace the fridge.
if you feel no air coming from the freezer vent, the fan needs replacing. If you feel air moving in the freezer but not the fridge, the channel from freezer to fridge is blocked.
if the freezer has air and the rear freezer wall has frost on it, the evaporator coils are iced up and need defrosting. causes:
1. low refrigerant
2. no fan
3. too much humid air in fridge/freezer due to door open or bad door seals
4. the condensate drain tube is clogged
5. defrost cycle not functioning properly
if the seal around the door is ripped or not completely sealing, or there is condensation at the bottom or the walls of the fridge, replace the seal(s).
no air, no fan. Replace
if the refrigerant is low, it just needs a top off. but you need to be certified by the epa to move refrigerant, so get a professional.
there defrost cycle starts with the timer. at a certain time of day for a specific time, the timer turns the compressor off and turns on the heater element located at the bottom of the evaporator coil. this stays on until the coil temp sensor reaches a certain temperature to let the timer know that the coils are defrosted and turns off the power to the element. the defrosted water drains to the condensate pan. if the timer is bad, it will never go into defrost, or never get out of it. if the element is bad, the coils will never defrost. if the temp sensor is bad, it’ll go into defrost, but it will either tell the timer that it’s always frozen or already defrosted, resulting in the element never turning on (stays frosted) or never turning off (eventually burning out the element).
on Dec 02, 2009 | Refrigerators
I have a Kenmore upright freezer model# 253.9260210. We noticed that our food was starting to thaw. I opened up the coil area and noticed a small piece of ice on the coils. I melted the ice and turned...
Feel top of the compressor and tell me how hot after it has been running awhile. I need also that you advance the defrost timer=>. 216517400 Defrost Timer
clockwise slowly untill the compressor stops or starts. I need to make sure the timer is not stuck into defrost. I want you to leave the compressor off for up to 35 minutes. If the freezer compressor doesn't restart bt then simply again turn the timer clockwise slowly until it does and then stop turning. The defrost timer is location 23 in this photo HERE If you need to turn the defrost timer like this to restart the compressor then replace the defrost timer and this will resolve the freezing problem. If not we move to the defrost heater location 14 in the sme photo=> 216254600 Defrost Heater
I am going to stop here until I hear from you, Thanks Sea Breeze
Dec 08, 2012 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Sanyo side by side door fridge is not defrosting, what to do?
bonjour,
Trouble comes in 3's
If there is never any water in the drip pan under the refrigerator it is not defrosting and the evaporator drain line may be stopped up. Side by Side refrigerators cool the freezer first and send a small amount of cold air to the refrigerator side. To start defrost the defrost timer stops the compressor and all fans. Next it turns on the defrost heater. This melts the ice/frost off the freezer coils. The water drips down the drain line to the drain pan under the unit. If the defrost heater raises the temperature too high the defrost termination thermostat turns the heaters off. When the defrost timer finishes it turns off the heaters and turns the compressor and fans back on. If the drain line clogs with food the water does not drain out and when the compressor starts again the water freezes. If this keeps happening the ice gets higher and bigger until it clogs the coils and the freezer does not get cold. If the defrost termination thermostat turns off the defrost heaters too soon all the frost is not melted from the coils. And the coils soon clog and the freezer gets too warm. No defrost usually means either a bad defrost timer, a clogged drain line, a bad defrost termination thermostat or some combination of the three.
If the drain line is not stopped up you can try this.
Remove all food from freezer and refrigerator, open the doors and unplug the cord. Wait 30 hours for all the frost to melt.
Keep the doors open and the cord unplugged the whole time. Empty the drain pan to keep it from over flowing. After 30 hours plug it back in and wait for 1/2 cup of water to turn to ice in the freezer. Then you can put the food back in. The problem can return if the unit is not defrosting. Or you can call a service technician.
Jul 11, 2012 | Refrigerators
My freezer keeps defrosting. I have tried unplugging it and plugging it in and turning down the temperature but it still continues to go into the defrost cycle or not work the fan completely turns off in...
i think that what you call the defrost is just the compressor not running so it warms . a defrost cycle does turn the heaters on for about 28 min and then goes baci into cold cycle . so if compressor is not running enough look for bad relay on compressor or bad control board that keep thins in ck .. mm
Aug 18, 2010 | KitchenAid KSCS25FKSS Side by Side...
Freezer just stopped working
Is this a frost free freezer? If it is, and the compressor and refrigerant is good, the problem probally lies with the defrost timer. What the defrost timer does, at regular intervals, typically every 12 hours, shuts down the compressor and powers up a defrost coil to melt any frost that has built up on the cooling coils inside the freezer. It probally the small square box that you mentioned. Some have a hole where you can turn the cam to the timer and that should switch the power from the defrost coil to the compressor.
Hope this helps.
Jun 27, 2010 | GE 25.1 cu. ft. / 711 liter Chest Freezer...
Not freezing
Either the defrost circuit has failed or the refrigerant is low - my money is on the defrost circuit.
Most defrost circuits have three main parts:
1) defrost electric heating coil
2) defrost terminator
3) defrost timer.
The heating coil and terminator are in the freezer compartment - behind a protective panel. The heater is usually piggy-backed on the freezer coil and the terminator is in contact with the freezer coil to detect its temperature. The defrost timer is a simple assembly of a clock motor with switch contacts that can be located anywhere the manufacturer desires. The timer turns on or enables the defrost circuit every 8 or so hours for up to 30 minutes give or take.
When the timer has enabled the defrost cycle, the cooling mode ceases; the compressor shuts off and power is sent through the terminator to the heater. The heater warms and melts any ice build up on the freezer coil. The water drips to a pan and flows down the tube to a pan under the fridge - where it is evaporated off. The heater warms the freezer coil until either a) the timer returns to cooling mode or b) the terminator senses a preset rising temperature on the freezer coil. Once either condition is present, power is interupted and heating stops. The compressor is energized through the adjustable thermostat in your fridge. Since it is warm, the compressor turns on and cooling begins.
If any of the components listed above (1,2 or 3) have failed, the defrost cycle never warms the freezer coil and the ice never melts to clear the freezer coil as intended. Air can not be circulated through the freezer coil since it is choked with ice, so even though the compressor runs, the fridge and freezer spaces never get colder. The adjustable thermostat never sees the temperature you've set so the compressor never shuts off.
Water dripping in the fridge is melting ice from the freezer space - as the freezer is not getting colder - only the protected space around the freezer coil is.
To fix this, you'll have to get the service manual or schematics for the fridge to determine where the parts are located and do some troubleshooting with a multimeter after disassembling the freezer compartment and wherever else to access the timer if needed. This is not a good first appliance repair job for a DIYer due to the danger of refrigerant and testing live electrical parts in closed in spaces.
I hope this helps.
May 20, 2010 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Freezer does not freeze fast enough, icecream gets very soft. The refrigerator is set on temperature level 9 and is not cold.
Setting the control to 9 may make the freezer ice up too much to work right. You can start with a manual defrost. That takes a long time, because the ice is below the freezer liner, stuck in the coils. You'll have to move your food elsewhere, like a cooler. I always take the freezer apart to get at the coils, use a hair dryer to melt the ice. Then you can check the defrost coil, it's like a toaster element. After all that, check the defrost timer too. It's usually down by the compressor area, about the size of a cell phone. It has a small dial on it that only turns one way. Mark it when the fridge is on with whiteout to see if it moves. It moves real slowly, so you will have to wait a half hour or so.
One way to speed up a defrost is to turn the dial on the defrost timer until it clicks. Then the compressor will turn off and the defrost coil will turn on. The freezer fan should be spinning. Feel the output from the freezer fan- anything? If no flow, you're iced up. Keep checking for flow, eventually it should get cold. When you get good airflow, and maybe it's not so cold anymore, you might be defrosted without having to take the whole thing apart. You may have to turn the dial more than once, if the compressor comes back on before you're defrosted. You can help the defrost with your hair dryer thru the vents in the front of the freezer, but not too hot, you don't want to melt any plastic.
Apr 25, 2009 | GE GTS18ABSWW Top Freezer Refrigerator
My freezer's defrost systems runs constantly
i dont think so i would look at the compressor kicking out on thermal overload or a faulty thermostat thermostats have two settings cut in cut out your cut in could be bad and not turning the compressor on till the temp reaches melting temps now if your hearing a click buzz then you need to look at the compressor and make sure the compressor fan is running but its not a defrost promblem
Sep 11, 2008 | Frigidaire Freezer Refrigeration White...
Upright freezer not cold enough
IF THE FREEZER IS AUTO DEFROST, DO YOU SEE A FROST BUILDUP ON THE BACK WALL? IF SO, YOU NEED TO DIAGNOSE THE DEFROST FAILURE. THERE ARE THREE ITEMS TO THE DEFROST CIRCUIT. THE TIMER, HEATER, AND BI-METAL. FIND THE TIMER, USUALLY ON THE BACK OF THE FREEZER DOWN IN THE CORNER NEAR THE COMPRESSOR. IT WILL HAVE A CONNECTOR WITH FOUR WIRES ATTACHED TO IT. IT HAS A KNOB THAT CAN BE TURNED TO PUT IT INTO A DEFROST CYCLE. WITH THE FREEZER RUNNING, START TURNING THE KNOB UNTIL THE COMPRESSOR STOPS. THAT WILL BE THE DEFROST CYCLE. THEN WAIT 5 MINUTES AND LISTEN IN THE FREEZER FOR A SIZZLING NOISE AND LOOK FOR A GLOWING FROM THE BACK BOTTOM. IF THE HEATER IS ON, THE TIMER IS THE PROBLEM. IF THE HEATER IS NOT ON, THE HEATER OR BI-METAL IS AT FAULT.
IF THE FREEZER IS NOT AUTO DEFROSTING, CHECK TO SEE IF THE COMPRESSOR IS RUNNING. IF IT IS, ARE THE SHELVES ALL FROSTED? IF NOT, YOU HAVE A SYSTEM FAILURE. IT COULD BE A LEAK, RESTRICTION, OR FAILED COMPRESSOR.
Apr 02, 2008 | Frigidaire 12 cu. ft. / 340 liter Upright...
Frigidaire 16.5 Cu. Ft. Top-Mount Refrigerator - White Logo
146 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
