Maxtor hard drive
hope you can help me, ive had a maxtor diamondplus 9 80 gb hdd running as my slave hard drive for bout 3 years with no probs.
but now the bios cant read the hard drive as its product name only the family name calypso, have done some research and found out this indicates a firmware problem,but not sure how to flash the hard drive with th firmware to rectify the problem have u any ideas.
  • 50 Answers
I've included a link to a location where you can download the firmware repair utility that covers the drive you've mentioned.
Post back if you have any further concerns.
Posted on Apr 09, 2008
What are the jumper settings for the maxtor 9064004 6.4 GB HDD?
Most computers 'nowadays' dont really need jumper settings, usually the best approach is to have all your drives on the same ribbon cable, on "cable select" if thats not an option, 'slave slave(or just slave depending on the drive)' will work just fine.
Mar 01, 2011 | Maxtor Hard Drive
I am looking for a user guide for a Black Armor 320 GB Maxtor, ¿can you help?
why would you need one ? Maxtor has a jumper label
on their face that is all the info you'll need to operate
this HDD , the rest is in the OS set up NTFS or
FAT32 , stick with the NTFS and you'll have no
problems , the jumper label indicates using as a
master , Slave or a Cable select , the IDE cable
in your computer if using an ATA HDD has two
connections the top one is the master the lower
one is the slave , if the HDD is a SATA it has its
own special connection which is marked SATA
Jan 19, 2010 | Maxtor Hard Drive
Jumper settings for a maxtor N256 master with slave
Select the maxtor HDD as master by setting the Jumper to the extreme left of the hdd; i.e. next to the data cable.
Remove all jumpers from the other HDD which you want to put as slave.
Sep 02, 2009 | Maxtor DiamondMax 80 (96147H6) 61.4 GB...
Slave Jumper settings NEEDED on Maxtor 9172808 ...17 G Hdd
Looks like the model number is 91728D8 for 17 Gb HDD DiamondMax 4320 Ultra ATA. Hope this helps.
Jul 10, 2009 | Computers & Internet
PC will not see Maxtor 80GB DiamondMax Plus 9 as seconary slave.
Two thing,
First, never use a Maxtor HDD as a slave to a CDROM/DVD, doesn't work and tends to cause stability issues. So try swapping the jumper on the CD/DVD to slave and setting the Maxtor to Master, this should get it working.
Second, if it is showing up as 33GB, you have the Jumpers set to limit capacity(designed to avoid troubles on older systems. If this is the case, you likely have a single jumper in the center row of pins between the power and data cables. If it only works as master at the moment, then you likely have the neter row(limit size pins) and the one closest to the data cable(Master Pin) both plugged in.
Change your DVD/CD to slave, remove the limiting jumper and ensure the Master jumper is installed on the Maxtor, then be sure the end connector on the ATA(likely marked master) is plugged into the Maxtor and the middle connector(Slave) is plugged into the DVD/CD, this should have you all fixed up.
Hope this helps FixYa,
May 19, 2009 | Maxtor DiamondMax Plus 9 80 GB Hard Drive
Hard drive was freezing up .i have already replaced and reloaded
On the back of the hdd you will see a row of little pins in groups of 2 vertically. It will be marked either right above the pins or on the top of the hdd above the pins, ma, sl, cs. The setting for slave is sl. Put the plastic jumper cap on those 2 pins & it is set for slave. Hope this helps & please remember to rate my answer. Thanks.
Jan 22, 2009 | Maxtor DiamondMax 60 (33073U4) 30.7 GB...
Maxtor 90845D5 EIDE HDD jumper settings
Connected the 2 pins furthest away from the power connector.
Pin 1
J1 IDE Connector | J2 Power
| .................... || @ * * * || X X X X |
| .......... ......... || @ * * * * || X X X X |
J50 Master/Slave -----+ | | | | | | | +-+12V
J48 Cable Select -------+ | | | | | +---+12V Return
J46 4092 Cyl Limitation---+ | | | +----- +5V Return
J44 Factory Reserved -------+ | +------- +5V
J42 Factory Reserved ---------+
Hope this helps.
Jun 28, 2008 | Maxtor Hard Drive
Dear noggin
is the jumpers set correctly . to slave or try cable select
Mar 02, 2008 | Maxtor Fireball 541DX (2B020H1) 20 GB Hard...
Computers & Internet Logo
David Payne
David Payne
