Question about Sony Video Cameras
My Sony DVC-TR11 will no longer play tapes.
The tape tray for my Sony DVC-TR11 will no longer retract when I put a tape in it, so I can no longer record or play tapes.
Only when there is no tape in the tray does the tray retract. I've got tens of tapes I can no longer play back. Can anyone help?
My comcorder does not play tape
Posted on Jun 12, 2010
Snowy picture
Clean the video heads. You can get a head cleaning tape. But the best solution is to take the top cover off and spray the Video Head with Servisol Video 40. Use cotton buds to clean any bad dirt off. Clean all the surfaces the tape touches. Allow to dry before putting a tape in. You might have to do it more than once. It will also take longer to clean if someone in the house is a smoker.
Sep 15, 2013 | Sony Televison & Video
Hi Donald. not sure how many calls you get from
The fault seems to be in the sensor and the mode switch of the loading system which is connected with the main controller processor and loading driver.
This can be a failure of the tape end detector which is a IR - infra red- emitter which is placed in the center of the tape tray and MUST feed continuous signal to the END IR detectors placed at either ends.
Also the tape seems to load with a false detection of the cassette within when the tray is closed for this reason of the failure along with a possible misplaced mode switch settings. This triggers to make the loading move without a reason and so can be due to failure of the the mode switch or unbalanced settings.You will need some experience to remove the tray unit, then check on the IR sensors and also check the settings of the loading drive and mode switch.
Nov 27, 2011 | Cameras
My canon dvc keeps telling me to reject my tape. It retracts just fine. But it won't let me record or play back. please help!!
I have the same problem. The only solution I've found is to manually wind the tape forward about 15 seconds and it works fine again. The problem only occurs if I let the tape wind all the way to the beginning.
Aug 03, 2010 | Canon ZR100 Mini DV Digital Camcorder
Loading tapes
I have the same problem. If I remove the battery for a few seconds, then replace the battery and wait about 5 seconds, the tape compartment closes.
Dec 10, 2008 | Sony Handycam HDR-HC7E DV Digital...
I found a loose part in the VCR bay I'd like to reinstall. Part #T5B
I found that part #T5B was on the bottom of the VCR tape tray on the right side of the VCR tape bay opening and was spring activated by inserting the tape to allow the tray to retract into the player mechanism. Without a tape installed, part T5B prevents the tape carriage from retracting.
However, I still couldn't get the whole mechanism timed properly, and gears were skipping teeth, the mechanism was still binding, and shutting the power for the whole player down. Therefore, I removed the rubber drive belt that operated the VCR tray insertion/ retraction process, and disabled the VCR side from operating at all. This allowed the power to remain on and allow the DVD side to work properly.
This worked only for the Phillips DVP3150V/37. I cannot say for certain if other Phillips players are the same.
Oct 12, 2008 | Philips DVDR3435V/37 DVD Recorder/VCR
DVC recorder
The physical tapes are the same size, but the encoding on the tapes are different. Unless the panasonic recorder can play DVcam, you're out of luck.
Dan
May 08, 2008 | Panasonic AG-DVC200 DV Digital Camcorder
Tape stuck in VCR
could be that you're looking at a blown cartridge for that vcr tape. You may need to cut the tape, to extract that from the unit.
The play head would usually retract when the cartridge is removed, BUT could be compromised by some tape getting into the play head mechanism, and jamming.
be particularly careful with anything pointy or sharp, as the tape head does NOT like those objects near the read surface.
Mar 02, 2008 | Philips CCC132AT 13 in. TV/VCR Combo
Mini DVC Tape
Hi Luigi, Have you tried playing the tapes on a different camcoder we would want to start by a process of eleimination.
Apr 20, 2007 | Fuji DVC-M60 Mini DV Tape
Video Cameras Logo
174 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
