Just got an old zenith stereo cabinet with turntable. The turntable motor runs, but the turntable itself will not turn freely. Any advice on how to "get in there" and free up the mechanism?
  • 105 Answers
In between motor pully and turntable there is a idelar wheel just replact it
Posted on Jun 04, 2010
Does old Zenith Allegro Console Stereo - 8 track/AM/FM/turntable, have a belt drive phono? I can see metal gears to drive the stuck turntable .
The manufacturers of such items would usually buy in such hardware as record turntables from fairly standard catalogues.
One popular brand of turntable was the BSR but the design of other brands were similar. The metal gears aren't for driving the turntable but to drive the multichange mechanism so when one record has finished playing another will drop from the stack loaded onto the extended centre spindle.
This type of turntable is driven by a synchronous motor with a multidiameter spindle via a moveable idler wheel equipped with a soft rubber tyre. Lack of maintenance causes many problems and as the rubber tyre ages it tends to harden and lose traction on the inside of the steel turntable so when the record reaches the end and the metal gears engage there is insufficient torque and everything stops.
It is for that reason many older examples have had the multichange removed or disabled.
Removing the turntable centre motif should reveal a circlip which when removed will allow the turntable to be removed for maintenance.
Jun 07, 2017 | Zenith Televison & Video
Old Zenith Allegro Console Stereo (made in England). - Turntable will not turn; tone arm does not move, even on "manual."
remove the flat rubber platen cover to expose the lock ring at center (horseshoe clip) remove this lock ring and pull the platen straight up and off , under there you should find a rubber tire and the drive motor shaft , turn unit on , you should see motor turn and then it should move rubber tire , if not , your going to need to replace it or clean it up and lube it
Jun 06, 2017 | Zenith Audio Players & Recorders
Can you replace the turntable in a vintage Zenith Console sterio with a newer turntable?
Generally speaking all you need to do is find the left and right channels leads from the old deck to the amp, cut them off or if thy plug in somewhere unplug them, then you can connected the playback leads of the new deck to the amp and it will then play back.
Jun 22, 2014 | Audio Players & Recorders
Have a 1974 RCA stereo model:VCY350 I'm not
To what kinde of AMPLIFIER is the table connected to?? does the AMP have a PHONO input??? if not what input you are using on your amplifier??? or is this an all in one (cabinet) system??? can't google the model I guess it's to old even for a 43 year old tech. like me ha! (I was only 6 in 1974)
More information pleas!!!
May 26, 2011 | RCA Audio Players & Recorders
Trying to find a way to get the turntable of a Zenith Allegro Console to work. We have turned to whole unit on and off. AM and FM radio plays. Turntable doesn't turn. At the bottom right of the turn...
Lift the turn table off the case and check the belt if it has one or the idler wheel that mechanically turns the table. Also check the motor to see that it rotates when you simulate a record play moving the needle carrier towards the center, The power must be on to test it. Becareful not to touch the 115 VAC line.
Oct 29, 2010 | Audio Players & Recorders
Vintage turntable turns slow for few minutes then speeds up,,,why
The tubes are only in the audio amp portion of the stereo, and have nothing to do with the motor that turns the turntable.
Most likely it's that the grease on the motor is old and gummy, but becomes less viscous when it warms up.
Jan 24, 2010 | Numark TTX Turntable
Need to replace a turntable belt on a zenith
Try this company? email them at this link but remove the <remove> from the address?
service<remove>@turntableneedles.com
Oct 16, 2009 | Audio Players & Recorders
I just inherited an old Zenith console turntable and stereo combined. Stereo sounds wonderful, but when I play records, the sound isn't loud. Is this a problem with the needle or what? When I touch the...
Hiya, check and be sure the turntable is plugged into correct inputs, "phono"
If thats OK, then probably is the stylus but could also be the cartridge itself. Check the wires on the back of cartridge make sure they are fixed properly. If all Ok, then start with a new stylus first.
Hope it helps
Jul 25, 2009 | Audio Players & Recorders
I HAVE A KENWOOD MICROWAVE GT/AL17,THE TURNTABLE HAS STOPED TURNING, ANY ADVICE MANY THANKS. TONY Nr IRRLAND
Two possibilities: either the turntable coupling is broken or the turntable motor has quit. The plastic coupling can wear or crack so it no longer fits properly on the turntable motor shaft. Then even though the motor still turns, the turntable doesn't. Or the motor itself may have stopped working. If the plastic coupling still looks normal and you can't rotate it easily by hand while it's in place, it's probably the motor.
I'm here in the US so I can't suggest where to find parts, but you should be able to locate a supplier who might have replacements available. Of course the oven will still work without the turntable running. You'll have to open the oven occasionally and turn the food yourself to insure even cooking.
Jun 03, 2009 | Whirlpool MH7140XF Microwave Oven
Microwave turntable won't turn
Most likely the turntable motor itself is bad - not an uncommon problem for that model.
Check with www.martinmicrowave.com (toll free 1-877-894-0035)
unfortunately, the particular motor used in your model is rather expensive - + - $50
Dec 23, 2008 | Sharp R-930AK Convection/Microwave Oven
845 people viewed this question
 Grubhead
Grubhead
