Question about GE Profile Stainless Bottom-Freezer Refrigerator with Internal Dispenser 22.2 Cu. Ft. - PFS22SIS
Water leaks on the floor occassionly may happen during defrost GE Model TDC18PAAWW
  • 713 Answers
Hi,Before jumping to conclusions about why your refrigerator is leaking, do a thorough inspection. Many times, it will be easy to see where the water is coming from and from that point deduce the problem. For instance, water leaking from the back is usually due to an ice maker issue, water from the side of the refrigerator is usually due to a faulty door or gasket, a leaking drain pan,a clogged defrost drain pan.
Thanks and good luck
Posted on Jun 03, 2010
Ice maker leaks on floor when I turn on after awhile
Hello:
is the water coming from the ice maker for sure?
It could be that you may have clogged defrost drain line and the water has no where else to go but the bottom of freezer..Defrost happens roughly every 8 hr or so...
Jul 11, 2017 | GE Refrigerators
Tdc18paaaww leaking ice buildup
Is this auto-defrost model? Usually, heating element that defrosts the ice in back of freezer can go bad. How old is the model?
Dec 29, 2013 | GE Profile 22.2 Cu. Ft. Bottom-Mount...
Model # GSH22VGPC CC water leak
Evaporator condensate should go to pan for evaporation. If the amount exceeds pan capacity during defrost cycle it could overflow to the floor.
Sep 03, 2017 | GE Refrigerators
Gss25jepccc water leaking somewhere in freezer. collects in bottom and leaks on the floor
There are many reasons for this happening for example water leaking from a water supply line for the dispenser or ice maker, a crack in the defrost pan, water leaking inside and draining through the refrigerator cabinet, but most are cased by a defrost drain line blockage. Below is a link that may be helpful so try to take it all in and use the parts that most refer to your specific problem, Thanks Sea Breeze
click on link below
Sep 07, 2009 | GE GSS22JEPCC / GSS22JEPWW / GSS22JEPBB...
Model GSL25JFPH BS freezer starts to defrost then will re-freeze. this is causing water to pool up in bottom of freezer. when defrosting, water is leaking out from under door onto floor.
If it defrost normally it will defrost about every 10 hours. If this is happening many time a day the control board is the reason for the problem. Now if it is defrosting and the water is coming from the rear of the freezer the defrost drain is blocked. the part number for the mother control board is WR55X10942 Your defrost thermostat may also be stuck and causing the temperatures to increase drastically. I would like to follow up with you on this problem if you don't mind
Sea Breeze
Aug 26, 2009 | GE Refrigerators
Model # TBX18TRBR large puddling leak on floor, think has to do with defroster messing up?? A GE refrigator serial # HG539639
I've got the same fridge with the same problem (believe it or not it was manufactured in 1992 so it's a wonder it's still working).
I also have been able to narrow the problem down to a defrost issue. It appears as the coils are defrosted, the leaking water drains down through the inside of the fridge, pools in the bottom of the fridge (under the bottom drawers), then when that area is full it runs out onto the floor.
I'm still troubleshooting and will post back here within a week with my results.
Aug 22, 2009 | GE Refrigerators
My GE Profile fridge periodically (eve other n) leaks water
Thaw out the defrost drain in the freezer. It has frozen over and the defrost water has nowhere else to go except on your floor.
Apr 08, 2009 | GE Refrigerators
GE TFX20JR side by side/water leaks out freezer during defrost
Yes, you are correct, that is a drain. Use a turkey baster with hot (not boiling) water to flush out the drain tube until water will flow out into the drain pan under the refrig. (where the air blown over it will cause it to evaporate)
Jan 06, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Question about water leaking on the floor under fridge
remove and reinstall water filter, possibly o-ring got sideways during installation.
Mar 21, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Profile Stainless Bottom-Freezer Refrigerator with Internal Dispenser 22.2 Cu. Ft. - PFS22SIS Logo
374 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
