New air conditioner not cooling air blowing same temp as fan
    Guru:
  • 587 Answers
If the blower is running and the unit is not cooling, then either the compressor isn't running, low on charge or there's a wiring or electrical component problem. Unless you are very fimiliar with a/c and electrical, it would probably be best to call a HVAC company and have them check it out for you.
Posted on Jun 04, 2010
Why is my portable air conditioner blowing out room temperature air?
Make sure the filter(s) have been cleaned (Washed) and that the thermostat is set to the correct temperature. If the room temp is the same as the setting on the air con, it wont cool or heat. Just the fan will be operating.
Sep 10, 2014 | Heating & Cooling
No heat blowing cool air
if your talking heat pump yes. heat pumps only work down to about 40 degrees ambient. you getdown to 19 it needs heat strips or auxilarry heat of some source.
Jan 24, 2014 | Ruud Heating & Cooling
Not cooling
outside freeze sensor locking out operation
Jan 04, 2014 | Dometic Rooftop RV Air Conditioner
Maytag m6x06f2a like new but doest blow cold air
Make sure the Thermostat is set correctly! The problem with mine was the temp in the house was colder than my A/C lowest thermostat setting.I had my AC temp setting on 66 degrees.The temp in the house was a little lower so the AC didnt kick on just the fan blowing cool air and no compressor working. The next day it was warmer out and the house temp was 79. So when I powered up the AC set at 66 i heard the compressor kick in and the AC worked fine.
Aug 27, 2013 | Maytag M6X06F2A Air Conditioner
My ac unit is not cooling my house. it is blowing cool air but not as much as it used to. i have replaced the thermostat and the air filter, and it still has the same problem. what can it be? and how can i...
What is the temp of the air at the nearest vent when it comes out. then what is the temp of the air when it goes back into the return air? check your ouside fan and be certain it is clean as well and that the fan and compressor are running .
Jul 31, 2011 | Ruud UBHC Air Conditioner
Friedrich KStar KQ06J10 Air Conditioner not Cooling?
mcdevito75 here, Put the fan on and wait 3 minutes, NOW turn to low cool and place temp to 0 degrees or 1/2 thru the blue section of the cooling knob. Unit should work fine. type in online the unit name plus.com for any other assistance manuals, etc.
Jun 22, 2010 | Heating & Cooling
Fan for Air Conditioner
You have a fan temp sensor located on the engine block that controls when fan turns on or off.
Jun 19, 2009 | 2000 Nissan Xterra
1997 Amana 2 or 2.5 ton heat pump, 13 seer - air handler only blows 4-5 min
do you have a totaline t-stat. they and some other brands have a fan recirculation setting in the installers menu.
this is assuming that this happens in addition to the heating or cooling normally
Jul 02, 2008 | Amana PTH123B25AJ Heat Pump Air...
Heating & Cooling Logo
148 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
