Question about Homelite 'Yard Broom' Leaf Blower
Carboratoe loose carborator loose
  • 63 Answers
There's two bolts holding it on, tighten them
Posted on Jun 28, 2010
Suzuki troubleshooting
I have a 2003 suzuki grand vitara v6 and every time I take my foot off the gas pedal my car dies out any solution for this kind of problem?
Jan 01, 2014 | Light Outboard Motor Boat Bass Fishing...
Honda generator leaking gas from carborator
that is your fuel drain screw so if you get any water in your carb you can drain it and it was loose thats why gas drained out of it
Dec 16, 2012 | Briggs & Stratton Measuring Tools &...
McCulloch ChainSaw Model: 600035-18. Looking for manual. Replacing the Primer Bulb and hoses to fual tank, carborator, and from opposite side of carborator are bad. replaced the lines connected to the...
Hi cmiller290...
The hose in the tank with the filter on the end connects directly to the carburetor input connection.
When the saw is equipped with a primer bulb, an output line from the carburetor connects to the suction side of the primer (once the bulb is collapsed it draws fuel from the tank through the carburetor to refill as it inflates).
The pressure side of the primer returns displaced fuel to the tank as it is depressed.
To get your manual for your McCulloch chain saw, you need to call 1-800-521-8559, ask for parts, than ask for a PDF user manual,you will need the model number of the saw..
It will be e - mailed to you for FREE.
1-800-521-8559
MONDAY - FRIDAY - 6:00 AM - 4:30 PM (MST)
www.mccullochpower.com
Please take time to rate me
Aug 18, 2011 | McCulloch Garden
I have a 1974 Yamaha 400 idles fine but luggs down at higher RPMs. Took the air filter off & cleaned the carborato. Any ideas & suggestions would be appreciated. Bill & Will.
Could be one of a number of issues. 1. could be bad points/point gap/timing. 2. could be rich fuel,(jetting?). 3. plugged exhaust pipe.
Nov 01, 2010 | Yamaha DT 360 Motorcycles
How do i drain the gas in my kawasaki dirtbike
Take the fuel line loose at the carborator and drain into a can. Or you can shut the gas valve off and remove the tank and drain it by turning it over
Nov 07, 2009 | 2006 kawasaki KX 450 F
Spits sputters and backfires
carborator needs to be cleaned and the float needs to be reset
Aug 23, 2009 | 2004 Harley Davidson XL 883 Sportster
Kawasaki ZZR400 Won''t start, Looses power in top Gear
Hi and welcome to FixYa,
Initially, would suggest:
  • a thorough cleanup job on the carbs;
  • inspect, clean the rubber couplings from carbs to intake manifold;
  • inspect tighten coupling clamps;
  • ensure no vacuum leak when re-assembling;
  • inspect, check, ensure air intake box seating to the carbs. Very important, there should be no air leak. All air must pass through the cleaner/filter;
  • check/clean tank, including fuel valve control and built-in fuel filter;
  • use PRIM instead of ON on the fuel valve control.
And the "carborator sleeves" will only slide up when there is sufficient vacuum (engine running) and the throttle is turned.
Good luck and Thank you for using FixYa. Happy Holidays.
Dec 13, 2008 | 1997 kawasaki ZZR 400
Loosing transmission fluid
cheak your mudulator valve could be sucking fluid into the carborator
Dec 05, 2008 | 1988 Ford Ranger
Homelite 'Yard Broom' Leaf Blower Logo
79 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
