Question about Tomtom One XL GPS Receiver
My sister's TomTom froze and I can't turn it off
The SD card fell out for some reason, and the device froze and I can't turn it off, nothing.
  • 1,284 Answers
Hi, i had the same problem...I contacted Technical Support at TomTom and found out the following..
This is a copy of the message I received from Technical Support...it does include formatting the drive...you will need to back up your maps...
After all maps have been copied to the computer, we can reformat the disk. This is done by entering to My Computer and right clicking on the drive that displays the TomTom. From there, left click on format and choose start (not quick format). In one to two minutes, the disk will be formatted and all files will have deleted. This does mean we will have lost all demos for audiobooks and mp3 player. After doing this, we can copy the map folders back onto the TomTom drive from the desktop. Then, we can open the TomTom HOME program. Once the program reads the TomTom drive, it will check for updates. These updates should include a TomTom program application and voices. We can download these updates and then choose to install them. Once installed, we can then safely remove hardware. The unit should reboot on its own, but we may have to reset the unit if it does not. After doing this, the unit should be in full working order and you should be able to navigate.
Just a quick note...in order for the TomTom to work correctly, we must have an application, a map, and at least one voice installed on the hard drive.
Take care
Posted on Jun 03, 2010
When turn On can get the screen showing the GPS connected to Computer when not connected ,On Battery only, get red cross flashing
If your TomTom shows a red cross, it means the device is not able to load the software to be able to operate. Some devices have this software on a SD-card, some have it stored on an internal memory.
If there was a SD-card in your TomTom, I would suggest to put it back. If there is a empty SD-slot on your device, it could be you lost your SD-card, but some TomTom devices have an internal memory AND a SD-slot for memory extension, so if you have an empty cardslot it doesn't necessarily mean there has to be a card in it.
When you never saw a SD-card, probably some data went corrupt on the internal memory. When you have a SD-card, probably some data got corrupted on the SD-card.
To repair the software, you need to connect your GPS to your PC or Mac with a USB cable.
You also need the program TomTom HOME. You can download it for free on the TomTom website.
With TomTom HOME you can update the operating system of your device for free (map updates are nor free).
Try updating, and see if your device works again.
If this doesn't work, post it here.
May 14, 2015 | Tomtom GPS
My tomtom fell on the floor and i get aflashing red and white cross. How do i correct this and get my device working again?
Internal memory was damaged when dropped.. OR the SD card if it has one. Replace the sd card and copy data over from back up
Feb 23, 2013 | Tomtom ONE XL GB Car GPS Receiver
I can't get my tomtom to turn on. It is plugged
Straight from the TomTom website:
To reset your TomTom device, do the following:
  1. Check that the battery is charged properly.
    Charge your device for at least 2 hours before trying to turn it on again. Make sure the charging light on your device is on.
  2. Remove the SD card
    If your device uses an SD card, remove it.
  3. Reset your device.
    Use a straightened paper clip, or something similar, to push the reset button for 15 seconds. See the pictures below for where to find the reset button.
  4. Turn your device on.
    Press the On/off button for at least 5 seconds.
  5. Insert the SD card
    If your device uses an SD card, insert the SD card.
    I hope this helps!
Mar 09, 2010 | Tomtom ONE XL GPS
Basic screen when turned on...can't do anything else.
You will need to do a soft reset here are the instructions:
Oct 16, 2009 | Tomtom GO 910 GPS Receiver
My go 720 gps keeps freezing up
try resetting it, if that doesnt work, connect your unit to tomtom home. if you dont have tomtom home, follow the link at the bottom.
Aug 20, 2009 | Tomtom GO 720 GPS Receiver
Restore to factory setting
n rare cases, your TomTom device may not start correctly or may stop responding. If this happens, try resetting your device. The only information lost on your device is the clock’s time zone setting. Select your device from the list below to see how to reset it.
Select your device: TomTom GO 940/740/540 TomTom GO 930/730/630/530 TomTom GO 920/720/520 TomTom GO 910/710/510 TomTom GO, GO 300/500/700 TomTom XL IQ Routes TomTom XL (30-Series) TomTom ONE XL TomTom ONE IQ Routes TomTom ONE 30 Series TomTom ONE 3rd Edition TomTom ONE 2nd Edition TomTom ONE 1st Edition TomTom RIDER 1st Edition, RIDER 2nd Edition TomTom ECLIPSE II TomTom DAIHATSU, TomTom ECLIPSE, TomTom TOYOTA Help Not sure which device you have? ico_close.gif Type the first two characters of your device's serial number below to find out.
The rest button is on the top of the GPS
Jul 23, 2009 | Tomtom GO 910 GPS Receiver
The map cartridge fell out of the bottom of the Tom Tom.
Yes, it can be replaced, the map cartridge is a standard SD memory card.
These can be bought quite cheap in most camera/computer stores or in several department stores.
They can also be bought online from amazon See Here $6.65
Once you have the new card, connect the device to your computer. Open the TomTom Home application. Click on 'Update My Device'. This should then install the application onto the SD card. Alternativly, you could perform all the steps above without the SD card in the device, this will install the application onto the internal memory. Note: you may also need to install your maps, voices, etc after you update.
Apr 05, 2009 | Tomtom One XL GPS Receiver
Tom tom one xl wont accept SD card with map on
If you have TomTom that have the slot for SD card, then it should accepted the SD card. The instruction for how to use the SD card is simple, but it is hidden in the TomTom Home, that's why it's difficult to find it. Below are the instruction how to use the SD card.
1. Format the SD card (FAT32) and do not stick the SD in the slot yet
2. Run Backup (connect TomTom device to computer)
3. Disconnect TomTom from computer and turn off
4. Slide the SD into the slot and connect TomTom back to computer (choose "yes")
5. In the TomTom Home menu, Choosen Backup & Restore >>> and choosen Restore
TomTom Home will add all applications to the SD card. So the internal memory still have the applications and the SD card also had the same applications. Everytime you slide the card in, TomTom will automatic detect and use it as its primary storage, if it not detect, you can go to the device menu and pick the device to connect to.
Whenver you take the SD card out, then TomTom will use its internal memory.
Hope this helpful
Apr 24, 2008 | Tomtom One Europe v2 GPS Receiver
Tom tom 910
do you have a sd card in the unit? take it out and push the reset button
Jan 16, 2008 | Tomtom GO 910 GPS Receiver
TOMTOM 510 not reading SD card
I did find out how to solve the problem. I can't remember exactly where I found the solution but I think it was on TOMTOM website. You have to connect to TOMTOM home and reinstall the application. I put the TOMTOM disc in the computer (which came with purchase) and reinstalled the program. Which I thought was weird as everything appeard to be fine with TOMTOM home). Anyway, it worked. Good luck.
Sep 30, 2007 | Tomtom GO 510 GPS Receiver
Tomtom One XL GPS Receiver Logo
74 people viewed this question
Top Tomtom GPS Experts
k24674
Martin Murray
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
